Trowel Or Knife?? - Page 2 - Drywall - Contractor Talk
Trowel Or Knife??
Old 06-12-2006, 06:52 AM   #21
drywall's Avatar
Re: Trowel Or Knife??
I have been doing the tapping by hand for over 15 years.I have used trowles and the six inch knife in new york, then i moved to georgia and use only knifes..they are both just as quick.(depends on the operator)never used fancy tools. I do it by hand.
drywall is offline
Old 06-12-2006, 11:54 AM   #22
sidejobs's Avatar
Trade: Dry wall Hanger taper and texture
Rewards Points: 75
I've been taping for 15 years, used a pan and knives for the first year then moved up to a hawk. I would never go back to a pan. I also found the commercial hawks are way too small, I made my own out of an old street sign (cut down to a 15" square) and added a wood handle. Works great and you can really load on the mud. It makes it easy when using your 8, 10, 12, and even a 16 knife.
sidejobs is offline
Old 06-12-2006, 09:59 PM   #23
AtlanticWBConst's Avatar
Rewards Points: 2,000
Trained with knives and Hawks in the early 80's
After many years, I don't do much taping now, but I def. can still do it...
One of those things you NEVER lose.
My thoughts:
Seen Trowels used adeptly.
Was on a job a few years back skim-coating 30" flats with a 12" knife (2 non-factory seams) - completely smooth, managed to convert some to 'the knife'.
I've always figured, it's what you were trained on.
Tho, I am sold on knives.
To me: Trowels are for plastering, knives are for taping...
Don't shoot me for that. I am entitled to my own humble opinion.
- Build Well -
AtlanticWBConst is offline
Old 06-13-2006, 04:10 AM   #24
Kristina's Avatar
Rewards Points: 250
Originally Posted by andrewtlocke
To finish:
6" knife for finishing corners and angles.
12" pan knife for bead
12" flat trowel for flats and butts (my butts are 24" wide finished)
In my opinion, having watched pros and my husband (not a pro taper) I'd think that the smaller knives would be easier to control for someone who doesn't know what the hell they are doing.
My husband did some taping here and umm needless to say, the PROS are coming in today to do the job right.
He is of the "bigger is better" mindset. Doesn't use a hawk but was using at LEAST a 14" trowel. I have plops of compound all over my floors, dressers, electronics AND it doesn't even look that good. I was going to attempt a small room, with regular old tape (he got the fancy expensive stuff ) but he got the guys in here before I could do it. I was just going to use a 6" knife. More control for my little hands.
By the end of the today it won't matter, the pros we use have the big trowels and hawks and they actually know how to use them.
Kristina is offline
Old 05-31-2007, 09:12 PM   #25
steve-in-kville's Avatar
Trade: Drywall/Textures/Paint
Rewards Points: 250
I've been experiementing with various techniques with both knives and trowels. I've found a system that works pretty slick for me, an prolly no one else...
4" knife for embedding tape, both flats and corners/bead.
6" knife for first coat (corners, bead and tapered seams).
12" trowel thereafter... for everything (yes, it can be done!)
I've come to appreciate the trowels. I have a larger 20" masonry trowel I use to float out pillars or large seams.
steve
Originally Posted by Paintguy26 View Post
.... everything was all warm and cushy until this.... please comfort me and say that someone held a gun to your head and made you say that
steve-in-kville is offline
Old 05-31-2007, 09:41 PM   #26
oldrivers's Avatar
Trade: drywall applications
Rewards Points: 522
pan and knifes, hawks and trowels just depends on what im doing .
oh and yes the 20 inch trowel is a neccesity.
oldrivers is offline
Old 05-31-2007, 09:43 PM   #27
oldrivers's Avatar
Rewards Points: 522
"He is of the "bigger is better" mindset. Doesn't use a hawk but was using at LEAST a 14" trowel. I have plops of compound all over my floors, dressers, electronics AND it doesn't even look that good. I was going to attempt a small room, with regular old tape "
we put down rosen paper on all the floors , easy clean up.
Old 05-31-2007, 09:45 PM   #28
oldrivers's Avatar
Rewards Points: 522
delete.
Old 05-31-2007, 09:53 PM   #29
Rewards Points: 250
I did a search on trowels vs. knives and found this thread. Only now do I realize it is almost a year old.
The subject needed brought up again anyways.
steev
Old 05-31-2007, 09:56 PM   #30
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
I can use both very efficiently, but knife & pan is my tool(s) of choice.
My dad however, a unbelievable finisher is very old school and still uses his hawk & trowel for all finishing. Well, he tapes with a 4" knife & pan, than blocks & skims everything else with his hawk & trowel. He taught me how to finish with a hawk & trowel when I was 12, it was not til 9 years later that I learned to use a knife & pan efficiently.
