Termination Joint - Drywall - Contractor Talk
Termination Joint
Old 03-22-2019, 10:33 AM   #1
Tom M's Avatar
Rewards Points: 2,986
Termination Joint
What would be the preferred method to finish drywall against commercial window frames?
Tear away, Jay, flat tape or they make vinyl corner guard that doesn't wrap around both sides. I think "L" bead is the correct name
Tom M is online now
Old 03-22-2019, 07:22 PM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,716
Re: Termination Joint
Wood trim.
Big Johnson is online now
Old 03-22-2019, 09:15 PM   #3
Tom M's Avatar
Commercial aluminum window frames
Tom M is online now
Old 03-22-2019, 10:58 PM   #4
tjbnwi's Avatar
Rewards Points: 3,084
Tear away.
tjbnwi is offline
overanalyze (03-23-2019), Tom M (03-23-2019)
Old 03-23-2019, 05:33 AM   #5
I’d probably go with the tear away too. I’ve seen it done with the other choices and it’s not good.
Old 03-23-2019, 05:45 AM   #6
Tom M's Avatar
I lean on tear away too. Somehow I squired L bead in the garage dont know if there are specific applications for these products other than user discretion. Can't find my Trim Trex book either
Tom M is online now
Old 03-23-2019, 06:10 AM   #7
If you want to use the big J to save on labor look for a metal one. The vinyl ones warp and shlt.
Tom M (03-23-2019)
Old 03-23-2019, 07:36 AM   #8
Tom M's Avatar
The Mason's left little room for wood bucks and jagged block cells so I ended up I ended up making 3/4 plywood frames pocket screw together and floated in with spray foam. Plus a tapcon or two where I could.
came out very sturdy in my framing technique around the outside of the block tied in the plywood which I left long however these returns are about 10 in deep. So that detail isn't going to work.
I will probably just use the tear away or L bead. Just don't like spraying the adhesive next to the window that I'll have to cover up to prevent over spray
Tom M is online now
Old 03-23-2019, 07:53 AM   #9
tjbnwi's Avatar
Please refer to this thread before continuing;
https://www.contractortalk.com/f11/blue-tape-416881/
tjbnwi is offline
Tom M (03-23-2019)
Old 03-23-2019, 08:41 AM   #10
Tom M's Avatar
They're already taped up because of the spray foam I left it in place.
Tom M is online now
Old 03-23-2019, 09:49 PM   #11
tjbnwi's Avatar
Opportunity lost...
tjbnwi is offline
Old 03-30-2019, 06:52 AM   #12
Tom M's Avatar
Ultimately I used tear away. Its a great option and time saver for painter too
Termination joint-hut-rough-windows.jpg   Termination joint-img_20190329_143327563.jpg
Tom M is online now
Old 03-30-2019, 07:01 AM   #13
Old 03-30-2019, 09:01 AM   #14
Fishindude's Avatar
Trade: Industrial
Rewards Points: 818
Plastic "J" channel with tear away edge and hold just a little gap away from aluminum. After you tear away the inside edge and paint, caulk against the window frame.
Fishindude is offline
Scarf joint or butt joint Chicofish Finish Carpentry 30 12-13-2017 08:47 AM
Joint Compound w/ Dust Control & Tape Machine lifestooshort81 Drywall 4 06-11-2013 07:51 AM
joint cracked twice in a week r4r&r Drywall 9 06-29-2012 09:08 PM
Paver sand joint fill red_cedar Masonry 14 05-21-2012 08:17 PM
joint between brick pavers and slab phnola Landscaping 3 04-18-2012 08:38 PM
