Not Strong Enough - Page 2 - Drywall - Contractor Talk
Not Strong Enough
Old 09-15-2013, 09:10 PM   #21
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
Re: Not Strong Enough
I am 230lbs short stocky and pretty solid, I sling around 4x12x5/8 pretty easy, but I work with a 53 yo guy who is skinny as a rail and has no problem doing the same thing. He says its all about technique for him. sure carrying them up steps is hard for him but you just need to learn to get it done.
ubcguy89 is offline
Old 09-20-2013, 05:58 PM   #22
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 13,024
I've found that the better you are with angling your body and spacial relations, the easier drywall is. It's when you don't have the load centered on the "weight" hang and you really start working your lower back and abs that it gets tough.
So yeah, do what these guys said, eat right, stretch early and often, keep your load balanced and if it feels wrong it probably is, adjust your stance. A single sheet of 1/2 should be virtually effortless once you've got your style down.
Also, your first post reminded me of one of my favorite Deep Thoughts with Jack Handy.
"It takes a big man to cry. It takes an even bigger man to laugh at that man."
Easy Gibson is offline
Old 09-22-2013, 03:00 PM   #23
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 268
If you can learn things , you can learn drywall, but its not for everyone...its a little strength, and a lot of technique . we had a guy on our crew 150 lbs 5'6" and he could move board...hang etc...so it can be done..but its also in your mind...that you have to control and conquer
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 09-30-2013, 02:30 PM   #24
B575JH's Avatar
Trade: Drywaller
Good news I've put on ten pounds since I started and the same belt size. That's all muscle. We've only done two drywall jobs in the last two months so it's hard to focus on technique.
B575JH is offline
Old 09-30-2013, 03:17 PM   #25
hdavis's Avatar
Rewards Points: 4,898
Keep at it
hdavis is online now
Old 09-30-2013, 09:05 PM   #26
ubcguy89's Avatar
Rewards Points: 742
I think the biggest thing with board is not that its that heavy especially 1/2'' but its awkward to carry.
ubcguy89 is offline
Old 10-01-2013, 04:01 AM   #27
Big Shoe's Avatar
Rewards Points: 1,918
I've hung thousands of boards...............It's all in the balance and technique.
You will figure it out eventually.
Expect the Unexpected
Big Shoe is offline
Old 10-01-2013, 11:02 AM   #28
Metal Stud Framer
Zendik's Avatar
Trade: Commercial Construction, Metal Stud, Drywall & Aco
Rewards Points: 152
If you are new to drywall then get out while you can.
It is a thankless brutal job that wears you out and leaves you in the gutter.
Go to school.
Zendik is offline
The Following 5 Users Say Thank You to Zendik For This Useful Post:
Ancient Rocker (10-05-2013), Inner10 (10-05-2013), JT Wood (10-01-2013), Morbidzero (10-03-2013), Mountain Man (10-05-2013)
Old 10-01-2013, 12:49 PM   #29
skillman's Avatar
Rewards Points: 1,968
Originally Posted by Zendik
If you are new to drywall then get out while you can. It is a thankless brutal job that wears you out and leaves you in the gutter. Go to school.
That's well said .
skillman is offline
Old 10-02-2013, 06:43 PM   #30
B575JH's Avatar
Trade: Drywaller
That sounds like a lot of things but I'm sure it's good advice. I'm sort of stuck with this lot in life for now just wanted to make the most of it.
B575JH is offline
Old 10-05-2013, 05:40 PM   #31
Ancient Rocker
Ancient Rocker's Avatar
Trade: drywall hanger
Rewards Points: 97
So am I, and I'm only 61.
Ancient Rocker is offline
Old 10-05-2013, 05:45 PM   #32
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,270
Go to school.
That should be a sticky on CT.
Welcome to a life of construction, get out while you can.
Inner10 is offline
Simpson Saddle Connectors strong for chicken coop? ForDoselCoop General Discussion 1 07-13-2011 10:02 PM
Is 1x IPE as strong as 2x oak? mehtwo Decks & Fencing 9 05-29-2011 10:43 AM
Is Foundation Strong Enough For 2nd floor addition? Vince10 General Discussion 11 02-23-2010 01:27 PM
Strong odor when starting Air Conditioner Since 1977 HVAC 15 08-18-2009 08:30 PM
toe nail or strong tie? erubin Drywall 2 09-28-2008 03:31 PM
