Skim Coat Over Wall Over Orange Peel Just Finished With Gloss Paint - Drywall - Contractor Talk
Old 07-19-2011, 09:41 AM   #1
alans's Avatar
Trade: General
Hello
What we are facing.....walls with a poorly applied orange peel finish. The finish was primed and then sprayed with a eggshell paint.
Client wants a smooth finish.
Am I correct with the following:
Rough screen surface, use tape compound mixed with bonding agent, trowel on, sand and prime.
Do you agree with those steps?
Alans
[email protected]
alans is offline
Old 07-19-2011, 09:56 AM   #2
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
Re: Skim Coat Over Wall Over Orange Peel Just Finished With Gloss Paint
Hello Alan,
Ya need to go to the introduction page first before posting questions
Anderson is offline
Old 07-19-2011, 10:51 AM   #3
Anti-wingnut's Avatar
Rewards Points: 3,430
What kind of general are you? That is a pretty basic question, kind of like you've never been around drywall mud before, except what you read about
Anti-wingnut is offline
Old 07-19-2011, 10:56 AM   #4
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Originally Posted by alans View Post
Hello
Alans
[email protected]
No No
start over.
skyhook is offline
Old 07-22-2011, 03:32 AM   #5
Gillegit's Avatar
Trade: General
There is a fast drying compound called HOT MUD, USG or BEADEX offer 40-45 minute dry times. I use USG 45. Mix the HOT MUD in a 5 gallon bucket using a drill and paddle or just mix it one pan at a time. Start coating the walls using a 10" knife and don't worry about leaving ridges. You can scrape them off with a 6" knife after it dries. When all of the walls are coated once, go clean your tools and let it dry a few minutes. Now open the box of HAMILTONS or BEADEX TOPPING COMPOUND and fill your mud pan (one pan at a time), and begin the process again, scrape off the high ridges with your 6' knife. I recommend to use a PVA primer after sanding the TOPPING COMPOUND. It will help you see imperfections. That should help, if you choose this method.
You Need
Hamiltons or Beadex Topping Compound
(you can use ALL-PURPOSE, but it will require more coats)
USG 45 (hot mud)
Pan
10" knife
6" knife
Something to stand on
Gillegit is offline
The Following User Says Thank You to Gillegit For This Useful Post:
alans (07-25-2011)
Old 07-29-2011, 09:00 PM   #6
Frankawitz's Avatar
Gill,
The only thing you forgot to mention is he needs to sand the finish of the paint, order wise the mud you told him to apply will bubble up the minute he puts primer or paint to the walls
Frankawitz is offline
The Following User Says Thank You to Frankawitz For This Useful Post:
alans (07-29-2011)
Old 07-29-2011, 09:13 PM   #7
alans's Avatar
Trade: General
thanks....great idea!!
alans is offline
Old 07-29-2011, 09:19 PM   #8
alans's Avatar
Trade: General
if the question was so basic, you would expect one simple reply......why are there different opinions on such a basic question?
Please have an open mind......we are all in a learning process every day.
alans is offline
Old 07-29-2011, 09:20 PM   #9
alans's Avatar
Trade: General
Hello
Alans
[email protected]
Thanks......great idea and a simple solution.
alans is offline
Old 07-30-2011, 12:22 AM   #10
Ralf Miranda's Avatar
Trade: Drywall and Texture
I recommend that you apply regular topping instead of hot mud because the quality of your finish will be much better. Apply at least 3 coats for a smooth finish sand after each application. I am also smoothing a house with orange peel texture. I used Sheetrock Lightweight Topping Plus 3 because its much easier to sand. Your third application of mud should be a skim coat... apply mud and take it all off. Use 150 grit sandpaper or a finer grit for finish sanding. Goodluck!
Ralf Miranda is offline
The Following User Says Thank You to Ralf Miranda For This Useful Post:
alans (07-30-2011)
Old 08-02-2011, 01:58 AM   #11
alans's Avatar
Trade: General
Great thought......I like it!
Thanks, Alan
alans is offline
Old 08-02-2011, 08:26 AM   #12
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 268
First off how big is the wall? Second, Because this is so basic, you as a General should have knowledge of this basic step...Do you have the option of re-skinning the wall?
,how much time do you have to complete?
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 08-03-2011, 06:09 PM   #13
D.Foster's Avatar
Trade: Carpentry & Remodeling
Alan, you qouted and then thanked yourself up there....
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
orange peel finish scottstef Drywall 4 07-22-2011 03:43 AM
Some advice on selecting the right finish michaelsaam Painting & Finish Work 0 02-28-2011 08:50 PM
Semi Gloss for wall paint?? bmxrdr67 Painting & Finish Work 13 04-20-2010 11:04 PM
Skim coat with setting-type compound? UALocal1Plumber Drywall 13 02-21-2010 06:22 PM
