Steel Stud Framing - Drywall - Contractor Talk
Steel Stud Framing
Old 07-26-2007, 10:56 AM   #1
Wensdy's Avatar
Rewards Points: 75
Steel Stud Framing
Can anyone provide some information on how to do steel stud framing interior and exterior? or a web page? I am starting to get into this and need to acquire a crew who knows how to, but I myself need to have an idea of "how to"
Thanks.
Wensdy is offline
Old 07-26-2007, 11:53 AM   #2
kgphoto's Avatar
Trade: Residential Remodeling
Rewards Points: 250
Re: Steel Stud Framing
Contractors Bookstore has books on that subject. It is too broad to cover here. They are available online or in major cities.
kgphoto is offline
Old 07-28-2007, 11:22 AM   #3
giffrod's Avatar
Thanks.
call the carpenters local and get a crew. Best way to do it Well trained professionals are the best way to go. Do it right or don't do it at all.
giffrod is offline
Old 07-28-2007, 04:45 PM   #4
Classic Drywall's Avatar
Trade: Drywall Contractor
Are you starting to get into it as a business, if so how can you bid work if you don't even know how to do it. I feel your best bet would be go to work for someone who is doing it right now and get a feel for it before you try to bid any work. It's not hard to do, but I could not imagine bidding work with out know alot about what I was bidding
Joe....
Classic Drywall is offline
Old 07-29-2007, 12:22 PM   #5
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
W-O-W.
W-O-W.
Are you kidding me? You expect to learn how to frame commercial buildings simply by reading a book and hiring a crew?
Do you know what type of gauge goes where? What fire rating is required on a commercial partition? Do you know OSHA codes for structural exteriors? How high must the partition be AFF when acoustics are involved? How far must supports be placed when you are not going to the decking? What is the minimum length supports must be? Do you know what type of shot/pin to use on different substrates? Do you know where to float studs when you have obstacles such as HVAC, Electrical, Plumbing,etc..? What is the minimum length for headers? Can you even lay out a metal framed wall?
I can't even ask anymore questions, I am disgusted. You need to know more than just "how to", you need to KNOW. Types, specs,regulations,installation,repair,etc.. Commercial construction is a completley different world than your piece work residential. I know I sound like a di*k, but it's the truth, and you could ruin your name if you try this with the method you are planning on taking.
Take Classic's advice and go to work for someone...you will get eaten alive if you try this with books and high hopes.
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 07-29-2007, 05:08 PM   #6
Work is good's Avatar
I`m with this guys,
Anyway by a book ,but work for someone,for a while.Join forces with some more experiented guys ,until you think have the whole picture of it .
After that you are on very begining !
You must start from bottom ,that`s the way how it works.
Good luck !
Work is good is offline
Old 09-19-2007, 12:47 AM   #7
rockertansky's Avatar
Mud Man: Moving from FL. to do some commercial steel framing up in NC. What are you thought on piecework? Interior, exterior, no soffits, no lifts, PT deck and insurance?
rockertansky is offline
First time framing with steel studs nywoodwizard Remodeling 13 04-30-2014 06:16 PM
estimate/contract for steel stud framing Wensdy Drywall 5 09-19-2007 12:34 AM
framing a door in a steel stud wall River Rat Dad Framing 5 10-21-2006 06:37 AM
ideas for wood stud wall attachment to steel "I" beam? durham Construction 9 05-10-2006 05:45 PM
