Texture Replication - Drywall - Contractor Talk
Texture Replication
Old 10-27-2011, 10:32 AM   #1
Wasting Time
Knighton's Avatar
Rewards Points: 75
Texture Replication
I removed a loadbearing wall and replaced it with an LVL in one of my clients homes. In the process I had to remove some drywall on the ceiling. In attempting to repair the drywall, I'm having difficulty determining just how the light texture was done. I thought it was just a light roll-on texture, but I can't see to get it to look right. Any ideas on how to replicate this texure would be grately appreciated.
Thanks
Chris
Knighton is offline
Old 10-27-2011, 11:44 AM   #2
Thom
thom's Avatar
Rewards Points: 4,748
Re: Texture Replication
I think that was done with a splayed texture brush, with multiple slaps in the same location.
thom is offline
Old 10-27-2011, 03:08 PM   #3
Wasting Time
Knighton's Avatar
Rewards Points: 75
What type of brush would that be?
Knighton is offline
Old 10-27-2011, 04:47 PM   #4
boman47k's Avatar
Rewards Points: 2,006
Wadded up newspaper or trash bag.
Jk'ing mostly. Sorta.
Sorry, just wanted to get notices as people respond to this thread.
boman47k is offline
Old 10-27-2011, 10:47 PM   #5
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
Thats a new one. Does it look professionally done everywhere or is it a home owner thing? I always have a much harder time matching a texture that was done with very little skill.
SuperiorHIP is offline
The Following User Says Thank You to SuperiorHIP For This Useful Post:
J L (11-01-2011)
Old 10-28-2011, 06:26 AM   #6
Wasting Time
Knighton's Avatar
Rewards Points: 75
Yeah, its everywhere and it does look good. House was built in early 60s. It has to be some sort of brush, I just can't figure it out.
Knighton is offline
Old 10-28-2011, 06:45 AM   #7
PSG's Avatar
Trade: Remodeler & Radon Mitigator
Rewards Points: 75
I found a site www.drywallschool.com that has examples of different textures and explains how to do them.
PSG is offline
Old 10-28-2011, 07:36 AM   #8
Wasting Time
Knighton's Avatar
Rewards Points: 75
I've seen that. And while one of his texture examples is sort of close, theres not one thats close enough. I may just have to retexture the whole ceiling in something close. I would just hate to have to do that.
Knighton is offline
Old 10-28-2011, 10:24 AM   #9
Thom
thom's Avatar
30 years ago, around here, a splayed brush was pretty common. The wood brush base is about 8" long, 1-1/2" wide, round on both ends. The brush fibers are about 3" long and splay out in an oval, they are bent so they are flat, so you have a flat oval. The brush fibers leave those lines when lifted. Typically there are two of these brushes on a single handle.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100403181&l angId=-1&catalogId=10053&ci_sku=100403181&ci_kw={keyword} &cm_mmc=shopping-_-googleads-_-pla-_-100403181&ci_gpa=pla&locStoreNum=3502
Generally the brush leaves an oval pattern but if you rotate it and slap it multiple times the lines will have no direction to them.
thom is offline
Old 10-28-2011, 01:22 PM   #10
Wasting Time
Knighton's Avatar
Rewards Points: 75
Oh, that's what you meant! I always just called that a texture brush. The word "splayed" threw me (though it was certainly a correct use of the word). I was hoping you had a super special secret brush I'd never heard of that would magically work. I guess I'll play around with that and slapbrush it to see if I can match it .
Thanks for your help.
Knighton is offline
Old 10-28-2011, 11:10 PM   #11
Rouerplastering's Avatar
Trade: plastering and sheetrocking
Rewards Points: 75
around here it's called a crow's foot. And it's
not done with that.
Rouerplastering is offline
Old 10-29-2011, 12:26 PM   #12
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
I'm not great with textures but to me that looks like a heavily sprayed orange peel that was pole sanded.
Metro M & L is offline
Old 10-29-2011, 03:33 PM   #13
Working
Cole82's Avatar
Rewards Points: 2,276
Is it drywall or veneer plaster? To me it looks like vaneer plaster finished with a wood trowel. It's hard to say though as there is nothing to scale the texture too. Can't tell if they are 1/16" ridges or 1/4" ridges.
Cole
The boss of awesome
Cole82 is offline
Old 10-29-2011, 09:34 PM   #14
Janitor
Repairman615's Avatar
Trade: Renovation and Design
Rewards Points: 150
I am guessing a knock-down and just maybe, wet sponge after swipe.
Roll on the thinned mud, stomp well rotating the brush, wait and knock down... then maybe wait and sponge it down.
I will admit now that I have trouble too while getting textures to blend.
Repairman615 is offline
Old 10-31-2011, 07:41 PM   #15
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
I've used thick texture paints with a texture roller that look very similar to that.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 11-01-2011, 04:59 AM   #16
Big Shoe's Avatar
Rewards Points: 2,136
Kinda looks like a roller-knockdown. Roll on mud and then knock it down.
You have to tack a sheet of drywall up on your shop/garage ceiling and do some test runs.
Big Shoe is online now
Need some texture advice... Ralf Miranda Drywall 23 06-11-2011 08:17 AM
Popcorn Texture over Concrete AM1965 Drywall 14 04-15-2010 10:51 AM
Ceiling texture fun!! EricTheHandyman Drywall 2 04-01-2009 09:14 PM
Snow texture, popcorn texture... AARC Drywall Drywall 5 10-30-2008 01:30 AM
Pock marks in Orange Peel texture MCComplete Drywall 4 01-14-2008 11:09 AM
