Lightweight Board - Page 3 - Drywall - Contractor Talk
Lightweight Board
Old 03-27-2015, 08:17 PM   #41
OMB's Avatar
Trade: Building, Excavating
Rewards Points: 142
Re: Lightweight Board
Originally Posted by blacktop View Post
I don't ! I make do tho!
Since 07 Every product I use has gone down hill. The wallboard ,The mud formulas , The wallboard glues ...Everything has gone to chit. Thanks to the tree huggers and the greedy manufactures .
Before 2007 ..I never had a problem with the sheetrock . Then comes along Certainteed ! JUNK! Then the lightwieght ! JUNK!
In 2011 they changed the formula in my Black top . For the worse .It ain't the same !
The wallboard glue will wash off your hands now with soapy water . That's not glue!!!!
I keep thinking these aholes will start caring about the trades that use their products . But I don't see that happening any time soon .
I think this is referred to as "progress".
I read a paper by USG (I think) about the water based glue (read no VOCs) shrinking back and causing mushrooms over screws, fix one problem (the treehuggers) and create another.
If one manufacturer still made good board you would think the others would lose enough market share to make some of the others bring back quality products, why don't you guys that are big buyers have a chat with the factory reps? I get it- you will always have some crap material showing up at Lowe's but come on, why can't pros still get real board?
OMB is offline
Old 03-27-2015, 08:47 PM   #42
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 276
Well first of all ! Factory reps are Idiots! Trust me ! I've met enough of these ties to know . They only care about looking after themselves !
I gave up on the reps in 2010. They still call me from time to time and I always tell them the same ... I'm Still fixing your chit!
USG Regular board is the best of the worst IMO. But.. The drywall suppliers and building suppliers here wont carry It. Cost too much!
I haven't seen a piece of USG Regular board in 6 years. The only way I can get It Is to open my own supply house ! And that ain't happening no time soon !!
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 03-27-2015, 09:45 PM   #43
hdavis's Avatar
Rewards Points: 1,556
I can get that any where around here, even HD.
hdavis is offline
Old 03-27-2015, 09:49 PM   #44
Drywall Slave
blacktop's Avatar
Rewards Points: 276
Certainteed took hold here . I have to beg for National gyp !!!
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
hdavis (03-27-2015)
Old 03-27-2015, 11:07 PM   #45
hdavis's Avatar
I'd be begging for them to take the NG back
hdavis is offline
Old 03-28-2015, 07:27 PM   #46
Drywall Slave
blacktop's Avatar
Rewards Points: 276
Let me send you a few hundred boards of Certainteed to finish out !! I'll bet you'll change your tune then!
Let's see........I think I'll send It to ya from the West Virginia plant !!
The reps name is Jerry. I have his number. You'll need it when you start the block coat!
blacktop is offline
Old 03-28-2015, 08:54 PM   #47
hdavis's Avatar
Free drywall? Heck, yeah!
hdavis is offline
Old 03-29-2015, 08:00 AM   #48
Ancient Rocker
Ancient Rocker's Avatar
Trade: drywall hanger
Rewards Points: 97
I have hung enough CertainTeed drywall to know even if it is free, you are losing money.
If you think hiring a professional is expensive, wait until you see what an amateur costs.
Ancient Rocker is offline
The Following User Says Thank You to Ancient Rocker For This Useful Post:
blacktop (03-29-2015)
Old 03-29-2015, 08:08 AM   #49
hdavis's Avatar
Not if I sell it on CL - somebody would buy.
hdavis is offline
Old 03-29-2015, 09:17 PM   #50
MarcoPollo's Avatar
Rewards Points: 250
Quick question for the full timers. Can someone give me a link to wallboard adhesive?
I've never seen or used it by anyone and am intrigued?
I always just double screw all my joints and when doing a full gut run strapping on 12" centres.
All thanks in advance.
MarcoPollo is offline
Old 03-30-2015, 07:01 AM   #51
mako1's Avatar
Rewards Points: 1,094
When we screw and glue we use PL400
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
hdavis (03-30-2015)
Old 03-30-2015, 04:19 PM   #52
Drywall Slave
blacktop's Avatar
Rewards Points: 276
Is that sub-floor glue?
blacktop is offline
Old 03-30-2015, 04:21 PM   #53
MarcoPollo's Avatar
Rewards Points: 250
It is but lower grade. It's panelling grade glue I believe is what's marked on the tube.
What do you use for adhesive blacktop?
Old 03-30-2015, 04:23 PM   #54
Drywall Slave
blacktop's Avatar
Rewards Points: 276
Since everything has gone green..Ones as good as the other !
blacktop is offline
Old 03-30-2015, 04:43 PM   #55
Drywall Slave
blacktop's Avatar
Rewards Points: 276
The tight bond is great to work with Not a tight bond tho.. It's weak.
The OSI has two types . OSI Wallboard /panel glue is the one that's like a tube of water ! The OSI Standard wallboard glue is a good glue with a good bond . But they both can haze over very quickly ..So the fields need to be screwed off asap. The liquid nails is similar to tight bond..Nice to work with but If ya get it on your hands You can wash it off with soapy water! That's not a tight bond !
I can remember when getting a glob of wallboard glue on my arm was an emergency ....Cause It would start to burn !!! And if not removed soon It would leave a mark.. Wallboard glues aren't like that anymore..
blacktop is offline
Old 03-30-2015, 08:34 PM   #56
hdavis's Avatar
There are still some solvent based glues, which usually don't shrink as much when they dry as the water based. If I need time for hanging, I'll sometimes use Gripper (it's general purpose water based) - it doesn't haze over as fast as most of the others.
hdavis is offline
blacktop (03-31-2015)
Old 03-31-2015, 07:50 AM   #57
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
Learning a lot from reading what you guys are sharing here, so thanks for that!
Apparently, I am pretty ignant about drywall, and all things related, so I wanted to ask you a question: What is "black top"?
Jeff G is offline
Old 03-31-2015, 04:01 PM   #58
Drywall Slave
blacktop's Avatar
Rewards Points: 276
blacktop is offline
The Following 2 Users Say Thank You to blacktop For This Useful Post:
hdavis (03-31-2015), Jeff G (03-31-2015)
Kerdi Board to Drywall Stunt Carpenter Kitchens & Baths 5 06-18-2013 12:11 AM
Board form concrete wall water stains DerekRC Concrete & Paving 0 12-06-2011 01:44 PM
determining skirt board height romoranger Finish Carpentry 2 07-07-2009 01:46 PM
Plywood over particle board PA woodbutcher Flooring 5 03-11-2009 06:09 AM