I still have my old hawk & trowel in my finishing bag..it is broken in so nice I think I would cry if something would happen to it.
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 05-31-2007, 10:44 PM   #31
taper71's Avatar
Trade: Drywall Taper
Rewards Points: 250
I used a hawk and trowel for 14 years. I tried knives 2 years ago and I will never go back to trowel as my main tool. With knives i found i get a cleaner corner ( less sanding woo hoo ) better control, less hard on the wrist, and don't get the odd knuckle marks that you have to go over again. I still use my big trowel on pillars and such as I can do it in one pass.
I still use a hawk for finishing -the pans suck- Mud dries out and you have to constantly clean them. I do use a pan for taping though - Muds alot thinner and less mess.
taper71 is offline
Old 06-01-2007, 06:02 AM   #32
Jcllc's Avatar
Rewards Points: 75
I started using knives almost 6 years ago for everything now after learning more and watching old timers I have come around to trowel.Never used the auto tools and don't think I ever will. I have seen them used and those using them are pretty good still have to hand turn corners etc. so why use auto tools. just my two cents
Jcllc is offline
Old 06-01-2007, 08:16 AM   #33
Frankawitz's Avatar
Rewards Points: 1,196
After 22 years I use them both just depends how I feel that day, Hey IHI have you tried to apply the mud to your ceilings with a textured roller and then use your 36" might be a little easier then lifting that baby with all that mud.
Frankawitz is offline
Old 06-01-2007, 10:02 PM   #34
Mater's Avatar
Rewards Points: 75
Hawk and trowel???? I'm stilll a young pup I guess. I never knew a guy/girl could finish with a trowel. I'd like to see it done sometime. Also a quick question for the "experienced gerousia" in our midst. Did any of you ever tape, bed, and skim with only a 6" knife? I'm a knife man, until I get my apla-techs . I don't have $10k to drop right now on them! BTW: someone had a 36" butt here???
Mater is offline
Old 06-02-2007, 04:59 PM   #35
mud dog's Avatar
Trade: drywall
Rewards Points: 150
Hawk and trowel for beads, butts and flats. knives for everything else. The only difference between a "pan and Knifer" and a "hawk and troweler" is where they ache at the end of the day.
mud dog is offline
Old 11-02-2007, 10:43 PM   #36
BoB The Fixer's Avatar
i started my taping by trowel and at the once i used the knife i never used the trowel again , because for me it was faster , easier, etc..
best wishes
BoB The Fixer is offline
Old 11-02-2007, 11:03 PM   #37
Al Smith
A W Smith's Avatar
I use 6, 8, and 12 inch knives with mud pan. I started out with knives then a builder I worked for convinced me to try and use a trowel and hawk. I did that for a few years but I damaged my trowel by dropping it and went back to knives and its been knives ever since. One guy who I finished with who was a union taper before he became the town animal control officer told me he shaped up at Quaker Bridge Mall when they were building it and they sent him, his mud pan, and knives home as it was a trowel job. Years later I visited the mall and the drywall finish work looked like s***.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 11-03-2007, 12:22 AM   #38
Head sawdust creator
Bummie's Avatar
Trade: Jack of All.... Master of a Couple
Rewards Points: 1,038
Taping.... pan and knife. Beads and finishing ... hawk and trowel.
"Whether you think you can or think you can't.... you are right!!!" Henry Ford
Bummie is offline
Old 11-03-2007, 02:21 AM   #39
localtradesman's Avatar
Trade: Personal speciality Drywall, Painting, Finish Work
Rewards Points: 75
I have always used knifes......I can say that after years of using knifes I do near perfect work. Who sands???? Very, Very little, and the best tool for sanding is the RADIUS 360.......best on the planet....... I dare anyone to find a better product. Or haven't you heard of the radius 360?????? Plaster guys never use knives and drywall guys should stick to knives. Take That!!!
localtradesman is offline
Old 11-03-2007, 03:20 PM   #40
kgphoto's Avatar
Trade: Residential Remodeling
Rewards Points: 250
Both! And at the Same time! I mean I use a hawk and knife or pan and knife or hawk and trowel. Trowels allow me to move more mud faster and put more mud on the wall. I get a better finish with knives.
I use a 6 inch knife and 12 inch knife, mostly. I also use, when necessary, a 1 1/2", 3 " angle, 4, 5, 8 inch knives. I use the largest one that will fit or the 4 inch to set No-Coat products.
kgphoto is offline
power trowel banctecbobn Construction 9 02-05-2013 11:28 PM
What utility knife do you use? Michaeljp86 General Discussion 33 08-20-2007 05:10 PM
Large Radius Cove Trowel Pauline100 Drywall 4 07-17-2007 07:47 PM
pointing trowel question roo Masonry 11 05-05-2007 07:09 PM
Golden Trowel Awards Tscarborough Masonry 6 06-17-2006 05:50 PM
