Problems With My Texture.... - Drywall - Contractor Talk
Old 08-07-2010, 11:08 AM   #1
Sibbert1's Avatar
Trade: Drywall
I recently bought the Graco Texspray 1500 and didn't have any problems the first couple times I used it. I went to spray ceilings last week and it seemed to be shooting the mud out more in a stream, not the spray that i like to create a consistent texture. This made orange peel impossible and knockdown messy and inconsistent. I tried thinning and thickening the mud, and adjusted the pressure from very low to high. Any suggestions or tips are appreciated.
Sibbert1 is offline
Old 08-07-2010, 11:44 AM   #2
A. Spruce's Avatar
Trade: General Contractor - ret.
Re: Problems With My Texture....
Sounds like reduced pressure. How well was the equipment cleaned after each of the first few uses before it started showing this issue?
A. Spruce is offline
Old 08-07-2010, 11:48 AM   #3
Sibbert1's Avatar
Trade: Drywall
It was cleaned thoroughly inside and out after each use. And there was plenty of pressure... It's a problem I haven't seen before.
Sibbert1 is offline
Old 08-07-2010, 12:04 PM   #4
A. Spruce's Avatar
I think I'd cal the dealer and talk to them about the symptoms. There may be a quirk with that model that is prone to this issue that they know about. At the very least they should be able to help you diagnose the problem.
Old 08-07-2010, 12:30 PM   #5
Tim0282's Avatar
Trade: drywall contractor
I've had a couple of these. Could there be a small chunk in the gun? Right behind the tip?
Tim0282 is offline
Old 08-07-2010, 12:38 PM   #6
Sibbert1's Avatar
Trade: Drywall
That was my first guess too, but I changed the tip a couple times trying to counteract the problem.
Sibbert1 is offline
Old 08-07-2010, 12:43 PM   #7
Tim0282's Avatar
When you have the tip off, does it spray a good stream of mud? Wonder if something is stuck deeper in the gun. Like a small chunk of plastic from mixing in the bucket.
Tim0282 is offline
Old 08-07-2010, 12:54 PM   #8
Sibbert1's Avatar
Trade: Drywall
That could be! I'll give it a try.
Sibbert1 is offline
Old 08-07-2010, 12:56 PM   #9
Licensed, Bonded & Insur
ewingpainting's Avatar
Rewards Points: 264
Do you strain your mud?
Riverside County Painters
ewingpainting is offline
Old 08-07-2010, 01:03 PM   #10
Tim0282's Avatar
Sounds more like a chunk of plastic. It'll usually bow chunky mud apart. But the plastic can sure get lodged hard!
Tim0282 is offline
Old 08-07-2010, 01:03 PM   #11
Tim0282's Avatar
You had plenty of air?
Tim0282 is offline
Old 08-07-2010, 01:45 PM   #12
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,485
Turn down the material knob on the machine (three dots down from Max material).
Then turn the gun trigger dial (not the air control) down to
where it barely moves when you squeeze trigger.
Start adjusting the gun from there.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
Old 08-07-2010, 01:50 PM   #13
Sibbert1's Avatar
Trade: Drywall
No, the mud was plenty loose. I think Tim hit it on the head. Usually the problem is something stupid and easy like that. I'll pay more attention to the gun when I get back. Thanks guys.
Sibbert1 is offline
Old 08-07-2010, 02:32 PM   #14
Tim0282's Avatar
Now I just have to say this....... I bet you are using a mixer made out of metal so it scratches the bucket...... Now, if you were using that mixer made by Hardman Industries, you wouldn't get any of those chunks of plastic in your mud to get lodged in your gun.... Just digging here.....
Tim0282 is offline
Old 08-07-2010, 03:31 PM   #15
I'm still loving mine from Hardman.
-Paul
TextureMaster.com
Old 08-07-2010, 03:49 PM   #16
Tim0282's Avatar
It surely doesn't look that pristene anymore, does it? And wait, your shaft is blue? Mine is green! Blue is my favorite color! Now I have to buy one! They are the best mixers out there. Even with a green shaft!
Tim0282 is offline
Old 08-07-2010, 04:26 PM   #17
That was the first day I recieved it.
-Paul
TextureMaster.com
Old 08-07-2010, 09:57 PM   #18
Sibbert1's Avatar
Trade: Drywall
Cool
I gotta get me one of those!!
Sibbert1 is offline
Old 08-08-2010, 06:13 AM   #19
Tim0282's Avatar
They'll tear your arm off if you're not expecting it. They can really mix a bucket of mud. Won't leave any unmixed in the center-bottom of the bucket. Some guys will tell you, you can mix right in a box, then dump it in a bucket..... Now why would you want to do that? And who was the first guy to try that??? Sure sounds like an accident in the making. Seems it would be that much harder to get out of the bag. They are a good mixer, but I'm gonna stick to using it in a bucket.
Tim0282 is offline
Popcorn Texture over Concrete AM1965 Drywall 14 04-15-2010 10:51 AM
Ceiling texture fun!! EricTheHandyman Drywall 2 04-01-2009 09:14 PM
Prime and Texture over painted splatter ceiling texture AARC Drywall Drywall 2 03-13-2009 07:53 PM
Snow texture, popcorn texture... AARC Drywall Drywall 5 10-30-2008 01:30 AM
Pock marks in Orange Peel texture MCComplete Drywall 4 01-14-2008 11:09 AM
