Popcorn Ceiling - Drywall - Contractor Talk
Popcorn Ceiling
Old 11-11-2019, 12:58 AM   #1
Genesi's Avatar
Rewards Points: 2
Popcorn Ceiling
Starting a job this week and part of the scope is spraying popcorn ceiling and i was wondering if i am able to use the plus 3 bucket joint compound or if there is a type of joint used for this task ?
Genesi is offline
Old 11-11-2019, 07:57 AM   #2
Porterfarm's Avatar
Trade: Handyman/ Home Improvement Contractor
Rewards Points: 28
Re: Popcorn Ceiling
Just tape tape the ceiling as if you're taping the walls.
Then prime the ceiling.
Then spray with your spray texture. I'm partial to USG spray tex. Follow the mixing instructions on the bag. They have coverage rate per bag as well.
I spray mine alot lighter, at a faster rate. So I get more coverage per bag. But I like the lighter look as opposed to a heavy texture.
You can try a few test passed on some paper first.
Porterfarm is offline
Old 11-11-2019, 09:03 AM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: Popcorn Ceiling
Tape well brother, that crap makes a mess going on and a mess when it gets removed.
Not a lover of pop corn ceiling, pain in the ass to paint also.
Still "Shakin" the tree boss
sunkist is offline
Old 11-11-2019, 09:44 PM   #4
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,485
Re: Popcorn Ceiling
Mix it soupy.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following 4 Users Say Thank You to Sir Mixalot For This Useful Post:
avenge (11-12-2019), Calidecks (11-12-2019), hdavis (11-12-2019), Texas Wax (11-12-2019)
Old 11-12-2019, 01:31 AM   #5
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Re: Popcorn Ceiling
Biggest dust trap there is. Hate it.
Irishslave is offline
Old 11-12-2019, 09:16 AM   #6
builditguy's Avatar
Rewards Points: 2,162
Re: Popcorn Ceiling
Are you doing a retro 70s remodel? Isn't popcorn dated? Of course we are in different areas.
builditguy is offline
Old 11-12-2019, 10:52 AM   #7
avenge's Avatar
Rewards Points: 358
Re: Popcorn Ceiling
I'm guilty of spraying a bunch of that in the 70's and early 80's. It and other blown on textures are outdated and removed I don't think I pulled out my hopper since. If I had to do it I'd only use what Mixalot posted.
avenge is offline
Old 11-12-2019, 01:08 PM   #8
Adamthebuilder's Avatar
Trade: Builder
Rewards Points: 350
Re: Popcorn Ceiling
Since we’re on the subject of Popcorn Ceilings .....
We are just purchasing a condo built in 1984, and I want to remove it. Is spraying water, waiting and scraping the best approach, or just go at it dry?
Adamthebuilder is offline
Old 11-12-2019, 09:07 PM   #9
Porterfarm's Avatar
Rewards Points: 28
Re: Popcorn Ceiling
I use a pump sprayer and a floor scraper with 4mil plastic on the floor.
Old 11-12-2019, 11:38 PM   #10
test
cedarboarder's Avatar
Trade: General
Rewards Points: 839
Re: Popcorn Ceiling
1984, get asbestos tests yet?
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 11-12-2019, 11:47 PM   #11
Mordekyle's Avatar
Rewards Points: 6,366
Re: Popcorn Ceiling
Soak it with soapy water, sprayed on. The soap helps the water penetrate.
Go to lunch, Then do it again. Time is your friend.
No asbestos in 1984.
Mordekyle is online now
The Following User Says Thank You to Mordekyle For This Useful Post:
Adamthebuilder (11-13-2019)
Old 11-13-2019, 03:49 AM   #12
test
Trade: General
Rewards Points: 839
Re: Popcorn Ceiling
Up here we have to test anything pre 1990.
Asbestos was used in these materials between 1930 and 1990.(In Canada not sure about the states)
Old 11-13-2019, 07:38 AM   #13
Trade: Builder
Rewards Points: 350
Re: Popcorn Ceiling
Thanks Cedarboarder.
Would having lunch at the famous Flora-Bama be adequate?
The condo is about 5 minutes away.
The Following User Says Thank You to Adamthebuilder For This Useful Post:
cedarboarder (11-13-2019)
Old 11-13-2019, 11:31 PM   #14
test
Trade: General
Rewards Points: 839
Re: Popcorn Ceiling
If I ever get out that way for sure. Looks like that state line is worth the trip.
Old 11-14-2019, 05:57 AM   #15
sunkist's Avatar
Rewards Points: 890
Re: Popcorn Ceiling
The ceiling will probably need a skin coat after the popcorn removal.
sunkist is offline
Old 08-21-2020, 09:00 AM   #16
NCDrywallKings's Avatar
Trade: Drywall
Rewards Points: 4
Re: Popcorn Ceiling
Yeah you just got to tape up the walls, prime the ceiling and start with your spray texture. It will take a bit to get it right but you can test on some paper before the ceiling. If you need help let me know I'll leave my website below and you can get in touch with me there.
https://drywallrepairgreenvillenc.com
NCDrywallKings is offline
