Level 5 - Drywall - Contractor Talk
Level 5
Old 09-01-2008, 11:23 AM   #1
Adam in BC's Avatar
Trade: Drywall Contractor
Rewards Points: 25
Level 5
How are the rest of the pros in here getting to a level 5 finish ?
currently I ; bed tapes, 3 coats (2 in angles) and spray/back roll synko pre coat.
I am tossing around the idea of picking up a grayco mark 4, but wonder how much sanding will be involved after spraying thinned down finishing mud, and/or what kind of finish I will get, as opposed to the high build underbody im using now.
I am happy with the finish im getting now, but wonder if I can spray a fairly thick coat ,if it will replace my third (skim coat) and also save buckets of $ by replacing the expensive pre coat with affordable topping mud ?
Adam in BC is offline
Old 09-01-2008, 01:55 PM   #2
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Rewards Points: 250
Re: Level 5
The Mark(s) do a great job with skim-coating. I shot mud through it with a big tip and did not wipe it down or sand it but for a glass like finish I would probably squeegee it down. With just shooting mud through the tip it gave the surface an almost back-rolled look and great for a level five finish, IMO. Hope this helps.
Brockster is offline
Old 09-02-2008, 01:52 PM   #3
Muddauber's Avatar
Trade: drywall
Rewards Points: 250
Re: Level 5
Brockster,
Will a smaller unit do the job, or does it require a Mark IV or V?
Muddauber is offline
Old 09-03-2008, 05:57 PM   #4
Brocktologist llc.
Brockster's Avatar
Trade: drywall
Rewards Points: 250
Re: Level 5
Originally Posted by Muddauber View Post
Brockster,
I'm not sure but I'd think you'd want a bigger unit to handle spraying mud constantly, plus you can have two guns spraying at the same time for prime and paint with the Mark's.
Split Level Foyer, Fixture Replacement ?? BACKWOODS Electrical 9 11-16-2008 09:42 PM
concrete block installed out of level pawlooch Masonry 10 05-04-2008 10:41 AM
Level decks XanadooLTD Decks & Fencing 22 04-25-2008 11:25 PM
level decks on the top floors adman1900 Carpentry 1 11-11-2006 11:20 AM
