Porter Cable 7800 Drywall Sander - Page 2 - Drywall - Contractor Talk
Old 12-15-2009, 01:45 PM   #21
drywall icon's Avatar
Trade: painting and drywall
Re: Porter Cable 7800 Drywall Sander
you got to put a sanding pad over that velcro
drywall icon is offline
Old 12-15-2009, 02:19 PM   #22
Mickey
mickey69125's Avatar
Trade: residential remodeling
Rewards Points: 75
Of course I had a sanding pad on it, but the pad with the velcro on it is thicker than the regular sanding pad and wouldn't let the head of the sander close enough to the wall for the vacuum to suck the dust up. Don't know if it was just the Menards one or what the problem was, but it didn't work. Have been meaning to call All-Wall and ask them about that but haven't done it yet.
I always learn more by listening that I do by talking.
mickey69125 is offline
Old 12-15-2009, 03:40 PM   #23
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,628
I use the Norton backing pads and paper with mine and have had no issues.
Trust me, this sander here will make you throw away that Porter Cable:
http://www.festool.co.uk/mediandoweb...69&AKTIVPROD=1
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 12-15-2009, 05:09 PM   #24
you have to put a sanding pad on the velcro
Old 12-15-2009, 05:47 PM   #25
Mickey
Rewards Points: 75
You evidently didn't read my earlier post.
Old 12-15-2009, 05:50 PM   #26
Mickey
Rewards Points: 75
It looks nice but for $2200 I think I'll stick with the ol' Porter Cable.
Old 12-15-2009, 06:32 PM   #27
I like Green things
No way, the planex is modular, it shortest section for use is about 4' and it can extend to 10'.
The suction is so good, it will hold itself to the wall.
That price is also including the vac.
It is truely light years ahead of anything like it.
Warner Mill Works
Facebook
YouTube
Old 12-16-2009, 10:28 PM   #28
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
I picked up a few 25 packs of sandpaper that fit both the radius 360 sander and the PC power sander at sherwin williams for like $0.15/piece or something cheap like that. Were on close out, might wanna check your local stores and see what they have
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Old 01-16-2010, 12:04 PM   #29
phoney2's Avatar
Trade: professional
Originally Posted by xtremekustomz View Post
Anyone use this sander? I've been using one lately and have only been able to find foam pads with velcro on them. After about 15 minutes of use the velco comes off of the pad. Anyone else have this problem?
i love the hook an loop pad s allways had good luck with them but never could use the other type not sure why
phoney2 is offline
Old 01-16-2010, 12:07 PM   #30
phoney2's Avatar
Trade: professional
now thats a great deal the cheapest i can find them here in vt is .80 cents each buy them up while you can
phoney2 is offline
Old 01-16-2010, 12:09 PM   #31
phoney2's Avatar
Trade: professional
are your brushes worn down
phoney2 is offline
Old 01-17-2010, 11:39 AM   #32
woodyrr's Avatar
Trade: Residential & Light Commercial Remodeling & Repair
Originally Posted by Capt-Sheetrock View Post
. . . If your wobbling, you have the pad off center, got to pay attention when you put it on, kep it centered. hitting a box or widow, or anything like that will tear off the pad or wrinkle it making it wobble just like being off center,,, its kinda like balancing a tire, if it gets off balance, you will know it.
I have a PC 7800 and the original model vac. For the record, outside of the increase in speed and quality, it makes working in an occupied home so much easier and cleaner.
Since I don't use it day in and day out, I haven't explored other sandpaper options. With the Norton Velcro backup pad, is it difficult to get the pad and sandpaper centered so that everything is not out of balance? Of course, fighting with that plastic nut every time that I need to change disks isn't exactly the easiest thing in the world, but the disks do seem to center themselves.
I am getting ready to order some more disks, but if the Norton system provides as good a finish as the proprietary disks with less hassle, I'll order them.
Thanks.
woodyrr is offline
Old 01-17-2010, 12:54 PM   #33
Mickey
Rewards Points: 75
No, the brushes are not worn. As soon as I put the regular disc on everything was fine again. The foam disc just would not let the brushes get close enough to the wall.
Old 01-28-2010, 12:00 AM   #34
gtp's Avatar
I had the same problem. I needed some 80 grit pads to sand a textured ceiling smooth.
At home depot they had norton backing pads and hook and loop. As i installed it I noticed that the backing pad was much thicker than the original foam/sandpaper pad I was taking off but didnt think anything of it till i started sanding.
It was horrible. Not even a 1/5 as much dust as normal was collected by the vac, It was bad. Sanding texture creates alot more dust than sanding a skimcoat to begin with and It was like there was no collection. I couldnt even see through the cloud even half the time and there ended up way way too much cleanup. The thick pad made the sandpaper sit at the top of the brushes or slightly above instead of below the brushes so there was no seal to the ceiling and the dust flew out the edges.
What did allwall say when you called them?
gtp is offline
Kreg Jig K2 vs. Porter Cable 550 OlTrimguy Finish Carpentry 13 07-07-2014 07:30 PM
porter cable palm belt sander Bone Saw Tools & Equipment 5 04-18-2007 05:47 PM
porter cable drywall sander tgates Contractor Swap 5 01-24-2007 09:51 AM
Porter Cable Framing Nailers Reno Tools & Equipment 10 05-04-2006 10:44 AM
GREAT Custome Service from Porter Cable JPV123 General Discussion 3 04-06-2006 08:06 PM
