Product Review/Demonstration Video - Strait Flex Uno-Bead - Corner Bead On A Roll - Page 2 - Drywall - Contractor Talk
Old 07-06-2015, 01:07 PM   #21
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Re: Product Review/Demonstration Video - Strait Flex Uno-Bead - Corner Bead On A Roll
Originally Posted by aptpupil View Post
Change that smoke alarm battery.
Every single time.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Sir Mixalot (07-06-2015)
Old 07-06-2015, 01:34 PM   #22
Creter's Avatar
Rewards Points: 1,966
Originally Posted by blacktop View Post
Is that you, Blacktop?
Creter is offline
The Following User Says Thank You to Creter For This Useful Post:
mikeswoods (08-26-2015)
Old 07-06-2015, 01:43 PM   #23
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Thank you Sir Mixalot---I'll be picking up a roll of that corner bead and giving it a shot--
That product would save me a lot of trips for forgotten corner bead.
I've been using Original Straight Flex for inside corners for many years.
mikeswoods is offline
The Following User Says Thank You to mikeswoods For This Useful Post:
Old 07-06-2015, 03:22 PM   #24
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,431
That thing drove me crazy. I told the homeowner I would put a new battery in for him since it was probably about 18' up. He said he was going to pick one up and have it there the next day when I came back to finish.
He forgot to pick one up. So day 2 was with the beeping beeping beeping...
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
aptpupil (07-06-2015), blacktop (07-06-2015)
Old 07-06-2015, 04:52 PM   #25
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 214
No... That's Frank . He's a true master of the trade .. Check out his channel .
https://www.youtube.com/watch?v=GRCuj6PcZVY
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following 2 Users Say Thank You to blacktop For This Useful Post:
Creter (08-25-2015), Sir Mixalot (07-06-2015)
Old 07-11-2015, 10:46 AM   #26
Yeah Mike, I think the Uno-bead is a perfect solution for always' having corner bead with you at all times. Even if it's not the main corner bead product someone uses on bigger drywall projects.
Let us know how you like it.
-Paul
TextureMaster.com
Old 07-11-2015, 04:44 PM   #27
mikeswoods's Avatar
I'll post when we try it----we are taping a little kitchen today--no corner bead needed---next job---I'll let the site know what I think.
Sir Mixalot (07-11-2015)
Old 08-22-2015, 07:38 PM   #28
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 142
Great vid, thanks.
Is this stuff readily available on the left coast? I've been using the inside corner stuff for a while, occasionally on outside corners -- shh!, and really like it. (I do very little drywall, so shopping/traveling with corner bead is a pain in the $%.)
Defenestrate is offline
The Following User Says Thank You to Defenestrate For This Useful Post:
Sir Mixalot (09-03-2015)
Old 08-25-2015, 02:44 PM   #29
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
It looks good for limited uses. There are times where I've done the same thing with level line. This would more likely be a better option. I wouldn't use it in place of metal for two reasons. One: it limits adjustability where the framing is off. Two: It takes much longer to install. I use a paslode which helps me install a stand up in 20 seconds. I do like the fact that it uses less mud to coat. I am also not a fan of mudding bead. Up north here temperature changes causes framing to shrink and swell. Mudded beads tend to crack and peel unless it's over metal stud.
It looks like a great product. Definitely a great idea. I would use it but in limited areas. Thanks for the heads up Paul. I'm not sure I can even get it up here for those reasons.
One more thing. Gotta say, I loved the reflection of you holding the camera in you mouth. Being able to do that while mudding and narrating is impressive. But can you core a apple chef of the future?
BUTCHERMAN is offline
The Following User Says Thank You to BUTCHERMAN For This Useful Post:
Sir Mixalot (08-25-2015)
Old 08-26-2015, 12:00 AM   #30
Hair Splitter
Trade: General
It's designed to grab and bond with the mud.
It has greater flexibility when the walls are off. They also name Straight Flex BIG and Straight Flex HUGE for larger gaps.
It's also more forgiving where seasonal movement is a concern.
Old 09-03-2015, 03:38 PM   #31
Originally Posted by Defenestrate View Post
Great vid, thanks.
Thank you.
Yes it's available on the West coast.
Here's a link to the StraitFlex dealers in California from the dealer locator on their website http://www.straitflex.com/ca.php
-Paul
TextureMaster.com
The Following User Says Thank You to Sir Mixalot For This Useful Post:
Defenestrate (09-03-2015)
Taping corner bead? Dave in Pa Drywall 19 12-17-2014 04:41 AM
Corner Bead installers kama480 Drywall 1 06-03-2014 03:39 PM
Opinions on the Schluter/Kerdi inside corner bead. mjay Tiling 3 04-06-2014 11:37 AM
Need suggestion for Corner bead ? normantos21 Drywall 1 02-06-2014 09:33 AM
