Old Ceiling Removed - Drywall - Contractor Talk
Old Ceiling Removed
Old 10-20-2013, 10:23 PM   #1
coolmen's Avatar
Trade: hvac
Rewards Points: 79
Old Ceiling Removed
I removed the old 12 inch squares on the ceiling of the living room. That was held on by 1/2" x 2 " wood strips. I removed the wood strips and lost all the insulation .ended up replacing the insu
Ation as well. Now im gonna install 1/2 sheet rock and will end up haveing a 1/2" gap. At the walls ceiling area. How do i fix this? Simply tape and mud at the corners.
coolmen is offline
Old 10-20-2013, 10:27 PM   #2
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Old Ceiling Removed
How big is the room? Could you fur down the ceiling? Could you use 5/8" rock to at least close the gap a little?
Otherwise you would want to use "hot" mud to fill your gap. I would flat tape your joint then put the corner tape over that.
CrpntrFrk is offline
The Following User Says Thank You to CrpntrFrk For This Useful Post:
donerightwyo (10-20-2013)
Old 10-20-2013, 10:28 PM   #3
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Crown, or cove molding
jlsconstruction is offline
Old 10-20-2013, 10:31 PM   #4
AustinDB's Avatar
Rewards Points: 22
you're speaking in future tense, therefore 1/2 strips to fur the ceiling down just a bit more. Maybe use 7/16 OSB-to ensure you can get the ceiling rock above the wall rock.
AustinDB is offline
The Following 2 Users Say Thank You to AustinDB For This Useful Post:
CrpntrFrk (10-20-2013), hdavis (10-20-2013)
Old 10-20-2013, 10:33 PM   #5
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Fur the ceiling back down. I would not fill with mud. Or double up the 1/2" rock.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Ancient Rocker (10-21-2013)
Old 10-20-2013, 11:43 PM   #6
hdavis's Avatar
With OSB I use the self drilling drywall screws - I've had too many problems with the regular drywall screws just spinning on the OSB surface.
hdavis is online now
Old 10-21-2013, 06:14 AM   #7
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,495
Add furring strips or resilient channel to the ceiling.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 100,000 Subscribers and over 15,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
TNTRenovate (10-21-2013)
Crack at Peak in vaulted Ceiling Milhaus Drywall 21 11-04-2013 09:44 AM
Temporary Rafter Support for Clipped Ceiling TLyon Remodeling 17 09-12-2013 11:22 PM
Ideas for lowering a ceiling 4-5" sbcontracting Framing 3 04-25-2011 11:47 PM
Radiant Ceiling Heat - Drywall Falling Again CliffHollen Drywall 7 04-05-2010 04:18 AM
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
