Taping A Painted Corner - Drywall - Contractor Talk
Old 10-05-2014, 06:26 PM   #1
A. Finelli's Avatar
Rewards Points: 76
hey fellas, I couldn't get someone to tape/mud for me so i'm doing it myself, quick question, i have a corner that is half new drywall and half older painted drywall...can I tape and mud this corner like any other corner or is there something I need to do since i'm working with the older existing painted wall surface? thanks for the help, Anthony
A. Finelli is offline
Old 10-05-2014, 06:29 PM   #2
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,477
Re: Taping A Painted Corner
If the paint is flat, just mud as usual.
If the paint has a sheen, scuff with sandpaper before mudding.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
icerock drywall (10-05-2014)
Old 10-06-2014, 03:36 AM   #3
Big Shoe's Avatar
Rewards Points: 2,110
If framing/hanging is done correctly.........Flat tape and caulk..........sometimes no tape.............Framing is key here.
Otherwise like Sir Mixalot said.
Expect the Unexpected
Big Shoe is offline
Old 10-06-2014, 07:40 AM   #4
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
then you spray a thick texture over that?
dont work hard...work smart
icerock drywall is offline
Old 10-06-2014, 12:33 PM   #5
VinylHanger's Avatar
Rewards Points: 12,910
I just caulk it if possible, then match the texture as best as I can.
VinylHanger is offline
Old 10-06-2014, 02:21 PM   #6
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
I used to do a lot of patch and repair work. Any time I would patch a spot, even if I had the exact paint the wall was painted with you could always see the patch because of the texture difference between the old paint and the new drywall compound. The new patch always looked smoother than the old texture. An old drywaller showed me the trick to get rid of the difference. You have to skim coat the existing wall. This makes the existing wall match the texture of the patch. It only takes a light skim and sand over the existing wall to make it match. In my opinion if you are going to tape onto the existing paint, you should skim the wall and repaint the entire wall. If you don't you will see the texture difference where you have taped the corner.
muskoka guy is offline
The Following User Says Thank You to muskoka guy For This Useful Post:
Big Shoe (10-06-2014)
Old 10-06-2014, 02:25 PM   #7
Big Shoe's Avatar
I knew I should not have said anything. Who said anything about Texture.
And no, you can't just caulk it. It needs to be a solid connection.
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
icerock drywall (10-07-2014)
Old 10-06-2014, 02:35 PM   #8
Rewards Points: 558
I said something about texture. He asked about taping onto an existing painted wall. Without a doubt, the difference in the texture will be the give away that there has been a patch job done. If you don't mind everyone knowing that you have made a repair, disregard what I said.
Old 10-06-2014, 03:40 PM   #9
Big Shoe's Avatar
I think we were both posting at the same time. You are 100% correct on skimming out the entire wall if you don't want it to be noticeable.
N
Big Shoe is offline
Old 10-06-2014, 04:23 PM   #10
A. Finelli's Avatar
Rewards Points: 76
thanks fellas, sounds like i'll have to give the homeowners a couple options and see how they want to go with it. thanks for the help, i appreciate it! ~Anthony
Old 10-07-2014, 07:39 AM   #11
Trade: drywaller
Rewards Points: 930
ever try a rubber knife
Old 10-07-2014, 07:45 AM   #12
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
??? For skimming??
-Steve
TimelessQuality is offline
Old 10-07-2014, 09:06 AM   #13
Trade: drywaller
Rewards Points: 930
Originally Posted by TimelessQuality View Post
??? For skimming??
when rework or patch work into texture you get this with
taping a painted corner-0904131208.jpg   taping a painted corner-0904131208a.jpg
The Following User Says Thank You to icerock drywall For This Useful Post:
RiverBG (10-09-2014)
Old 10-07-2014, 09:08 AM   #14
Trade: drywaller
Rewards Points: 930
rubber knife you get this
taping a painted corner-0904131210.jpg   taping a painted corner-0904131211a.jpg
j_sims (10-07-2014)
Old 10-07-2014, 09:34 AM   #15
Oooo I get it now thanks!
Now I gotta get one
-Steve
The Following User Says Thank You to TimelessQuality For This Useful Post:
Old 10-07-2014, 09:45 AM   #16
Sweet. I gotta get me one too.
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 10-07-2014, 10:48 AM   #17
Trade: drywaller
Rewards Points: 930
the red knife I used a plastic knife with a rubber tip from a dust pan and glued it on here is my 2nd knife and I did make a new one but don't have a pic... yet
Old 10-07-2014, 10:50 AM   #18
Trade: drywaller
Rewards Points: 930
skim out the hole wall....no thank you
Old 10-07-2014, 10:52 AM   #19
MarkJames's Avatar
Rewards Points: 18,915
That knife will help do that stipple (or whatever it's called)? How? Does the blade have ridges?
MarkJames is online now
Old 10-07-2014, 11:00 AM   #20
Trade: drywaller
Rewards Points: 930
it flows over the texture so it don't leave lines...I did this test without sanding or scraping it first....if it did scrap it first it would off looked sweet but it as to show how it works...
I use this tool for my fiberfuse tape (it don't rip it)
and texture repair / knock down where my big tool don't fit
hdavis (10-09-2014)
Automatic Taping Tools Part Time Taper Drywall 11 01-03-2020 09:28 PM
Cutting drywall 4' and corner bead questions plazaman Drywall 39 01-01-2013 01:59 AM
Eavestroughing Corner Patterns CdnTrougher General Discussion 1 10-15-2012 11:55 AM
Corner window framing- No post, cantilever. tyler durden Carpentry 9 08-15-2012 09:00 PM
corner piece--siding davinci Windows, Siding and Doors 11 07-20-2009 09:05 PM
