Repairing Pops N' Joints Under Paint - Drywall - Contractor Talk
Old 05-10-2010, 05:23 PM   #1
D.Foster's Avatar
Trade: Carpentry & Remodeling
Got a remodel job with alot of nail pops and bad joint finishing under eggshell paint. Any suggestions on a process for repairing these,other than sanding through paint n' primer....
The nail pops i think i got....bang n' fill...Right? The field is all screwed, nails poppin at the joints n' corners.
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 05-10-2010, 05:38 PM   #2
genecarp's Avatar
Rewards Points: 2,000
Re: Repairing Pops N' Joints Under Paint
If the budget will bear it, reprime the whole mess, light it up, rescrew as needed, spackle, spot prime , repaint, GMOD
genecarp is offline
Old 05-10-2010, 06:59 PM   #3
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
I have done alot of warranty work in the past, so I'll chime in...
What makes you think the nail pops won't come back? IMO if they didn't hold the first time, there is always the possibility they will back out again. I always pull them out, sink in a new one in that area, and skim.
I would retape any cracked joints, they always seem to come back if you don't.
Egg shell doesn't touch up well, so you can plan on painting from corner to corner on any effected walls.
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 05-10-2010, 07:15 PM   #4
D.Foster's Avatar
So a new nail wont drop?? Or did you mean a screw? Or a ring shank?
D.Foster is offline
Old 05-10-2010, 07:28 PM   #5
CCCo.'s Avatar
I personally would stick a screw back in, but most of the nails I've pulled weren't grabbing good, or placed good at all. I really don't think it matters what you use as a replacement, but be good and sure it hits home, and is holding.
CCCo. is offline
Old 05-11-2010, 08:26 PM   #6
Big Shoe's Avatar
Rewards Points: 2,222
Add new screws .......cut out nail pops/blisters...tap in old nails and mud up. If tape is solid, then float out the bad joints. then reprime and paint.
As always ...Good luck!
Big Shoe is offline
The Following 2 Users Say Thank You to Big Shoe For This Useful Post:
Capt-Sheetrock (05-11-2010), D.Foster (05-12-2010)
Old 05-11-2010, 09:56 PM   #7
frankster's Avatar
Rewards Points: 75
Big Shoe is right on track with bad tape joints. Float em out with new mud, texture if required, prime and repaint. If tape joint is cracked or loose then its a redo on effected joint area.
Nail pops are way to common. I did warrent repair work for quite some time. Nails are usally used to hold up the rock untill it can be screwed down. Mostly on the ceiling. If its where the wall meets the ceiling, take a nail punch and drive the nail all the way through. the wall rock should be butted against ceiling rock so replacing is not necessary. Clean loose paint and such around hole, fill with lightweight spackle, and wipe area around hole with damp cloth. Its easier to hide a pencil eraser size hole verses a quarter or 50cent size area because you left filler all around the hole to dry.
If its a screw, use a screw driver and tighten the screw and apply same process above with filler.
If you keep your repair areas nice and small you can most of the time get away with just useing a artist brush and dab paint on repaired area. I try to keep the paint thick as possible when I do this. If its a orange peel textured wall you can pull the paint with the artist brush and create a texture with the paint.
Hope this helps
frankster is offline
The Following User Says Thank You to frankster For This Useful Post:
Old 05-18-2010, 07:35 AM   #8
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 268
We do a lot of insurance work, and customers want the walls touched up, with the walls already being painted, we re-screw in the pop screws, or hammer in the nails, and coat with pro set 30..this will allow your other coats of mud to grip to the wall...works also with joints etc...
J
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Tags
nail pop repairs , settling crack repairs
Paint Shaver vs Infrared Paint Removers Goochie Painting & Finish Work 12 09-11-2012 04:05 PM
Paint sprayer yields "orange peel" finish BRUCE R Painting & Finish Work 5 05-01-2010 04:42 PM
Best Paint for a Historic Home fatal_degree Painting & Finish Work 15 04-23-2010 08:09 AM
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 06:59 AM
BEHR Paint Problem Please advise api11296 Painting & Finish Work 39 12-19-2008 06:19 AM
