-   Drywall (https://www.contractortalk.com/f49/)
-   -   Standard precedure for texture on a wall? (https://www.contractortalk.com/f49/standard-precedure-texture-wall-132162/)
BCConstruction 03-13-2013 10:39 AM
We now I found a guy to do the texture in this place he wants me to do the drywall. This is a first for me as I ain't ever messed with texture.
Is there a best board to use? vinyl or metal corner beads, mud and tape all seams to what level? Etc etc
Thanks guys
VinylHanger 03-13-2013 11:33 AM
23 Attachment(s)
I would ask him. I'm beginning to like the paper edged corner beads, but don't know about longevity. He will know what level of finish he needs, but the smoother the better as any scratches, divots or edges show through the texture unless you are blowing on a crapload of mud.
Oh, and it's nice to know that I'm not the only one with an occasional rookie question around here. :laughing:
BCConstruction 03-13-2013 11:50 AM
You think if I goto a level 3 will be good enough. He wants blue board so that's that bit sorted.
I got loads more rookie questions lol just ain't got them jobs yet where I have to ask them.
VinylHanger 03-13-2013 12:07 PM
23 Attachment(s)
I've never used the number system. I just get it smooth. Hopefully someone who knows something will be along soon.
TimelessQuality 03-13-2013 12:20 PM
A plain splatter/orange peel is way more forgiving than a knock down... A KD will highlight any high or low spots.
Paper faced metal corners are the shiz for me... If your worried about impact in a high traffic area, I sometimes pack the back full of mud for a really solid corner.
CrpntrFrk 03-13-2013 07:38 PM
Level 3 then skip trowel.
Metal bead (IMO) is easier to install but if you ever hit it your screwed.
Vinyl bead you'll need to put the additive in to make it stick better. Well you don't need to but it would help.
Fly me out I'll do it.....:laughing:
tenon0774 03-13-2013 07:54 PM
...or shoot it on with 18g. staples.
CrpntrFrk 03-13-2013 07:59 PM
I was never able to use staples on Vinyl bead. 18ga anyway. They always cracked it or went through. Metal I use 18ga though.
I was talking about applying mud to it. My bad on clarification.:thumbsup:
tenon0774 03-13-2013 08:02 PM
Try to put one of the legs of the staple through the hole and hold the gun on a little bit of an angle. Works like a charm.
:thumbsup:
BCConstruction 03-13-2013 08:14 PM
I use the spray adhesive and a normal staple gun and it hold it's in place till it sets up. Works well.
ToolNut 03-13-2013 09:29 PM
Better check blue board is for plaster.
Mavis Leonard 03-13-2013 09:36 PM
pime before txtur sprayin
Use USG metle reinforceedcorners work fast withhttp://www.sheetrocktools.com/images...hopper_pic.jpg
Use vinyl corners inbathrom noruts
Big Shoe 03-14-2013 04:39 AM
Let' make this complicated. :blink: Just hang it and finish it. It's not rocket science.
iDAHOchris 03-14-2013 06:44 AM
3 Attachment(s)
If you are just shooting for " good enough" then you will be fine. If you are wanting to do a light texture ( looks nicer and stays cleaner longer) youd better do a good job of finishing. Everyones definitions of the levels of finish are different but a level 3 may pass in a garage or closet according to my standards.Blueboard should be fine but is not needed unless you are in a damp environment. Its actually good board to finish over. If you go with a light or even a heavy spray knockdown I would make damm sure the seams and screws are all done right because any patchwork/repair will stick out like a sore thumb
thom 03-14-2013 05:16 PM
Many tapers would disagree, they would insist taping is way more difficult than rocket science. Just try holding a mud pan in one hand, a knife in the other, a cell phone in the other, and a beer in the other, all the while break-dancing to a radio broadcast that can be heard a mile away.
