Rocking Over Dens-pac Cellulose In Walls When Done With Mesh - Drywall - Contractor Talk
Old 12-16-2010, 11:38 AM   #1
UpNorth's Avatar
Trade: Engineer & Ret. GC
How does it go with you on jobs like this? What does the insulation contractor do to minimize the bulge-out, so you are not fighting it when laying on boards?
UpNorth is offline
Old 12-16-2010, 03:38 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,706
Re: Rocking Over Dens-pac Cellulose In Walls When Done With Mesh
I have used dense packed fiberglass numerous times.
I have yet to have an issue with the drywall bulging when going over it.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 12-16-2010, 04:07 PM   #3
SDC's Avatar
Rewards Points: 256
If it is bulging out...it is overfilled....
I would call your insulator and ask him what he is going to do about it.
David Cookman
Twitter
SDC is offline
The Following 3 Users Say Thank You to SDC For This Useful Post:
Big Shoe (12-17-2010), CookeCarpentry (12-16-2010), Muddauber (12-16-2010)
Old 12-17-2010, 05:54 AM   #4
Big Shoe's Avatar
Rewards Points: 2,066
''Noboby else is complaining''
I've hung my fare share of board on ''overstuffed''walls and ceilings. Board can push it in to some point. But if its popping screws it has to be addressed!
Make them come back and fix it!
How about plumbers kickplates at the base of the wall going over pipes already 1/2'' out of the wall?????
Make them come back and fix it. Riiiiiiiiight
UpNorth, what do you mean by ''done with mesh''. Thanks
Big Shoe is offline
Old 12-17-2010, 06:55 AM   #5
Joasis's Avatar
Rewards Points: 604
We do this type of wall fill frequently, and have no issues with the rock not laying flat. The key is obviously to not overfill to an extreme, and cellulose will compress quite a bit, no problem.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is online now
Old 12-17-2010, 07:10 AM   #6
Marson's Avatar
Trade: Carpenter/contractor
The amount of bulge out in your pic looks acceptable to me. In a first class insulation job, the insulation should make good contact with the rock, and that's going to require pushing in the bulge a bit. Using 5/8's helps a lot. The real answer might be to charge a bit more for hanging over dense pack.
Marson is offline
Old 12-17-2010, 06:08 PM   #7
Muddauber's Avatar
Trade: drywall
Rewards Points: 250
The real answer is to charge a lot more to cut slits in the mesh and pull out hands full of insulation, which I have had to do on some jobs.
Muddauber is offline
Old 12-17-2010, 07:26 PM   #8
kj6887's Avatar
Trade: remodeling now but used to hang rock
Rewards Points: 27
Hate rocking on this stuff !!!! really hate it in kitchens when the cabinet guys put the uppers in and they suck everything tight ( not saying that they shouldnt ) and that pops a sh!t ton of screws .
kj6887 is offline
Old 01-06-2011, 09:32 PM   #9
d's's Avatar
Trade: Drywall
Rewards Points: 75
Try setting the depth on the screw gun shallower so the screws don't pop. Do the whole house, then double up with a tighter depth setting beside each one to draw it tight, then hand tighten the first pass of screws flush. Twice the screwing but ensures no popping - factor it into your price next time.
d's is offline
1/4" Hardiboard on 8" center framed walls. bob_cntrctr General Discussion 6 11-06-2009 03:16 PM
Stone foundation walls insulation gefstra Remodeling 1 11-05-2009 02:42 PM
Why Build ICF monsterconstruc Green Building 32 09-28-2008 10:48 PM
cellulose vs fiberglass insulation Home Serve Insulation 3 09-20-2008 06:48 AM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
