Screwing Drywall Around Tub Enclosures - Drywall - Contractor Talk
Old 06-10-2017, 06:10 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
Have always been weary of driving nails or screws around the tub tab.
Even when pre-drilling. Having seen occasions where it split.
Is pre-drilling fine thread screws the best we can do?
On the elevated areas, it's easier to avoid the tab altogether by bumping the screw off the molding and onto the stud. Sides have to be done though and you're not always given 1/2 stud width...
artinall is offline
Old 06-10-2017, 06:16 AM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,004
Re: Screwing Drywall Around Tub Enclosures
Drywall shouldn't overlap the tab. Stop right above it on top and next to it on the sides. My drywallers use durabond or 90 minute ez sand to fill in the gap.
Big Johnson is offline
Old 06-10-2017, 06:23 AM   #3
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Did you mean "leery"?
No fastener within 2" of tub flange. Therefore, no issue.
SmallTownGuy is offline
Old 06-10-2017, 06:24 AM   #4
artinall's Avatar
Don't follow you. Drywall has to overlap the nailer tab (flange; edited later)...
Fill in what gap? you referring to the height difference between the nailer tab and the stud?
artinall is offline
Old 06-10-2017, 06:25 AM   #5
MarkJames's Avatar
Rewards Points: 18,803
What's a tub tab? The flange? I wouldn't fill the gap with anything that wicks water. (I don't use drywall, either).
Or are you talking about the top and sides of a surround?
(Nail to stud...then drywall screws outside the "tab", not through it)
MarkJames is online now
Old 06-10-2017, 06:26 AM   #6
artinall's Avatar
- If no fastener within 2" then how do you attach drywall at the sides?
Mine's not getting tiled. Painted green/purpleboard.
Correction (sorry) this is the shower flange (wall kit) . All the way around including the base tub unit.
BTW: I guess I did mean a little bit of leery and weary both!
artinall is offline
Old 06-10-2017, 06:28 AM   #7
John the Builder
doesn't matter. Sounds like s*** tho. What do I know...
Old 06-10-2017, 06:49 AM   #8
John the Builder
Then I have no clue WTH you are talking about. I posted a pic - if it doesn't relate - them maybe you got to post one so a dufus like me can see the situation better.
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Big Johnson (06-10-2017)
Old 06-10-2017, 06:52 AM   #9
You stop the drywall before you get to the flange. Then fill in the area between the shower surround and the drywall. Durabond with paint and primer will hold up no worse than drywall with paint and primer.
My drywallers use mesh tape.
Big Shoe (06-10-2017)
Old 06-10-2017, 06:54 AM   #10
MarkJames's Avatar
He's talking about the enclosure kits, like fiberglass or gel coat, etc. His problem is where the alcove isn't deep enough, so a sliver of wallboard is needed outside the tub...and how to apply.
SmallTownGuy (06-10-2017)
Old 06-10-2017, 06:57 AM   #11
MarkJames's Avatar
I run it over the lip and fill with caulk.
Old 06-10-2017, 07:45 AM   #12
artinall's Avatar
Believe shower bead could be of help, which I have not seen before http://www.trim-tex.com/products/ove...ds/shower-bead
artinall is offline
Old 06-10-2017, 08:38 AM   #13
hdavis's Avatar
Rewards Points: 1,022
Nobody glues a strip and corner bead on? I'll either do that, or do the whole strip as a fill, depending.
If I need a nailer to screw to, I'll put one in.
hdavis is online now
MarkJames (06-10-2017), SmallTownGuy (06-10-2017)
Old 06-10-2017, 08:43 AM   #14
MarkJames's Avatar
Doh! I've glued 'em.
Old 06-10-2017, 08:46 AM   #15
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,498
That looks like it might work pretty good, might give it a try on my own bathroom remodel.
Randy Bush is online now
Old 06-10-2017, 09:08 AM   #16
John the Builder
Ah. That would work for me. Seems ideally suited...
Screwing Drywall Around Tub Enclosures-f28fa24580a63783fc3b9607eac427af_f997.jpg
Old 06-10-2017, 10:19 AM   #17
slowsol's Avatar
Rewards Points: 2,248
I'm in the "but to the flange and durabond in the gap" club.
-John
slowsol is offline
Old 06-10-2017, 10:25 AM   #18
avenge's Avatar
Rewards Points: 296
Tub tab, LOL. I haven't torn one out where drywall was screwed through the flange, it's always been over the flange and caulked. If the walls are open you simply add a stud if one isn't close enough.
I have never installed a shower enclosure, pretty sure that's a 70's thing or rebath.
avenge is offline
Old 06-10-2017, 10:33 AM   #19
AustinDB's Avatar
Rewards Points: 1,520
you will split that surround kit if you're using a bugle head (sheetrock) screw. Use a self-drilling lathe/truss head screw.
I use to also hollow out the back of the sheetrock that sat over those screws to get it to lay flat. You can use sheetrock screws for the sheetrock over tub surround flange connection b/c the head is sinking into the sheetrock.
AustinDB is offline
Old 06-10-2017, 02:10 PM   #20
ktmrider's Avatar
Trade: carpentry
I shim around tub flange so It sits flat and hold screws back from the flange, like others have said use the trim tex shower bead it gives it a clean look
ktmrider is offline
The Following 2 Users Say Thank You to ktmrider For This Useful Post:
Texas Wax (06-10-2017), Tom M (06-10-2017)
drywall over drywall nwksremodeler Drywall 11 01-14-2014 09:57 PM
Zinsser 123 for new drywall? renov8r Painting & Finish Work 11 09-10-2013 07:35 AM
Priming & Painting drywall Repairs, not new drywall mcgyver79 Painting & Finish Work 21 04-23-2013 03:47 PM
Drywall GettingBy General Discussion 3 06-16-2011 12:58 PM
Drywall sagging on 24" o.c. ECinc Drywall 20 10-30-2010 08:31 PM
