Moisture Meters For Closing Up Walls, Ceilings - Drywall - Contractor Talk
Old 07-24-2018, 07:40 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 520
Since I should really be metering some of the patches I've been turning away, and doing some "wetter ones" - am looking for a reliable meter.
Are pins really needed or can it be pinless with the same accuracy ?
Will almost always use it on wall cavities, maybe trim every great once in a while before staining or sealing, etc.
As always, I'm not looking to break the bank on this one. So it doesn't have to be FLIR as much as I'd like to have one.
artinall is offline
Old 07-24-2018, 08:20 AM   #2
hdavis's Avatar
Rewards Points: 2,038
Re: Moisture Meters For Closing Up Walls, Ceilings
I'd go with a combination unit like the Extech MO55. Around $100.
The problem with just having pins is there is noticeable damage to trim.
I use a Lignomat pin type, and a thermal imager.
hdavis is online now
artinall (07-24-2018)
Old 07-24-2018, 04:18 PM   #3
artinall's Avatar
Rewards Points: 520
THX will look into. Didn't know there were combo's. Amazon $82.
Wondering if those pins will leave noticeable indents in drywall?
- Yeh I won't always be able to pin the backside of stock trim. Used to do custom home casework where they'd let it dry out days 1st.
artinall is offline
Old 07-24-2018, 04:25 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 620
for many years i dealt with moisture content of various materials.
i do not recall the reason but pin type meters were not acceptable to the inspectors.
Wagner was/is the accepted trade standard for moisture meters.
https://www.wagnermeters.com/moistur...oaAvoKEALw_wcB
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
artinall (07-25-2018), Robie (07-24-2018)
Old 07-24-2018, 10:18 PM   #5
Radical Basement Dweller
Robie's Avatar
Rewards Points: 7,626
That's what I own.
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
griz (07-24-2018)
Tips on the fastest way to prefab walls? roscoe8423 Framing 16 04-09-2014 08:22 PM
Faulty Masonry construction at Moore School cdkyle Masonry 6 02-24-2014 12:46 PM
chain smokers and painting ceilings toolman65 Painting & Finish Work 11 09-15-2012 09:05 PM
Moisture barriers between footing and CMU walls. RMcBride Masonry 14 10-20-2010 10:02 PM
Share your techniques for access panels in finished ceilings and walls Dustball Carpentry 9 07-14-2007 07:27 PM
