Some BUTT BOARD Questions - Drywall - Contractor Talk
Old 04-05-2010, 09:59 AM   #1
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
I've used butt boards in very limited applications, and I have some questions.
Can anyone tell me the advantages of the 53" boards compared to 47" that I have seen recommended? (I like the 53" since I can lock into the parallel boards.)
Some people say 1/16" on the side strips, some say 1/8". (if your boards use side strips as opposed to being beveled) Any thoughts?
And do you screw all of one side before putting up the adjoining board? Or just a few screws on the first board, then begin working in the screws on the second board along with the first?
Do you begin your screws from one end... from the middle... or does it seem to matter?
Do you alternate screws, left right, left right? Or do you place them directly across from one another?
Is a 5" pattern sufficient?
Thanks
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 04-05-2010, 11:42 AM   #2
hardscrabble's Avatar
Trade: Residential construction
Rewards Points: 75
Re: Some BUTT BOARD Questions
Im not getting the application. What are you building with these boards? cabinets, siding? more info please.
hardscrabble is offline
Old 04-05-2010, 11:56 AM   #3
Rewards Points: 2,000
Being as this is the Drywall forum...
Willie, I generally use ¼", since
that is what I generally have around....
neolitic is offline
Old 04-05-2010, 12:02 PM   #4
Rewards Points: 75
Oops! guess im still a little green as regards to this forum. Im gettin a good laugh anyways. Thanks for the clarification
Old 04-05-2010, 01:45 PM   #5
General Contractor
Willie T's Avatar
Rewards Points: 12
So far, the biggest problem I've run into is keeping the screws from breaking the paper. About every third one cuts through the top paper.
Willie T is offline
Old 04-05-2010, 02:39 PM   #6
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
try resetting your depth guage.
jlhaslip is offline
Old 04-05-2010, 02:52 PM   #7
Project Manager HFH..
JumboJack's Avatar
Rewards Points: 2,004
Willie.Are you buying ready made butt-boards or do you make your own?
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 04-05-2010, 03:54 PM   #8
General Contractor
Willie T's Avatar
Rewards Points: 12
I've tried both.
Willie T is offline
Old 04-05-2010, 04:12 PM   #9
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 322
What are butt-boards ?
rjconstructs is offline
Old 04-05-2010, 07:46 PM   #10
General Contractor
Willie T's Avatar
Rewards Points: 12
THIS will help explain them.
Willie T is offline
The Following User Says Thank You to Willie T For This Useful Post:
sycamorebob (07-16-2012)
Old 04-12-2010, 06:05 PM   #11
Tradesman's Avatar
Trade: Drywall, painting, carpentry
Rewards Points: 77
Couple thoughts on butt boards, back blockers, or whatever you want to call them...
The first time I tried the idea, I made my own and experienced the same thing with the screws tearing through. Very frustrating.
Next time, I tried some store-bought ones (rocksplicers) and they worked MUCH better. Why? The edges were not built up as much as I had done mine. They are not even 1/16". Still pulls the board down to get the taper, but the bend is less than a fatter edge produces, so there is less tension on the screws. Also, the width of the backer is important. Rocksplicers are 6" wide; narrower backers would have the same effect as fat edge buildups.
Rocksplicers also are 54" long, which I assume is to accommodate 54" board. If you are using 48" board, you don't need a backer longer than 48"
Personally, I found that the hassle of making my own wasn't worth it. The different back blockers seem expensive by the piece, but if you keep the number of butts to a minimum, enough backers for a whole house only adds a couple cents per square foot to the cost. Well worth it for me.
Whichever method you use, they do a great job!
Tradesman is offline
The Following 2 Users Say Thank You to Tradesman For This Useful Post:
sycamorebob (07-16-2012), Willie T (04-12-2010)
Old 04-12-2010, 06:22 PM   #12
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
48" osb scrap rip 6-8", 2 paper shims slap tacked each edge... You'll never go back
I stitch'em up 4-6"...
I experimented with more..screws just rip through
Also, as to the longer length tied the adjacent board. I think that limits the action of the butt board and causes more stress/pull.
-Steve
TimelessQuality is offline
The Following 2 Users Say Thank You to TimelessQuality For This Useful Post:
Capt-Sheetrock (04-12-2010), Willie T (04-12-2010)
Old 04-12-2010, 07:21 PM   #13
Cjeff's Avatar
Trade: Renovations
I have been thinking on using them as well.
What thickness of OSB? The paper shims, we Talking just printer paper thickness or something more like posterboard?
How about making the Board 54" with posterboard strips 48" and started at one end with 6" at the other end with no strip? Then when you screw it into the sheet above (or below) it there would still be the proper depth.
If there is no real advantage then 48" is sure easier to make, or should you go under that becasue of top and bottom plates on the wall? say 45" for walls and 48" for ceiling ones?
Cjeff is offline
Old 04-12-2010, 07:47 PM   #14
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Good idea fellers I'll through her in the arsenal. Always hated those butt joints.
superseal is offline
Wood fired oven questions Joasis Masonry 30 02-27-2012 10:47 AM
Newbie Questions FlooringGuy Business 20 05-06-2010 08:12 PM
Posting Rules Update: How-To Questions Nathan General Discussion 1 09-21-2009 02:33 PM
Cork Flooring Questions.... SBI Flooring 3 12-12-2008 04:18 PM
