-   Drywall (https://www.contractortalk.com/f49/)
-   -   Texture Replication (https://www.contractortalk.com/f49/texture-replication-106694/)
Knighton 10-27-2011 10:32 AM
Texture Replication
1 Attachment(s)
I removed a loadbearing wall and replaced it with an LVL in one of my clients homes. In the process I had to remove some drywall on the ceiling. In attempting to repair the drywall, I'm having difficulty determining just how the light texture was done. I thought it was just a light roll-on texture, but I can't see to get it to look right. Any ideas on how to replicate this texure would be grately appreciated.
Thanks
Chris
thom 10-27-2011 11:44 AM
I think that was done with a splayed texture brush, with multiple slaps in the same location.
Knighton 10-27-2011 03:08 PM
What type of brush would that be?
boman47k 10-27-2011 04:47 PM
Wadded up newspaper or trash bag.
Jk'ing mostly. Sorta.
Sorry, just wanted to get notices as people respond to this thread.
SuperiorHIP 10-27-2011 10:47 PM
Thats a new one. Does it look professionally done everywhere or is it a home owner thing? I always have a much harder time matching a texture that was done with very little skill.
Knighton 10-28-2011 06:26 AM
Yeah, its everywhere and it does look good. House was built in early 60s. It has to be some sort of brush, I just can't figure it out.
PSG 10-28-2011 06:45 AM
I found a site www.drywallschool.com that has examples of different textures and explains how to do them.
Knighton 10-28-2011 07:36 AM
I've seen that. And while one of his texture examples is sort of close, theres not one thats close enough. I may just have to retexture the whole ceiling in something close. I would just hate to have to do that.
thom 10-28-2011 10:24 AM
30 years ago, around here, a splayed brush was pretty common. The wood brush base is about 8" long, 1-1/2" wide, round on both ends. The brush fibers are about 3" long and splay out in an oval, they are bent so they are flat, so you have a flat oval. The brush fibers leave those lines when lifted. Typically there are two of these brushes on a single handle.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100403181&l angId=-1&catalogId=10053&ci_sku=100403181&ci_kw={keyword} &cm_mmc=shopping-_-googleads-_-pla-_-100403181&ci_gpa=pla&locStoreNum=3502
Generally the brush leaves an oval pattern but if you rotate it and slap it multiple times the lines will have no direction to them.
Knighton 10-28-2011 01:22 PM
Oh, that's what you meant! I always just called that a texture brush. The word "splayed" threw me (though it was certainly a correct use of the word). I was hoping you had a super special secret brush I'd never heard of that would magically work;). I guess I'll play around with that and slapbrush it to see if I can match it .
Thanks for your help.
Rouerplastering 10-28-2011 11:10 PM
around here it's called a crow's foot. And it's
not done with that.
Metro M & L 10-29-2011 12:26 PM
I'm not great with textures but to me that looks like a heavily sprayed orange peel that was pole sanded.
Cole82 10-29-2011 03:33 PM
Is it drywall or veneer plaster? To me it looks like vaneer plaster finished with a wood trowel. It's hard to say though as there is nothing to scale the texture too. Can't tell if they are 1/16" ridges or 1/4" ridges.
Cole
Repairman615 10-29-2011 09:34 PM
I am guessing a knock-down and just maybe, wet sponge after swipe.
Roll on the thinned mud, stomp well rotating the brush, wait and knock down... then maybe wait and sponge it down.
I will admit now that I have trouble too while getting textures to blend. :blink::eek:
redwood 10-31-2011 07:41 PM
I've used thick texture paints with a texture roller that look very similar to that.
Big Shoe 11-01-2011 04:59 AM
Kinda looks like a roller-knockdown. Roll on mud and then knock it down.
You have to tack a sheet of drywall up on your shop/garage ceiling and do some test runs.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
