Mesh Tape Question??? - Page 7 - Drywall - Contractor Talk
Old 02-18-2015, 05:30 PM   #121
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
Re: Mesh Tape Question???
Originally Posted by blacktop View Post
You talking about this?
this it simply the best
dont work hard...work smart
icerock drywall is offline
Old 02-18-2015, 05:35 PM   #122
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 214
Not sure If I would go that far Ice.
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 02-18-2015, 10:18 PM   #123
Trade: drywaller
Rewards Points: 930
if you install it right it is the best ....well that is the way I feel
Old 02-18-2015, 10:24 PM   #124
Drywall Slave
blacktop's Avatar
Rewards Points: 214
To apply it correctly the flange will need to be paper taped tight to the center. That's the only way I can see it will hold up. JMO!
blacktop is offline
Old 02-18-2015, 11:07 PM   #125
Trade: drywaller
Rewards Points: 930
I use the 847 ...dont like the mud set for the magic corner and yes I do ff the flange ...they say you dont need it I just like to do it
I did a test peace and you cant pull it apart ...it is strong and yes I tested all the other way and my kids can pull it apart paper ff straight flex dont pass my test
but 847 with ff or straight flex will pass
The Following User Says Thank You to icerock drywall For This Useful Post:
blacktop (02-19-2015)
Old 02-25-2015, 01:59 PM   #126
Trade: drywaller
Rewards Points: 930
as most of you know I am a fiba-fuse user ....I use to use mesh and durabond on my first coat and never had one call back
I am going into the city to do a job and I only have a day to do it so I am going old school. I am going to use Extra Strength mesh tape on my butts and seams and just mesh tape in the corners. my tape coat will be ezsand 20 with mud max mixed into it. 2nd and 3rd coat will be exsand 20. my outside corners will be trim-tex 847 ...3 coats one day
If the gaps are filled and you use hot mud mesh will work and adding mud-turns any mud to durabond. so why not use durabond well if I stay with one type of mud I will not get bubbles
I did the city job yesterday and I did it like I said ...but I did NOT like the Extra Strength mesh tape
1) it needed to be more sticky
2) its a little to thick
3) some of the fibers pop up and sticks out the 2nd coat
illbuildit.dd (02-25-2015)
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 88 09-01-2014 09:30 PM
Mesh Tape Thompson Drywall 37 11-06-2013 12:31 AM
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
How do you tape? Al Taper Drywall 10 12-03-2009 11:16 PM
Tape measure question Mike Finley Tools & Equipment 60 03-26-2006 10:35 PM
