Skim Coat Plaster Help - Drywall - Contractor Talk
Old 04-06-2019, 11:41 PM   #1
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,252
need to repair an interior skim coat plaster wall . this house got what was called 'skim coat plaster ' on drywall/sheetrock walls . 1/8" skim coat .so i have to repair a small section that was water damaged . 1 ft wide 4'feet long . I am trying to decide between hot mud which I am familiar with and plaster which is gritty and i expect harder to smooth out .
JFM constr is offline
Old 04-06-2019, 11:55 PM   #2
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,332
Re: Skim Coat Plaster Help
I vote for hot mud.
Mike.
_______________
Calidecks is online now
Old 04-07-2019, 12:57 AM   #3
hdavis's Avatar
Rewards Points: 2,582
Durabond. If you need a harder surface, add acrylic fortifier.
hdavis is online now
finisher65 (04-07-2019), rrk (04-08-2019)
Old 04-07-2019, 08:38 AM   #4
JFM constr's Avatar
thanks ,my 1st choice also.
Old 04-08-2019, 12:28 AM   #5
HarmonyL's Avatar
Trade: Drywall/plaster
I do a lot of plaster repairs as well as drywall. First off, be mindful that you keep your area at a 1x4’ water damaged are. It’s hard to find a stoping point.
Usually working with 1” depth in plaster.
Also,depends on the lath. If wood;backing can be applied, then drywall, then hot mud. That’s one way.
You can also put the same material back.
Use metal lath and a box of stucco patch mix. Drys in 20min. Get textured grit for you project. Also apply the bonding agent. I usually buy it by the gallon and apply separate. I like it as tacky as possible to adhere to surface much better.
Depending on texture. Wet sanding may do or a float will also work.
Just a few ways to skim a cat 😎👍
HarmonyL is offline
The Following User Says Thank You to HarmonyL For This Useful Post:
Calidecks (04-08-2019)
Old 04-08-2019, 08:08 AM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,085
That sounds like rock lathe, which are 16" x 48" (3/4" thick, I think) sheetrock-type boards onto studs, then skimmed with plaster. We have that in our post WWII, 1947 home.
I use Durabond, (nothing proud, no sanding) then easy sand or whatever to finish it up.
MarkJames is offline
Old 08-28-2019, 12:24 PM   #7
rounde683's Avatar
Trade: Electrician
Rewards Points: 32
For a silk finish, use a wet sponge.
Removed by staff
rounde683 is offline
The Following User Says Thank You to rounde683 For This Useful Post:
hdavis (08-28-2019)
Full hard coat plaster J.C. Drywall 15 05-10-2017 04:00 PM
What ways do you guys skim coat? DuFast Drywall 106 04-13-2013 07:24 AM
Concrete floor skim coat question CJKarl Masonry 12 07-31-2012 09:58 PM
complete skim of plaster . 3 coats oldrivers Drywall Picture Post 8 05-12-2012 08:51 AM
Spray skim coat Burpaz Painting Painting & Finish Work 2 09-12-2009 09:12 PM
