A Line Appears Around Patch/mud Edge When Paint Is Applied - Drywall - Contractor Talk
Old 08-30-2019, 07:00 AM   #1
ContractorStevv's Avatar
Rewards Points: 86
I'm no mudder by trade and have always had problems trying to mud. Yesterday was another one of those days when a small job turned into a failure when I put paint to a small patch and a line around the patch appeared, regardless of how smooth I sanded the patch edges. Indeed, I sanded until I made sure I couldn't feel any edge between the wall and the mud edge. I thought I had it done perfectly this time. I wiped down the area with a wet cloth to remove the dust and when I applied a light coat of paint a line appeared right around the whole mud edge ... err! I applied another light coat and then two heavier coats with no success. Any reasons for this?
ContractorStevv is offline
Old 08-30-2019, 09:10 AM   #2
hdavis's Avatar
Rewards Points: 2,516
Re: A Line Appears Around Patch/mud Edge When Paint Is Applied
Without pics, it's just guessing. You shouldn't have to sand to feather the edges, they should have been feathered when you applied the mud so the edges are translucent.
If you are using bucket mud, a wet wipe down can make results worse if you overdo it. You can use a foxtail brush, vacuum, or microfiber cloth to get the dust off.
Feeling isn't good enough to catch everything. A strong grazing light is your best bet.
hdavis is offline
The Following 4 Users Say Thank You to hdavis For This Useful Post:
Caleb1989 (09-23-2019), Calidecks (08-30-2019), ContractorStevv (08-30-2019), Idothat (08-30-2019)
Old 08-30-2019, 09:22 AM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,069
Maybe you're just seeing paint moisture absorbed into the compound (which will eventually go away).
As for getting smooth transition at the edges, use an LED flashlight to check both your application and any sanding you may need. You don't need anything too big or fancy. Pocket light will work.
MarkJames is offline
Old 08-30-2019, 09:55 AM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 752
Could be you are not feathered out/blended as good as you think you are.
New patch absorbing paint at a different rate than the old work.
Paint not blended/feathered properly.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
ContractorStevv (08-30-2019), Tom M (08-30-2019)
Old 08-30-2019, 10:01 AM   #5
Rewards Points: 86
I think I have too options. (1) to go back and re-sand these edges to perfection, brush off the dust rather than wipe it down with a wet towel, and repaint. Or (2) lay on a few really heavy coats of paint and cross my fingers, although I've never had much luck with paint hiding anything.
Old 08-30-2019, 10:07 AM   #6
hdavis's Avatar
Originally Posted by ContractorStevv View Post
I think I have too options. (1) to go back and re-sand these edges to perfection or (2) lay on a few really heavy coats of paint and cross my fingers, although I've never had much luck with paint hiding anything.
Forget about sanding after paint is on. Go back and feather it with mud.
Relying on sanding is going to keep you from learning how to get your application and detailing right.
hdavis is offline
Old 08-30-2019, 10:07 AM   #7
Rewards Points: 86
I think this could have been my mistake, when moisture from the wet towel hit the edge, which is the thinnest part of the mud and created the problem.
The Following User Says Thank You to ContractorStevv For This Useful Post:
Old 08-30-2019, 10:07 AM   #8
KAP's Avatar
Trade: Custom
Rewards Points: 36,988
Wiping it with water and painting right after was most likely your issue...
KAP is offline
The Following 5 Users Say Thank You to KAP For This Useful Post:
Big Shoe (09-30-2019), Calidecks (08-30-2019), ContractorStevv (08-30-2019), Idothat (08-31-2019), MarkJames (08-30-2019)
Old 08-30-2019, 10:10 AM   #9
Texas Wax's Avatar
Rewards Points: 2,000
or quick sand & skim of the effected areas. Good heavy but even shot of primer and re-paint. Covers all the possibilities except shiners with high(er) gloss paints.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following 2 Users Say Thank You to Texas Wax For This Useful Post:
Old 08-30-2019, 10:14 AM   #10
MarkJames's Avatar
Yup, just wipe the dust with a dry rag or bare hand. After that, I spray it with a quick thin coat of oil-based spray primer (eg. kilz), along with a piece of cardboard to catch overspray. It'll dry quick. Then paint.
Be prepared to repaint an entire wall or area, sometimes it's the quickest way for a good result...it just goes with the territory. Charge for it, of course.
Or leave it "primed only" so they can do it themselves.
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
Old 08-30-2019, 07:00 PM   #11
Tom M's Avatar
Rewards Points: 8,256
Was it setting compound? There have been times I've done a bathroom and could have sworn I sanded that smooth as could be and see an edge and some odd lighting.
I use AP for my second and finish coats now only.
Tom M is offline
Old 08-30-2019, 10:29 PM   #12
Rewards Points: 86
I used Dap pink spackling. It's the stuff that turns white when it's dry, in about 4-5 hours with a light coat. I'm wondering too if that is the problem. Sheetrock 45 might have been a better choice.
Old 08-30-2019, 10:55 PM   #13
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,270
Seal it first. Use a drywall sealer. Helps remove a lot of the inconsistent moisture absorption.
Mike.
_______________
Calidecks is offline
ContractorStevv (08-31-2019), Idothat (08-30-2019), Tom M (08-31-2019)
Old 08-30-2019, 10:57 PM   #14
GC/carpenter
Calidecks's Avatar
Hotmud should've been your choice. That pink dap is for pinholes from pictures and nails.
Mike.
_______________
The Following 4 Users Say Thank You to Calidecks For This Useful Post:
Caleb1989 (09-23-2019), ContractorStevv (08-31-2019), Dirtywhiteboy (08-30-2019), Idothat (08-30-2019)
Old 08-30-2019, 11:21 PM   #15
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Green bucket mud for tight skims. Gardz to seal it.
EricBrancard is offline
The Following 4 Users Say Thank You to EricBrancard For This Useful Post:
allaboutfun (09-04-2019), ContractorStevv (08-31-2019), Dirtywhiteboy (08-30-2019), Idothat (08-30-2019)
Old 08-31-2019, 05:18 AM   #16
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
That ****'s nasty.
SmallTownGuy is offline
Old 08-31-2019, 08:25 AM   #17
Tom M's Avatar
I use th pink crap to fill nail holes in trim once in a while. Couldn't imagine doing a room with it.
Tom M is offline
Calidecks (08-31-2019)
Old 08-31-2019, 11:28 AM   #18
test
cedarboarder's Avatar
Trade: General
Rewards Points: 2,301
I need a picture... But pretty sure he has a patch flash.
If so you need to skim coat the wall with mud. And NOT with pink fluff hehe.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 09-02-2019, 07:42 PM   #19
VinylHanger's Avatar
Rewards Points: 11,722
Who told you, OP, that the pink stuff was for patching holes?
That's just goofy.
VinylHanger is online now
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
avenge (09-02-2019), Calidecks (09-02-2019)
Old 09-02-2019, 09:45 PM   #20
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,657
Whenever you think that you have sanded the edges smooth, close your eyes and run your fingers over the edges. By removing one sense, your sense of touch is heightened and you can oftentimes feel a discrepancy.
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
ContractorStevv (09-08-2019)
