Old Drywaller, New Estimator - Page 3 - Drywall - Contractor Talk
Old 02-19-2008, 05:06 PM   #41
galanbro's Avatar
Trade: DRYWALL & INSULATION
Re: Old Drywaller, New Estimator
Hey dave I am wondering if it is to late to ask you for a copy of that spreadsheet. I am starting to get into the multifamily business and estimating can become a little time consuming.
Thanks ,.
Omar
[email protected]
galanbro is offline
Old 02-04-2016, 04:24 PM   #42
AJ M's Avatar
Trade: Home Improvement Specialist
Rewards Points: 4
Originally Posted by DaveH View Post
Kirk,
You're right. Don't worry about the size of the sheets when bidding. Make sure you have enough SF to cover your a**. If the job is small enough you can go to the site and measure the board sizes before bidding. You simply make a sheet up with your board size and thickness I.E. 8'-1/2" ...10'-1/2"... 12'-1/2"...8'-5/8" .... Then walk it measure it as you would hang it and put a mark by each sheet as you go. At the end you will have your complete list. If you are working from prints as I do mostly you can use the meathod I described (Carter's Meathod). If your wall are slightly under 8' they still measure as 8'...9'-4" becomes 10' and so on. All drywall comes in even 2' lengths so your estimates should always round up to the next 2' incrament. If you would like I could send you an example of an excel spreadsheet I use for estimating to help. I also do teaching.
Dave, could I take you up on the spreadsheet?
[email protected]
Thank you in advance!
AJ
Last edited by AJ M; 02-04-2016 at 04:55 PM. Reason: forgot to leave an email address
AJ M is offline
Old 02-04-2016, 05:38 PM   #43
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
[email protected]
AJ
Did you notice that the original posting is from quite a long time ago?
jlhaslip is offline
Old 03-06-2016, 12:46 AM   #44
Banger of Nails
Dullers's Avatar
Rewards Points: 66
I start at $75/ board, hang, finish, & primer (we always prime) and go from there with difficulty, size of job, pita factor(s), 12 vs 8' sheets, etc.
Dullers is offline
Old 03-30-2016, 07:56 PM   #45
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
Figure out how much each guy can hang a day (Avg 500 sf day in commercial per guy), same for taper. Then divide your total sf by that number and you've got your days to complete. Add in material price per sf and some extra time to get the board shook out on site, plus your markup
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Roofing Estimator Needed harrychamp Help Wanted or Looking For Work 2 05-01-2007 07:00 PM
2006 National Electrical Estimator RandyMc Electrical 4 10-08-2006 06:32 PM
Craftsman Construction Estimator books ejyonkman General Discussion 16 07-26-2006 07:30 PM
need estimator rich schwartz Help Wanted or Looking For Work 3 04-13-2006 07:14 AM
estimator 2tones Painting & Finish Work 11 11-28-2005 07:54 PM
