Skip Trowellin - Drywall - Contractor Talk
Skip Trowellin
Old 03-15-2013, 08:17 PM   #1
Mavis Leonard's Avatar
Trade: Different phrases of construction
Rewards Points: 250
Skip Trowellin
whatis skiptrowelling
Mavis Leonard is offline
Old 03-15-2013, 08:38 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,290
Re: Skip Trowellin
An old style of texture where one adds dry sand to the mud.
Edge of a broad knife is dipped in the bread pan and then spread on the wall.
I learned to do it with a vertical pass then come back with a horizontal pass.
VERY effective at hiding defects.
One can vary the amount of sand & how wet the mud is to obtain different results.
My preferred way of texturing, because I like the look.
griz is online now
Big Shoe (03-16-2013)
Old 03-15-2013, 08:39 PM   #3
Brownchickenbrowncow
elementbldrs's Avatar
Trade: General Building
Rewards Points: 1,376
Re: Skip Trowellin
For us its 00 sand in the mud with an 18" trowel l, leaves a very random knock down pattern of 1/4" to 3" flat spots. Very variegated.
Phil
elementbldrs is offline
Old 03-15-2013, 08:41 PM   #4
Re: Skip Trowellin
Funny you were the one to answer first griz. In the day it was the texture of choice in Cali.
Phil
The Following User Says Thank You to elementbldrs For This Useful Post:
griz (03-15-2013)
Old 03-15-2013, 11:39 PM   #5
JR Shepstone's Avatar
Rewards Points: 1,552
Re: Skip Trowellin
Hopefully this won't derail the thread...
Now that we know what it is, how would one go about removing it if someone so desired?
Is it even possible? I would think sanding wouldn't be feasible as it would just rip the paper apart.
Only drink 23, that way they won't have a case against you.
JR Shepstone is offline
Old 03-15-2013, 11:42 PM   #6
The Sheriff
Jaws's Avatar
Rewards Points: 4,850
Re: Skip Trowellin
Sand where needed, skim float, sand, skim float and re texture.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
The Following 2 Users Say Thank You to Jaws For This Useful Post:
griz (03-15-2013), JR Shepstone (03-15-2013)
Old 03-15-2013, 11:46 PM   #7
Re: Skip Trowellin
Thanks! If I ever have to do it, I'll let you know how it turns out.
The Following User Says Thank You to JR Shepstone For This Useful Post:
Jaws (03-15-2013)
Old 03-16-2013, 12:01 AM   #8
Re: Skip Trowellin
Skim it one direction, next day skim it 90 degrees. Boom. Done. Magic.
Phil
Old 03-16-2013, 01:11 AM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,248
Re: Skip Trowellin
I completely retextured my whole house with a skip trowel, however I don't use sand. I like the skip look without the grit. If you have an existing texture like a knockdown or splatter then you will first have to putty coat the walls. Anyway that's what we call it out here in Cali. Also it's still the preferred texture for high end homes here in Cali. Some guys call it an old world texture.
Calidecks is offline
Old 03-16-2013, 02:15 AM   #10
VinylHanger's Avatar
Rewards Points: 10,270
Re: Skip Trowellin
I've done skip trowel without the sand. I like the look, but blow on is quicker. Quicker is cheaper people want blow on.
Is the sand what makes that stuff cut your arms when you rub against it, or is that plaster?
VinylHanger is offline
Old 03-16-2013, 05:05 AM   #11
Big Shoe's Avatar
Rewards Points: 1,910
Re: Skip Trowellin
California thing, just like all that round bead.
It was used here in the 80's, not so much anymore. They want to keep it on some renovations I do.
We refer to it as ''hand'' texture here. Stucco guys do ''skip'' troweling.
Florida thing.
Expect the Unexpected
Big Shoe is offline
The Following 2 Users Say Thank You to Big Shoe For This Useful Post:
JWilliams (03-21-2013), MasterBuilt (03-16-2013)
Old 03-16-2013, 07:08 PM   #12
pibe's Avatar
Trade: drywall
Rewards Points: 93
Re: Skip Trowellin
Maybe sir mixalot will post on here. Ive seen quite a lot of skip trowels with really huge differences. And i gotta say after seeing some pics of his work, it really looks awesome. (think i saw a pic somewhere of a really cool lookin skip trowel tray ceiling he did with ropelight around it, dont recall where)
pibe is offline
Skip Trowel Help Ralf Miranda Painting & Finish Work Picture Post 1 06-10-2011 08:50 PM
Skip the Backer Board? kcremodeling Flooring 38 11-20-2009 06:06 PM
stucco skip troweling ? cj5orion General Discussion 2 08-11-2009 06:27 PM
Skip tracing leaks using dye Walason Roofing 0 03-30-2009 12:44 PM
What is skip trowel cedy Drywall 43 01-27-2008 01:47 PM
