Obtuse Inside Corners - Drywall - Contractor Talk
Old 07-05-2019, 01:34 PM   #1
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,180
I'm sure this question has probably been discussed too many times, but...I've been dealing with a lot of these shallow ceiling angles and I'm doing an awful job making them look okay.
I taped a few with paper tape and I'm trying to round them off so the crooked line isn't as noticeable. The worst are where my level/flat drop ceiling framing meets the underside of bowed/sagging roof rafters. I saw a rubber drywall knife online but I just ran a 12" perpendicular to round it off. Sanding that radius was very awkward.
It will eventually end up "passable" but what should I do next time so I don't waste countless hours touching up?
dielectricunion is offline
Old 07-05-2019, 02:02 PM   #2
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 544
Re: Obtuse Inside Corners
Hire a drywall finisher has always been my go to.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following 2 Users Say Thank You to DaVinciRemodel For This Useful Post:
CScalf (09-04-2019), dielectricunion (07-05-2019)
Old 07-05-2019, 02:28 PM   #3
TheConstruct's Avatar
Rewards Points: 1,444
Check out No Coat Ultraflex
TheConstruct is online now
The Following 2 Users Say Thank You to TheConstruct For This Useful Post:
dielectricunion (07-05-2019), MarkJames (09-04-2019)
Old 07-05-2019, 04:33 PM   #4
Radical Basement Dweller
Robie's Avatar
Rewards Points: 8,242
I have a friend who grinds the desired curve into the edge of a 6" knife.
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
Old 07-05-2019, 05:52 PM   #5
Tom M's Avatar
Rewards Points: 8,232
I use straight flex they make a rubber knife for curved/scooped look. It's like a spatula.
https://www.homedepot.com/p/ToolPro-...8020/206926478
Tom M is online now
Old 07-05-2019, 06:33 PM   #6
micahmye's Avatar
Rewards Points: 64
A bat knife will be your friend! Also no-coat ultraflex is a good option.
micahmye is offline
The Following User Says Thank You to micahmye For This Useful Post:
Old 07-07-2019, 05:13 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,206
We used to use a 5" rubber sanding disk (the flexible kind) before they came out with one's with handles. It was known as a rubber ducky in the field.
Mike.
_______________
Calidecks is online now
Old 09-03-2019, 11:17 AM   #8
rounde683's Avatar
Trade: Electrician
Rewards Points: 32
Wet masonry sponge for a silky smooth finish.
Removed by staff
rounde683 is offline
Old 09-04-2019, 04:26 PM   #9
VinylHanger's Avatar
Rewards Points: 11,708
Sponges are a last resort. They tend to make scuffs and scratches, at a minimum.
VinylHanger is offline
