Patching Over Semi Gloss Oil Based Paint - Drywall - Contractor Talk
Old 07-14-2018, 01:55 PM   #1
zukinut's Avatar
Trade: electrician by trade, general contractor, cabinet maker
Rewards Points: 100
I have to repair the ceiling in a customers indoor pool "house". The ceilings are painted with an oil based semi gloss paint. Do I need to prime the ceiling patch area with guardz or pro block or something else, or am I ok to just clean it and patch?
I've always primed the painted area with pro block, the damaged area with guardz and then do my mudding, but I wanted to ask the pros what they reccomend.
Thanks again for all the help.
Will
zukinut is offline
Old 07-14-2018, 08:03 PM   #2
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,469
Re: Patching Over Semi Gloss Oil Based Paint
I've always primed the painted area with pro block, the damaged area with gaurdz and then do my mudding, but I wanted to ask the pros what they reccomend.
Will
I always prime oil around the perimeter of the repair with a Kilz or BIN spray can. Unless it's a big area I'll roll it out. Gardz works great on regular ceilings. Except when there's water stains, then I'll hit it with one of the oil base stain blocking primers.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 70,000 Subscribers and over 11,000,000
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
Old 07-15-2018, 09:11 AM   #3
zukinut's Avatar
Rewards Points: 100
Thank you sir.
zukinut is offline
Old 07-15-2018, 09:33 PM   #4
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,910
I would prime the area to be repaired with an oil base primer before starting any repairs.
Ohio painter is offline
Old 08-07-2018, 06:45 PM   #5
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 646
Will
Don't believe you mentioned the cause of repair.
I've seen pool area ceilings that were literally destroyed by moisture.
Is it moisture related? Or due to alteration/damage?
artinall is offline
Old 08-07-2018, 06:57 PM   #6
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 940
Glossy surfaces, especially oil based, should be sanded until dull for best adhesion
Idothat is online now
Old 08-07-2018, 08:24 PM   #7
zukinut's Avatar
Rewards Points: 100
[/quote]Don't believe you mentioned the cause of repair.
Is it moisture related? Or due to alteration/damage?[/QUOTE]
First time there was a roof leak, I fixed it and 2 days later the a/c drain line in the attic took it out. This time, a settling crack allowed moisture in. Settling was due to a cracked knot rafter caused by a/c guys being idiots.
zukinut is offline
Old 08-08-2018, 06:13 PM   #8
artinall's Avatar
Rewards Points: 646
I would use oil too, but if there is stress cracking/shearing then glass tape instead of paper (not "fiberglass" just to be clear) for patch along with setting-type compound.
Some pool rooms are practically dripping in water. Have seen paper tape lift, and beginning to hang in a sort of sick celebration all over off the ceiling (big name hotel chain here locally). Can't close the room down? Can't get it fixed.
Where moisture was a known problem in some situations I have primed the backside of wallboard before it goes up which may help in the future anyway ... (such as for high moisture wall cavity having a shower in the other side) but be careful, as this may also create a moisture barrier.
You may even hit it with growth preventative - but of course I can't see it or what is potentially coming through.
I'd be concerned about a rafter settling that much that quick even though it may not be your problem. Was it too large a drill out?
Note: they may need to stabilize 1st (sister-on or other remedy) given access.
Hope this helps,
Art
artinall is offline
Old 08-08-2018, 08:11 PM   #9
zukinut's Avatar
Rewards Points: 100
Art,
I fixed the rafter first, and then did the patch. I tried that fibafuse tape. Didn't wanna run the risk of having the tape lift like you stated, and I was out of mesh tape. So I bought and tried fibafuse. For whatever reason I can't get pics to load from my phone or I would show you the problem and the fix.
Will
zukinut is offline
Old 08-08-2018, 09:53 PM   #10
artinall's Avatar
Rewards Points: 646
Art,
Will
I've had great luck with Fibafuse and it can be backfilled, if the mix is thin enough.
I use on flat surfaces only, it can tear on inner corners.
artinall is offline
Paint or stain on hardi plank? Jer Painting & Finish Work 28 02-17-2017 08:29 PM
Painting Douglas Fir 1890's Front Porch: What Paint? JLPicard Painting & Finish Work 11 05-22-2013 09:33 AM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
latex semi gloss over oil semi gloss - can it be done? Zeebo Painting & Finish Work 13 09-05-2007 05:38 PM
Oil Based Paint leaving wrinkly finish on doors dwbrooks Painting & Finish Work 8 11-09-2005 11:29 PM
