No Tape Drywall Patch - Drywall - Contractor Talk
Old 12-17-2018, 05:18 PM   #1
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,338
This how ya do them?
We used to call them blowout patches
No Tape Drywall Patch-img_0560.jpg   No Tape Drywall Patch-img_0563.jpg   No Tape Drywall Patch-img_0564.jpg   No Tape Drywall Patch-img_0566.jpg   No Tape Drywall Patch-img_0567.jpg
SmallTownGuy is offline
The Following 3 Users Say Thank You to SmallTownGuy For This Useful Post:
Robie (12-17-2018), Sir Mixalot (12-17-2018), Tom M (12-17-2018)
Old 12-17-2018, 05:30 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,721
Re: No Tape Drywall Patch
Nice.
Doing that, I would score and peel the surrounding paper so it's not doubled up in thickness.
Now, I'm in the habit of screwing some ply backer, filling the hole only (no overlap), and mudding with no tape whatsoever. It seems to work just fine. I clean all board edges with a sharp utility blade.
MarkJames is offline
Old 12-17-2018, 05:30 PM   #3
Radical Basement Dweller
Robie's Avatar
Rewards Points: 1,416
That's how I do mine. Will be doing one tomorrow.
When the debate is lost, slander becomes the tool of the losers.
Robie is offline
Old 12-17-2018, 05:32 PM   #4
Robie's Avatar
Originally Posted by MarkJames View Post
Nice.
It's going to be doubled in thickness if you use tape.
Robie is offline
Old 12-17-2018, 05:55 PM   #5
MarkJames's Avatar
If...but I don't.
Old 12-17-2018, 05:56 PM   #6
Tom M's Avatar
Rewards Points: 5,288
Even using lath or plywood backer they tend to suck in the middle. Paint layers I guess.
I do them quite a bit. I will also also flap that extra paper over a factory joint once in a while where it's out for site.
Tom M is online now
Old 12-17-2018, 08:33 PM   #7
Fixed's Avatar
Trade: HVAC
Rewards Points: 196
Up here we call them California patches (no idea why).
They're my favourite way to patch busted doorknob holes, etc. With hot mud it's awesome, mix some 5min up, goop her and good to go.
Sent from my SM-G935W8 using Tapatalk
Fixed is offline
The Following 2 Users Say Thank You to Fixed For This Useful Post:
Calidecks (12-17-2018), donerightwyo (12-17-2018)
Old 12-17-2018, 08:36 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 2
yup, california patch...
used all the time, drywallers & tapers are really fast at them...
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (12-17-2018), Sir Mixalot (12-17-2018)
Old 12-17-2018, 08:38 PM   #9
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 158
Not much work to screw a strip of backing back there.
Golden view is offline
The Following 5 Users Say Thank You to Golden view For This Useful Post:
blacktop (12-18-2018), Calidecks (12-17-2018), Expert Hanger (02-05-2019), Fixed (12-17-2018), Sir Mixalot (12-17-2018)
Old 12-17-2018, 08:39 PM   #10
Fixed's Avatar
Trade: HVAC
Rewards Points: 196
I think it's less about having to screw on backing and more about no mess, no tape, and then faster/easier to finish over it afterwards.
Fixed is offline
The Following User Says Thank You to Fixed For This Useful Post:
SmallTownGuy (12-18-2018)
Old 12-17-2018, 08:42 PM   #11
edward trowelhands
Trade: Diplomat
Rewards Points: 158
Backing doesn't change any of that, but it does strengthen it against a misplaced impact on the wall.
The Following 3 Users Say Thank You to Golden view For This Useful Post:
Calidecks (12-17-2018), Expert Hanger (02-05-2019), Tinstaafl (12-17-2018)
Old 12-17-2018, 08:52 PM   #12
Capra aegagrus
Tinstaafl's Avatar
If a doorknob punched that hole, odds are it'll happen again. I'm with the install backing crowd.
Tape? I've done it with and without, no callbacks. So... I dunno.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
blacktop (12-18-2018), Calidecks (12-17-2018), Sir Mixalot (12-17-2018)
Old 12-17-2018, 08:55 PM   #13
Fire up the BBQ
griz's Avatar
Rewards Points: 2
pretty much on anything but blow & go tract work, we put some sort of 2x blocking at door knob height.
griz is offline
Calidecks (12-17-2018), hdavis (12-17-2018)
Old 12-17-2018, 09:16 PM   #14
edward trowelhands
Trade: Diplomat
Rewards Points: 158
Yeah, I don't see tape being needed. It's a floating patch, no shear forces on it as the building moves. I can't see it cracking.
Old 12-17-2018, 09:31 PM   #15
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,439
These metal adhesive patches work pretty well for smaller holes too.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 70,000 Subscribers and over 11,000,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
The Following 4 Users Say Thank You to Sir Mixalot For This Useful Post:
avenge (12-18-2018), griz (12-17-2018), KAP (12-18-2018), Robie (12-17-2018)
Old 12-17-2018, 10:03 PM   #16
Mordekyle's Avatar
Rewards Points: 5,148
I donít have a picture, but my kids put doorknob holes in their adjacent rooms.
32Ē doors, one RH, one LH, left a hole in between the rooms that you could see through.
I went with some backing in the holes, figuring it will happen again.
Mordekyle is offline
The Following 2 Users Say Thank You to Mordekyle For This Useful Post:
hdavis (12-17-2018), KAP (12-18-2018)
Old 12-17-2018, 10:07 PM   #17
hdavis's Avatar
Rewards Points: 70
Backers take time, and you still have screw heads to deal with.
I'm not usually concerned about integrity on a small patch like that.
hdavis is offline
Fixed (12-17-2018)
Old 12-17-2018, 10:28 PM   #18
Capra aegagrus
Tinstaafl's Avatar
And a California patch doesn't take time? Screw heads or not, you still need a couple of coats for a nice job.
IMO, it's pretty much a wash between the two as far as application time, but it'll be a more solid repair if you use a backer. Sir Mix's mesh patch runs a close second.
The Following 4 Users Say Thank You to Tinstaafl For This Useful Post:
Calidecks (12-17-2018), Expert Hanger (02-05-2019), KAP (12-18-2018), Sir Mixalot (12-17-2018)
Old 12-17-2018, 11:00 PM   #19
hdavis's Avatar
Rewards Points: 70
One that size I do in 1 finish coat, no backer, no tape, no screw heads, no flaps on the patch.
hdavis is offline
Old 12-17-2018, 11:46 PM   #20
Fire up the BBQ
griz's Avatar
Rewards Points: 2
i knew a taper that used the metal screen.
he'd roughly clean up the hole, cut his screen, cut a rough drywall plug, then super glue it to the screen.
cut the paper away on the front, sort of to accommodate the thickness of the screen.
goop the back w/hot mud & set the screen in with hot mud.
sounds involved but he was absolutely wicked quick at doing this and the patch was flawless.
2-3 minutes, maybe at a patch and he was done.
california patch guys just shook their heads....
griz is offline
Ohio painter (03-18-2019), Sir Mixalot (12-18-2018)
Drywall Subcontractor NJ LouCHI Help Wanted or Looking For Work 0 08-08-2012 06:40 AM
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
35,000 sq ft of commercial drywall to tape kaiberg Drywall 16 04-13-2008 04:49 PM
tape all drywall seams before ceramic tile install? zmusashi General Discussion 3 08-24-2007 08:04 PM
tape all drywall seams before ceramic tile install? zmusashi Drywall 4 08-23-2007 11:23 AM
