Seams Intersect - Drywall - Contractor Talk
Seams Intersect
Old 06-26-2006, 08:39 AM   #1
JimmieC's Avatar
Seams Intersect
I have a wall with seams running horizontially and vertically. How are these to be taped and finished? The area I am most concerned with are where they intersect. How is that section done to avoid un-necessary buildup. Thanks, Jim.
JimmieC is offline
Old 06-26-2006, 09:29 AM   #2
Custom Builder
Glasshousebltr's Avatar
Rewards Points: 2,000
Re: Seams Intersect
With a question like that Jim......maybe your over your head. Sometimes we just have to stay out of the deep end of the pool.
Bob
Bob
Glasshousebltr is offline
Old 06-27-2006, 08:24 PM   #3
andrewtlocke's Avatar
Rewards Points: 25
Re: Seams Intersect
Quick answer: hire a taper. It'll be better than how I'm thinking your wall will turn out if you try to do it yourself. No offense intended, but Bob's right, if you're asking a fundamental taping question like this, you should not attempt to finish this wall.
andrewtlocke is offline
Old 06-28-2006, 05:33 PM   #4
Mudpuppy's Avatar
Re: Seams Intersect
if youre asking a question like that than as the others have hinted i assume you are not a taper, if thats so(I really hope it is) then id guess you are not in a piecemeal situation where youre being pushed for time. coat your flats first always(10" or 12"), wiat til it dries then coat your butts, those are the verticals(12" or 14") hope that helps some.
Mudpuppy is offline
ripped off? Taurus Flooring Flooring 20 08-02-2007 12:34 AM
seams bill6078 Drywall 17 04-11-2006 12:25 AM
