Patch Holes Behind Baseboard ? - Drywall - Contractor Talk
Old 08-24-2018, 03:52 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
There was a flood and restoration co. drilled out about 3 inch holes in the wall bays with the baseboard removed. No moisture found.
Basement on slab and tile floor.
These really needed patching before new baseboard is installed? Which would conceal the holes. Why would there be another reason to close the wallboard up first?
artinall is offline
Old 08-24-2018, 04:39 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,516
Re: Patch Holes Behind Baseboard ?
Drafts & critters.
griz is online now
The Following 3 Users Say Thank You to griz For This Useful Post:
artinall (08-24-2018), MarkJames (08-24-2018), Sir Mixalot (08-24-2018)
Old 08-24-2018, 04:45 PM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 13,177
Fire marshal would think so.
Fire tape with a california patch and put the base on.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 08-24-2018, 05:18 PM   #4
artinall's Avatar
California patch?
artinall is offline
Old 08-24-2018, 05:37 PM   #5
LRG WoodCrafting
Leo G's Avatar
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-24-2018, 05:47 PM   #6
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 186
Griz & Leo nailed it but it should only be about an inch to an inch & a half not three - with that fill with foam & shave off excess as baseboard covers it
SLSTech is online now
Old 08-24-2018, 05:56 PM   #7
Adamthebuilder's Avatar
Trade: Builder
Rewards Points: 334
If it is required for all the reasons that have been mentioned above, the insurance company should pay to patch the holes. I am guessing at least $75 per hole?
Adamthebuilder is offline
Old 08-24-2018, 06:12 PM   #8
artinall's Avatar
I know that as a Butterfly patch.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
Snobnd (08-25-2018)
Old 08-24-2018, 06:22 PM   #9
MarkJames's Avatar
Rewards Points: 19,561
How about the self stick, metal-backed patches? cut to fit, skim it, done. dries quick, too, since it's not too thick with mud.
MarkJames is offline
Old 08-24-2018, 06:48 PM   #10
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,485
Mix some 20 minute mud a little thick and fill the holes.
*Edit- The holes are 3" in diameter?
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
hdavis (08-27-2018)
Old 08-25-2018, 01:26 AM   #11
artinall's Avatar
What started out as a "why should it be"...quickly became "how to patch" I tend to think the glass tape with its lower build behind the base, to keep it tight to the wall.
Or maybe no tape, as pointed out.
If it was a full bath I might seal over it but it's a half.
artinall is offline
Old 08-25-2018, 11:48 AM   #12
LRG WoodCrafting
Leo G's Avatar
That's why I suggested the california patch. It's only as thick as the paper if you are only doing the 1st coat.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
artinall (08-25-2018)
Old 08-26-2018, 10:09 AM   #13
AustinDB's Avatar
Rewards Points: 1,592
is a california patch essentially a level 1 finish?
one reason not to use the metal wall patches is the added thickness-if it matters.
a 3" hole above the bottom plate brings the damage up 4-1/2-5" off the floor, that would require a nice wall patch unless you're using a taller baseboard on top of the tile.
AustinDB is offline
Old 08-26-2018, 10:44 AM   #14
Texas Wax's Avatar
Rewards Points: 2,172
Do they really need patching? Meh, really depends upon the owner or if the insurance company will pay for it. Have never heard a definitive answer. Cali patches are ideal, but PIA mickey mouse time consuming. Not bad for a handful of holes, but I've seen 20-50-100 holes. They really like the 3" holes down here, if the base board will cover it. I lean toward a "draft Stop" solution. In good conscience, at a minimum, I fire tape (draft stop) with fibrous mesh wide enough to cover.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 08-26-2018, 11:22 AM   #15
avenge's Avatar
Rewards Points: 308
Screw patching holes just cutout and replace the drywall.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
artinall (08-27-2018)
Old 08-26-2018, 07:48 PM   #16
artinall's Avatar
Which has occurred to me.
Probably best.
Don't know why they cut these large holes.
artinall is offline
Old 08-27-2018, 05:17 AM   #17
Big Shoe's Avatar
Rewards Points: 2,124
Duct tape. Seal the draft.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
Old 08-27-2018, 06:13 AM   #18
woody123's Avatar
Trade: repair , and remodeling
Rewards Points: 304
" 5-minute mud " is my buddy for that kind of thing
woody123 is offline
The Following User Says Thank You to woody123 For This Useful Post:
Old 08-27-2018, 11:07 AM   #19
hdavis's Avatar
Rewards Points: 2,354
Lots of ways to do this.
The first consideration is any fire rating requirements.
Fastest is probably plug with foam cutouts slightly recessed, and skim with durabond. You can put the trim back up before it sets if you want.
hdavis is online now
The Following 3 Users Say Thank You to hdavis For This Useful Post:
artinall (08-27-2018), Big Shoe (08-28-2018), GTBuilds (09-29-2018)
Old 09-04-2018, 10:21 PM   #20
Allspark's Avatar
Rewards Points: 28
The fire rating is a concern as the above post. But gyp is always lifted off the floor so it doesnt crack with the house flexes, rarely does anyone seal behind the baseboard. or put a jam of a mdf door over gyp, I for one wont trust insurance companies, but I know for a fact insurance companies let that go as its common practice and rarely do every building codes stipulate open gaps in fire rated material to the 1/8 of an inch. What would be needed wud be a fire stop for combustible framing. I would just put a back fire rate ply and then a piece of gyp then time mud then ur finish coat.
Allspark is offline
Product to patch bug holes Golden view Masonry 5 06-29-2017 10:41 PM
Filling Holes in PT ? We Fix Houses Decks & Fencing 29 02-24-2013 01:59 PM
"Quick" drywall patch robert c1 Drywall 23 01-23-2013 06:10 PM
DIY knockdown patch Cole82 General Discussion 9 05-27-2012 11:44 PM
Pergo patch in middle of large floor, treat it like a hardwood patch? Big Hammer B Flooring 26 11-13-2011 08:48 PM
