Patch Holes Behind Baseboard ? - Page 2 - Drywall - Contractor Talk
Old 09-10-2018, 10:20 PM   #21
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 288
Re: Patch Holes Behind Baseboard ?
This was a great read .
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 09-10-2018, 10:25 PM   #22
Drywall Slave
blacktop's Avatar
Rewards Points: 288
Originally Posted by griz View Post
Drafts & critters.
So the baseboard aint good enough ? I get that .
blacktop is offline
Old 09-10-2018, 10:56 PM   #23
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
Nobody suggested having metal sheared in lengths to fit behind the baseboard to serve as a fire barrier, which could be removed with the baseboard should the home flood again.
P42003 is online now
Old 09-20-2018, 07:32 PM   #24
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 618
You could also use those to scope pests and insects
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
P42003 (09-21-2018)
Old 09-20-2018, 10:03 PM   #25
PC&R's Avatar
Rewards Points: 122
Originally Posted by hdavis View Post
Lots of ways to do this.
The first consideration is any fire rating requirements.
Fastest is probably plug with foam cutouts slightly recessed, and skim with durabond. You can put the trim back up before it sets if you want.
I just completed a project where i needed to blow in insulation into some existing walls. The insulation contractor did just that, drilled a bunch of 3" holes, stuffed it with foam and skim coated it. The taper brought it up to a level 5 finish.
It took them all of 30 second per hole.
PC&R is offline
The Following User Says Thank You to PC&R For This Useful Post:
hdavis (09-21-2018)
Old 09-20-2018, 10:09 PM   #26
PC&R's Avatar
Rewards Points: 122
Originally Posted by Allspark View Post
The fire rating is a concern as the above post. But gyp is always lifted off the floor so it doesnt crack with the house flexes, rarely does anyone seal behind the baseboard. or put a jam of a mdf door over gyp, I for one wont trust insurance companies, but I know for a fact insurance companies let that go as its common practice and rarely do every building codes stipulate open gaps in fire rated material to the 1/8 of an inch. What would be needed wud be a fire stop for combustible framing. I would just put a back fire rate ply and then a piece of gyp then time mud then ur finish coat.
You can fire block with 2x material. Doesn't The sill plate behind drywall gap act as part of the fire rated system?
PC&R is offline
Old 09-21-2018, 09:48 AM   #27
hdavis's Avatar
Rewards Points: 2,286
The sill plate is part of the fire rated wall assembly, but it's also structural, so it needs some protection from fire in a rated assembly. That isn't to say it has to be 100% covered, just whatever the protectuon is called out.
Patching is usually only an issue for higher fire ratings. Patching seperations between units in a multifamily would be an example.
hdavis is online now
artinall (09-22-2018)
Old 09-29-2018, 08:48 AM   #28
Residential Contracting
GTBuilds's Avatar
Rewards Points: 63
I think this is just about the simplest method and it offers good results.
GTBuilds is offline
Product to patch bug holes Golden view Masonry 5 06-29-2017 10:41 PM
Filling Holes in PT ? We Fix Houses Decks & Fencing 29 02-24-2013 01:59 PM
"Quick" drywall patch robert c1 Drywall 23 01-23-2013 06:10 PM
DIY knockdown patch Cole82 General Discussion 9 05-27-2012 11:44 PM
Pergo patch in middle of large floor, treat it like a hardwood patch? Big Hammer B Flooring 26 11-13-2011 08:48 PM
