Using 4x4 Sheets Of Drywall Vs 4x8 - Drywall - Contractor Talk
Old 11-23-2019, 12:10 PM   #1
jb9's Avatar
Trade: Plumbing
Rewards Points: 204
Hello,
Other than the fact that there will be more taping/finish work, is there any reason that I can't use 4x4 sheets of drywall to finish my shop? I just don't think that I can wrangle the 4x8 sheets by myself and I also have limited space (the workshop is 12'x16').
Thanks.
jb9 is offline
Old 11-23-2019, 12:36 PM   #2
A2Zcontracting's Avatar
Trade: General Building
Rewards Points: 160
Re: Using 4x4 Sheets Of Drywall Vs 4x8
No reason you cant... Just makes for alot of extra butt joints and mud work. If your shop is 12 x 16 or anything just under 12' i would want to use 12' sheets and a helper. That would eliminate alot of extra taping and mud work if youre going for a clean finish. I would especially want to reduce the seams on the lid however possible. If the cieling joists run perpendicular to the 12' walls you can cut your seam work down massively. Would only have 3 factory seams on the lid.
Have you considered renting a drywall lift? Also, what thickness of drywall are you gonna be using? Are you going for a clean finish or just L2?
Sent from my LM-Q710.FG using Tapatalk
A2Zcontracting is online now
The Following User Says Thank You to A2Zcontracting For This Useful Post:
ScipioAfricanus (11-24-2019)
Old 11-23-2019, 12:55 PM   #3
avenge's Avatar
Rewards Points: 108
No way I would want those extra seams.
avenge is online now
The Following 2 Users Say Thank You to avenge For This Useful Post:
Calidecks (11-24-2019), Seven-Delta-FortyOne (11-23-2019)
Old 11-23-2019, 02:16 PM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,006
Just no.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
Calidecks (11-24-2019), jhark123 (11-27-2019)
Old 11-23-2019, 02:20 PM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,721
Originally Posted by jb9 View Post
Hello,
Thanks.
When you think about all the extra cutting and taping, the boards get lighter. Try a panel carrier tool, as well.
MarkJames is online now
Fouthgeneration (11-23-2019)
Old 11-23-2019, 03:51 PM   #6
PCI
PCI's Avatar
Trade: contractor
Rewards Points: 848
Second a drywall lift, it works for walls too.
PCI is online now
The Following User Says Thank You to PCI For This Useful Post:
Old 11-23-2019, 03:54 PM   #7
PCI
PCI's Avatar
Trade: contractor
Rewards Points: 848
Drywall lift was my impetus for the cordless screw gun and roto zip. Hated moving cords to push it around and cords always tangled.
PCI is online now
TheConstruct (11-23-2019)
Old 11-23-2019, 05:34 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,335
Rent or buy(resell later) a lift, it will allow you to use 5/8" products EVERY where, sides and ceiliing. giving you MORE strength, less damage in the future, and more fire safety at a tiny cost today, quieter and Warmer/cooler
The walls will be much flatter as the longer DW flattens crazy studs some what, Don't be afraid to saw silly studs plumb(in and out axis) as needed with a chalk line and skil saw, save hours when shelving and installing cabinets later.
Any chance of water, USE fiberglass faced rock....
Hire a weight lifting buddy to help unload and hang the rock, in this case big is better.
I'd block any joints that are "exposed" in a shop to add strength to the "floating" parts of the dry wall seams.
Don't forget future cabinets blocking needs prior to DWalling.
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
MarkJames (11-23-2019)
Old 11-23-2019, 07:57 PM   #9
hdavis's Avatar
Rewards Points: 1,540
Honestly, if I didn't think I could handle a 4X8, I'd call a drywall buddy of mine and see if he knows any hangers that want a side job.
hdavis is offline
The Following 3 Users Say Thank You to hdavis For This Useful Post:
Fouthgeneration (11-23-2019), Joasis (11-24-2019), TheConstruct (11-23-2019)
Old 11-23-2019, 08:11 PM   #10
TheConstruct's Avatar
Rewards Points: 1,372
I've hung a lot of drywall solo, screw blocks of wood on the walls and ceiling as needed for a second set of hands if you're going to do it solo. A bit of 1x4 and 2x4 can be quickly assembled in any configuration that will hold an end for you. Might be a good time to buy a third hand pole too.
Boarders would laugh at the way I've done it I'm sure but itll get ya there and save hours and hours of finishing 4x4 sheets.
TheConstruct is online now
The Following 2 Users Say Thank You to TheConstruct For This Useful Post:
Fouthgeneration (11-24-2019), hdavis (11-23-2019)
Old 11-23-2019, 10:31 PM   #11
hdavis's Avatar
BTW, if you can't work the crank on a drywall lift, it's possible to build one that uses an electric hoist.
It takes a little time to make one out of 2X6s and 2X4s, but a home made electric one works fine.
hdavis is offline
Old 11-24-2019, 12:42 AM   #12
Fire up the BBQ
griz's Avatar
Rewards Points: 370
WTF, your a plumber...
go install an extra toilet or water heater and pay a dry wall guy...
griz is online now
The Following 6 Users Say Thank You to griz For This Useful Post:
blacktop (12-02-2019), cedarboarder (11-24-2019), finisher65 (11-24-2019), Fouthgeneration (11-24-2019), Joasis (11-24-2019), pizalm (11-24-2019)
Old 11-24-2019, 04:10 AM   #13
test
cedarboarder's Avatar
Trade: General
Rewards Points: 1,751
LOL. 100% the best way to do it.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 11-24-2019, 07:21 AM   #14
Joasis's Avatar
Rewards Points: 602
It is a shop....gee.
My shop has visible spray foam, and some day (we all know that one), I intend to line it with OSB. It would matter not one bit to do 4 foot rock, and if a guy wanted a cool look, trim it all with 1x4s fora coffered ceiling. Think of all the ways you could hang stuff from the ceiling then. And minimal taping. Like none.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 2 Users Say Thank You to Joasis For This Useful Post:
Calidecks (11-24-2019), TheConstruct (11-24-2019)
Old 11-24-2019, 10:56 AM   #15
Frank Castle's Avatar
Rewards Points: 258
This is what I was thinking also. Makes hanging things on the wall much easier.
Adapt, Improvise, Overcome.
Frank Castle is online now
Old 11-24-2019, 11:42 AM   #16
Joasis's Avatar
Rewards Points: 602
Already have backing for peg board. Win, win.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
Old 11-24-2019, 11:46 AM   #17
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,543
Buy more beer and you'll never notice the difference.
rescraft is offline
Old 11-24-2019, 12:17 PM   #18
VinylHanger's Avatar
Rewards Points: 11,488
If you can't lift 4x8 sheets of 1/2 inch, you need to exercise more.
Seriously though, just grab a lift for like 50 bucks a day and get it done. Or a buddy. And I'd still use a lift on the lid.
Use 12's if possible and it's done quick and easy.
Sent from my SM-N975U using Tapatalk
VinylHanger is offline
Old 11-24-2019, 12:51 PM   #19
Rewards Points: 258
Funny you should mention peg board.
Didn't say it becuase some don't like that much peg board.
My whole shop is covered with it. There are sooooo many things I can do with a peg board hook.
Old 11-24-2019, 06:41 PM   #20
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
Drywall for fire resistance, then mill some french cleats for hanging cabinets, tool bars, or hangers.
P42003 is offline
The Following 3 Users Say Thank You to P42003 For This Useful Post:
Fouthgeneration (11-24-2019), MarkJames (11-25-2019), SmallTownGuy (11-25-2019)
