Question About Prepping Kitchen Walls. - Drywall - Contractor Talk
Old 02-10-2015, 03:05 AM   #1
VinylHanger's Avatar
Rewards Points: 12,994
I am working on a small kitchen gig this week. Filling in a blank area from an old drop cieling, rocking the lid, etc. Basic stuff.
My question is about the existing walls. They had wallpaper in most of the areas, so I will be working to get the rest of the backing of in the next day or so.
The part I don't know what to do with is where they had a splash panel glued to the walls. It is still a bit rubbery. Pulling the rock off isn't really a plan unless it is totally needed.
I had planned to lay on some Gripper primer and then skim the worst areas and sand it down to make the wall as clean and fresh of a surface as possible. Then we are doing a basic knockdown.
Will Gripper work over the old glue? What is the standard procedure in this instance?
VinylHanger is online now
Old 02-10-2015, 03:28 AM   #2
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: Question About Prepping Kitchen Walls.
It's probably contact cement. Did you try acetone and a scraper?
I think if you knock the high spots off, clean it and then prime with oil primer, you should be ok to skim it.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 02-10-2015, 10:08 AM   #3
KAP's Avatar
Trade: Custom
Rewards Points: 39,770
Why isn't replacing that piece an option? You're skim coating anyway...
You're overthinking it IMHO...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
TNTRenovate (02-10-2015)
Old 02-10-2015, 10:13 AM   #4
Tom M's Avatar
Rewards Points: 11,286
The second those boards come down your looking at upgrading wiring and insulation so maybe he doesnt want to go there.....
Plus a permit will then be required, we all know everyone run out to the BD to get one right?
Tom M is online now
greg24k (02-10-2015)
Old 02-10-2015, 10:45 AM   #5
It is over cardecking, so maybe I will just pull that section. May be easier in the long run.
Yep, as usual, over thinking things. Pulling it is definetly easier than cleaning the goop off of it. It'll turn out better in the end.
The Following User Says Thank You to VinylHanger For This Useful Post:
Walraven (02-10-2015)
Old 02-10-2015, 11:44 AM   #6
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
1. scrap and some kills over the grease or cut that spot out.
2.add screws where needed ....like that seam
3. 36'' rolls of fibafuse will fix that so easy
dont work hard...work smart
icerock drywall is offline
Old 02-10-2015, 11:51 AM   #7
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
I'd pull it. Would definitely be less work in the end.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
blacktop (02-10-2015)
Old 02-10-2015, 12:09 PM   #8
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Cut it out and replace. Your going to save time. As mentioned above fiberfuse is a great product. You will spend more time cleaning rocks out of your mud etc. Just because its knockdown don't mean the wall does not have to be done right. Your right about the gripper, it's a great product.
kingcarpenter is offline
Old 02-10-2015, 01:23 PM   #9
KAP's Avatar
Trade: Custom
I am not aware of any code requirement that says that when you do a patch, which is all this is, you have to permit and upgrade the insulation, wiring, etc...
KAP is offline
Old 02-10-2015, 01:34 PM   #10
Business Owner
JD@SBS's Avatar
Trade: Schluter Systems ASD, General Bathroom Remodeling
Rewards Points: 330
Definitely pull it
JD
JD@SBS is offline
The Following User Says Thank You to [email protected] For This Useful Post:
Old 02-10-2015, 02:42 PM   #11
Trade: drywaller
Rewards Points: 930
I could fuse it all in one hr in a 12X12 room ...2nd coat would take less time and then texture done in one day with one person ...so easy
Old 02-10-2015, 08:02 PM   #12
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 322
Tear out ! Or invest in a magic wand !
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 02-10-2015, 08:13 PM   #13
Drywall Slave
blacktop's Avatar
Rewards Points: 322
Really though VH ... That's just too much . I see tear out !
What you have there is near impossible to get right . It would take more time and material to patch that up then to just tear it out and go fresh .
imo! But I've seen worse !! I'll post pics later this week !!
blacktop is offline
Old 02-10-2015, 09:49 PM   #14
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Tearing it out would be easier but we would scrape it, then prime it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it, then skim it,
Then tear it out and do it right. Seems to be the prefferred method for my guys....
ohiohomedoctor is offline
The Following 3 Users Say Thank You to ohiohomedoctor For This Useful Post:
EthanB (02-10-2015), summithomeinc (02-14-2015), TNTRenovate (02-10-2015)
Old 02-10-2015, 10:01 PM   #15
Hair Splitter
Trade: General
Been meaning to say this, but it's good to have you back posting regularly!
The Following 4 Users Say Thank You to TNTRenovate For This Useful Post:
ohiohomedoctor (02-10-2015), overanalyze (02-10-2015), Spencer (02-11-2015), Xtrememtnbiker (02-10-2015)
Old 02-10-2015, 10:31 PM   #16
I ended up cutting the bad spots out. The area that looks like grease is just a a spot that got hot behind the old wall oven. The rest of it is in pretty decent shape. It was all protected by wallpaper. I have a few bits of paper and backing to get off, then it will be ready to be finished up once the electrician finishes making more holes.
m1911 (02-10-2015)
Old 02-10-2015, 11:11 PM   #17
Talking Head
EthanB's Avatar
Rewards Points: 438
You need to teach your guys the other way of doing it, Matt. You scrape it and prime it then skim it with about 1/4 of mud then sand it, then sand it, then sand it...
You get the idea.
Planer.....
EthanB is offline
Old 02-10-2015, 11:39 PM   #18
Trade: drywaller
Rewards Points: 930
You get the idea.
if you sand that much you need to put your tools down.
if you skim coat there is just a little scrap I would keep my festool home...no need to sand that much
Old 02-11-2015, 12:17 AM   #19
Trade: drywaller
Rewards Points: 930
o my god...holes ...new you need to rip it all out
Old 02-11-2015, 01:37 AM   #20
Nah, I'm good. I just checked out Youtube.
What is the max distance for load baring walls in a residence? kgcaddesign Architecture & Design 13 06-03-2012 02:35 PM
Kitchen remodel electrical question Dore Electrical 9 05-15-2011 09:03 AM
Please help -Kitchen cabinet question BusyOne Remodeling 20 01-13-2010 02:08 AM
my 1st kitchen question on laminate / melamine rotarex Kitchens & Baths 9 03-10-2009 12:22 PM
