Standard Precedure For Texture On A Wall? - Drywall - Contractor Talk
Old 03-13-2013, 10:39 AM   #1
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
We now I found a guy to do the texture in this place he wants me to do the drywall. This is a first for me as I ain't ever messed with texture.
Is there a best board to use? vinyl or metal corner beads, mud and tape all seams to what level? Etc etc
Thanks guys
www.bcconstructionllc.com
BCConstruction is offline
Old 03-13-2013, 11:33 AM   #2
VinylHanger's Avatar
Rewards Points: 10,278
Re: Standard Precedure For Texture On A Wall?
I would ask him. I'm beginning to like the paper edged corner beads, but don't know about longevity. He will know what level of finish he needs, but the smoother the better as any scratches, divots or edges show through the texture unless you are blowing on a crapload of mud.
Oh, and it's nice to know that I'm not the only one with an occasional rookie question around here.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
BCConstruction (03-13-2013)
Old 03-13-2013, 11:50 AM   #3
Trade: Construction
You think if I goto a level 3 will be good enough. He wants blue board so that's that bit sorted.
I got loads more rookie questions lol just ain't got them jobs yet where I have to ask them.
Old 03-13-2013, 12:07 PM   #4
I've never used the number system. I just get it smooth. Hopefully someone who knows something will be along soon.
Old 03-13-2013, 12:20 PM   #5
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
A plain splatter/orange peel is way more forgiving than a knock down... A KD will highlight any high or low spots.
Paper faced metal corners are the shiz for me... If your worried about impact in a high traffic area, I sometimes pack the back full of mud for a really solid corner.
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
Old 03-13-2013, 07:38 PM   #6
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Level 3 then skip trowel.
Metal bead (IMO) is easier to install but if you ever hit it your screwed.
Vinyl bead you'll need to put the additive in to make it stick better. Well you don't need to but it would help.
Fly me out I'll do it.....
CrpntrFrk is offline
Old 03-13-2013, 07:54 PM   #7
tenon0774's Avatar
Trade: Remodeling Carpenter
Rewards Points: 2,270
...or shoot it on with 18g. staples.
-Scott
tenon0774 is offline
The Following User Says Thank You to tenon0774 For This Useful Post:
CrpntrFrk (03-13-2013)
Old 03-13-2013, 07:59 PM   #8
CrpntrFrk's Avatar
I was never able to use staples on Vinyl bead. 18ga anyway. They always cracked it or went through. Metal I use 18ga though.
I was talking about applying mud to it. My bad on clarification.
Old 03-13-2013, 08:02 PM   #9
tenon0774's Avatar
Try to put one of the legs of the staple through the hole and hold the gun on a little bit of an angle. Works like a charm.
-Scott
Old 03-13-2013, 08:14 PM   #10
Trade: Construction
I use the spray adhesive and a normal staple gun and it hold it's in place till it sets up. Works well.
Old 03-13-2013, 09:29 PM   #11
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
Better check blue board is for plaster.
ToolNut is offline
Old 03-13-2013, 09:36 PM   #12
Mavis Leonard's Avatar
Trade: Different phrases of construction
Rewards Points: 250
pime before txtur sprayin
Use USG metle reinforceedcorners work fast with
Use vinyl corners inbathrom noruts
Mavis Leonard is offline
Old 03-14-2013, 04:39 AM   #13
Big Shoe's Avatar
Rewards Points: 1,910
Let' make this complicated. Just hang it and finish it. It's not rocket science.
Expect the Unexpected
Big Shoe is offline
Old 03-14-2013, 06:44 AM   #14
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
If you are just shooting for " good enough" then you will be fine. If you are wanting to do a light texture ( looks nicer and stays cleaner longer) youd better do a good job of finishing. Everyones definitions of the levels of finish are different but a level 3 may pass in a garage or closet according to my standards.Blueboard should be fine but is not needed unless you are in a damp environment. Its actually good board to finish over. If you go with a light or even a heavy spray knockdown I would make damm sure the seams and screws are all done right because any patchwork/repair will stick out like a sore thumb
Standard precedure for texture on a wall?-sprintphoto_bowbsm.jpg   Standard precedure for texture on a wall?-sprintphoto_bwbiqm.jpg   Standard precedure for texture on a wall?-sprintphoto_bylnb1.jpg
iDAHOchris is offline
The Following User Says Thank You to iDAHOchris For This Useful Post:
CrpntrFrk (03-14-2013)
Old 03-14-2013, 05:16 PM   #15
Thom
thom's Avatar
Rewards Points: 4,748
Many tapers would disagree, they would insist taping is way more difficult than rocket science. Just try holding a mud pan in one hand, a knife in the other, a cell phone in the other, and a beer in the other, all the while break-dancing to a radio broadcast that can be heard a mile away.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
The Following User Says Thank You to thom For This Useful Post:
Big Shoe (03-15-2013)
can any one id this wall sensor HUDSONVALLEYEXT General Discussion 8 06-15-2012 07:20 AM
Gutter Hangers in Stucco Wall go_hercules Construction 8 05-23-2012 12:37 AM
Retaining Wall Rebuild Dovetailed Landscaping 22 03-31-2012 08:02 PM
New furred 2 x 6 wall infront of concrete block wall. huntch3 Construction 11 03-27-2012 06:39 AM
Basement wall caving in JT Wood General Discussion 19 10-21-2010 06:14 PM
