Remove Or Cover Popcorn Ceilings? - Drywall - Contractor Talk
Old 12-27-2016, 05:03 PM   #1
MayflyCarpentry's Avatar
Trade: carpentry
Rewards Points: 12
Hello,
I am working on a drywall bid for a remodel. The GC would like for me to include removal of popcorn ceilings in all three bedrooms, both bathrooms and the hallway and re-texturing the ceilings. Approximately 600 square feet. The home is definitely older than 1980, though the GC does not know exactly when it was built. Our closest asbestos testing facility is over an hour away and closed until after the new year, and the GC is wanting the work to start next week.
So my question is, might it be cheaper and less obstructive to just lay new drywall over the popcorn ceilings and basically start over? My only issue there would be where the hallway meets the living room the new drywall ceilings would be 1/2 inch lower than the old. Does anyone have advice on if this might be easier and cheaper than testing and then removing the old popcorn texture? And if so, what would you suggest for the transition?
MayflyCarpentry is offline
The Following User Says Thank You to MayflyCarpentry For This Useful Post:
Stunt Carpenter (12-27-2016)
Old 12-27-2016, 05:20 PM   #2
Head sawdust creator
Bummie's Avatar
Trade: Jack of All.... Master of a Couple
Rewards Points: 1,038
Re: Remove Or Cover Popcorn Ceilings?
If older than 1980 good chance there is asbestos.
As far as going over old ceiling it would not be as easy as it sounds plus you will be disturbing the old textue, making dust, which is not good if it does have asbestos in it.
The transition would be the least of your worries. Milcore or cove would fix that problem.
"Whether you think you can or think you can't.... you are right!!!" Henry Ford
Bummie is offline
The Following User Says Thank You to Bummie For This Useful Post:
KAP (12-29-2016)
Old 12-27-2016, 05:32 PM   #3
Trade: carpentry
Rewards Points: 12
So you'd suggest having it removed? Am i correct that I am not allowed to have my crew do it even if we take the right measures?
Old 12-27-2016, 05:39 PM   #4
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,477
You could always skim coat it. I skim coat over painted popcorn ceiling texture all the time. Usually takes two rounds of skimming.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
Bummie (12-27-2016), hdavis (12-27-2016)
Old 12-27-2016, 08:36 PM   #5
VinylHanger's Avatar
Rewards Points: 12,896
Does it stay up? That crap likes to fallnaff if you sneeze on it.
VinylHanger is online now
Old 12-27-2016, 09:13 PM   #6
Yes it stays up. It's the old school vermiculite popcorn texture that is hard as a rock and been painted half a dozen times. This popcorn doesn't come off even if you want it to.
-Paul
TextureMaster.com
hdavis (12-27-2016), VinylHanger (12-27-2016)
Old 12-27-2016, 10:36 PM   #7
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
That's what she said
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 12-28-2016, 04:48 PM   #8
martelh1984's Avatar
Trade: hvac
Rewards Points: 2
Eat the popcorn ceiling
Sent from my SM-G360T1 using Tapatalk
martelh1984 is offline
Old 12-28-2016, 07:28 PM   #9
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,888
Interesting first post.
Sent from my SGH-I337M using Tapatalk
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following User Says Thank You to heavy_d For This Useful Post:
Sir Mixalot (12-28-2016)
Old 12-28-2016, 08:26 PM   #10
-Paul
TextureMaster.com
Old 12-28-2016, 08:35 PM   #11
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
heheheheheh
SmallTownGuy is offline
Old 12-28-2016, 10:54 PM   #12
avenge's Avatar
Rewards Points: 298
I think someone is sniffing his refrigerant.
avenge is online now
Old 12-29-2016, 07:45 AM   #13
builditguy's Avatar
Rewards Points: 2,072
I would remove the popcorn. Usually it comes off pretty easy. If it has years of paint, that does make it harder, but its not too bad.
As far as the asbestos, I'm guessing the GC wants to avoid that completely. You may have to stand your ground and take a chance on loosing that job.
builditguy is offline
Old 12-29-2016, 10:09 AM   #14
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
I scraped a ceiling for an entire day before giving up and tearing it all out and installing new. It can be nearly impossible to scrape off!!
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 12-30-2016, 07:00 AM   #15
builditguy's Avatar
Some are tougher than others. Usually I spray them down with hot water. Wait a while and do it again. Then go at it with a drywall knife. Usually it falls right off. 95% of the time, extremely easy. Just messy.
The last one I did, was not so easy. I assume it had alot of paint on it and it was stuck like crazy. So they are out there.
Tags
popcorn ceiling , popcorn removal , skim coat , skim coating
Hot Tub Cover Help jb4211 General Discussion 28 01-11-2012 08:19 AM
Has anyone read code book cover to cover? mehtwo General Discussion 31 12-22-2010 11:23 PM
Popcorn Removed now Primer ? We Fix Houses Painting & Finish Work 15 10-13-2009 05:02 PM
cottage cheese remove or cover it? bright star Drywall 7 10-04-2006 07:22 PM
