Taping & Finishing Modular Home - Drywall - Contractor Talk
Old 07-18-2018, 06:41 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 618
Have customer some distance away, who says he has removed most of the joiner strips.
He wants me to look at taping and finishing his modular sheetrock - all drywall that I have done has been either commercial/metal or residential structures.
Am a little concerned about the backing/how wallboard was put up (if it has sufficient support, or if it relies on the joiners).
Is it generally okay to tape these joints, from a standpoint of potential cracking, etc?
artinall is offline
Old 07-18-2018, 09:15 PM   #2
hdavis's Avatar
Rewards Points: 2,362
Re: Taping & Finishing Modular Home
Those walls can move a lot more thsn a regular wall, so they're more prone to cracking.
hdavis is online now
Old 07-18-2018, 09:27 PM   #3
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
The wholly wood framed floor modular homes I seen (NO METAL FRAME like a 'trailer home') were MUCH stiffer then same generation of spec homes as they where design and built to SUCCESSFULLY travel hundreds of mile on bumpy highways...
If the home has been wet, some structural integrity might of been destroyed....
In addition to double and triple rim joists, the sheathing and dry wall are commonly glued and fastened to the framing.....
Whisper that it might be CHEAPER to move to a home with "real" dry wall than polish a turd, IMHO.
Fouthgeneration is offline
Old 07-18-2018, 11:49 PM   #4
hdavis's Avatar
The framing on thesr movr relstively easily. Fall against a wall, and you'll see ehat I mean
Old 07-18-2018, 11:50 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 680
find a bottle of spirits have ya????....
griz is online now
hdavis (07-19-2018)
Old 07-19-2018, 12:03 AM   #6
hdavis's Avatar
I wish, I changed out a hot water heater that you get to through a panel in a closet. No room to work, half the time I felt like I was humping the heater, the other half I felt like I was humping myself.
griz (07-19-2018)
Old 07-19-2018, 07:30 AM   #7
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 212
Op sounds like he's dealing with a double wide, not a modular like 4th Gen is talking about.
I live in a double wide, and have taken the strips off and taped the wall board in a couple of the rooms. There's no taper on the board in mine, so all your seams will probably be butt joints.
It is all glued and stapled to the studs though, I've torn some off, and it comes off in bite size pieces.
Sent from my SM-G900V using Tapatalk
mrcat is offline
The Following 3 Users Say Thank You to mrcat For This Useful Post:
artinall (07-19-2018), Fouthgeneration (07-19-2018), hdavis (07-19-2018)
Automatic Taping Tools Part Time Taper Drywall 11 01-03-2020 09:28 PM
Building with Adobe as a Cost Effective Solution for Home Construction? tierraconcepts Green Building 14 09-19-2015 05:52 PM
Historic Home Exterior Wood Refinishing-Need Projects-Nationwide bdonahue Help Wanted or Looking For Work 2 09-11-2012 06:51 PM
2x4 Basement Stud Walls On a Three Story Home WITH NO FOOTER Baltimore Carpentry 13 08-16-2012 07:02 PM
Illinois Mechanics Lien Forms and Instructions Ed the Roofer Business 4 02-23-2008 08:58 PM
