Lead Lined Drywall - Drywall - Contractor Talk
Lead Lined Drywall
Old 07-12-2012, 08:18 PM   #1
Carpenter
woodbutchr's Avatar
Rewards Points: 150
Lead Lined Drywall
I'm remodeling a CT room in a hospital & it has lead lined drywall that I've got to hang & finish. I've never messed with it before, what do y'all think is the best way to cut it?
Thanks,
Jim
woodbutchr is offline
The Following User Says Thank You to woodbutchr For This Useful Post:
skyhook (07-14-2012)
Old 07-12-2012, 08:21 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Lead Lined Drywall
I have no idea. I demo'd some of that stuff, it SUCKED. I cant even imagine what the epa wants you to do to install it. Sounds like $750 per sheet to me..
ohiohomedoctor is offline
Old 07-12-2012, 08:32 PM   #3
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,465
Here ya go http://www.radiationproducts.com/gypsum-board.htm
-Paul
TextureMaster.com
Checkout my YouTube Channel with 70,000 Subscribers and over 11,000,000
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
Old 07-12-2012, 10:21 PM   #4
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
Thanks,
Jim
You can hang the lead by itself( if that is specd as an option or can get approved) it comes on roll, real heavy, but need a longer screw for the drywall after. You cut with a knife
iDAHOchris is offline
Old 07-12-2012, 10:24 PM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,986
It cuts like butter, knife or drywall saw, never hung it but I put AV systems in multiple dental offices that used lead clad drywall.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
Big Shoe (07-13-2012), woodbutchr (07-13-2012)
Old 07-13-2012, 03:24 AM   #6
chewy's Avatar
Trade: Electrical Apprentice and Data Technician.
Rewards Points: 1,208
I worked on a Hospital upgrade, totally gutted and refitted. In certain procedure rooms with Xray facilities they used lead lined plasterboard. Our outlet boxes had to be screwed down onto 2mm lead foil which was folded up behind them to prevent radiation escaping through the electrical and network outlets. The plasterboard didnt seem to any more difficult to cut with a normal jab saw when we had to cut open buried boxes...
chewy is offline
Old 07-13-2012, 06:10 AM   #7
Carpenter
woodbutchr's Avatar
Rewards Points: 150
Thanks y'all. With it being as soft as it is I kinda thought it would be fairly simple to cut but I didn't know for sure, I was hoping anyway.
I started demo on the room yesterday and what a PITA!! There's 1/8" on the walls now, heavy chit. I'm going back with 1/16" as per plans so one sheet will be around 200lbs, not as bad as what I'm taking down.
Old 07-13-2012, 09:37 AM   #8
I wonder if there is a chance of radiation exsposure demoing an exisitng lead lined wall that has been exposed to radiation?
-Paul
TextureMaster.com
Old 07-13-2012, 11:22 AM   #9
Carpenter
woodbutchr's Avatar
Rewards Points: 150
I sure the h3ll hope not!
Old 07-13-2012, 12:07 PM   #10
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
I'm also interested to hear how this is done under RRP as it contains lead. Do you have to be RRP compliant to install it as well as remove it?
Just spoke to me mate who does a lot of this kind of work. I knew some of this but he said it don't require nothing under RRP even when installed in residential applications. He said just like stuff like floor coverings, bathtubs, pipe work etc etc He said under commercial the demo has to be done under OHSA's hazardous materials removal section for radio active waste. He said he ain't had to demo it for years so the laws could be much stricter now that Lead is also considered hazardous.
www.bcconstructionllc.com
BCConstruction is offline
Old 07-13-2012, 12:26 PM   #11
Well they do reuse those lead aprons everytime they do an xray. So hopefully not.
-Paul
TextureMaster.com
Old 07-13-2012, 07:27 PM   #12
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Did the same thing in a chiropractors office once. If I remember right we cut it with a utility knife. Just unrolled it and had another guy to help hoist that stuff up.
I always wondered about the X rays transferring through the screws. We just used reg. drywall screws.
I don't think the RRP has anything to do with it. It's basically encapsulated behind 1/2" of rock. No lead dust can be generated.
Paulie is offline
Old 07-13-2012, 08:06 PM   #13
There's a small lead disk that should go over the screw head.
-Paul
TextureMaster.com
Old 07-14-2012, 05:47 AM   #14
Big Shoe's Avatar
Rewards Points: 2,064
Yes, those lead disk are a real pain. You end up floating over those things, there's no way to get them recessed.
Also you would have 2'' wide rolls of it to go behind all the seams and corners.
I have done both rolled lead and the lead board......Always a lot of fun..............Not
Expect the Unexpected
Big Shoe is offline
Old 07-14-2012, 06:21 AM   #15
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
One thing you have to consider is that there is a difference between using lead as a solid sheet of material vs. it being in paint, gasoline, or any other substance where it is in particle form and can be inadvertently inhaled.
tedanderson is offline
Old 07-14-2012, 06:47 AM   #16
Carpenter
woodbutchr's Avatar
Rewards Points: 150
The walls I tore down did not have screw caps and the box penetrations were not wrapped!
This hospital has been around a long time too. If only them nurses over the years knew.......
Old 07-14-2012, 06:58 AM   #17
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Exclamation
Great discussion.
skyhook is offline
Old 07-14-2012, 07:21 AM   #18
Paulie's Avatar
I honestly can't remember if we were given the disks or not. But it did ring a bell because we had a dickens of a time finishing the seams as the tape showed in several spots after a sand.
I can't imagine how to make a repair if a gurney makes a hole in the wall.
Paulie is offline
Old 07-14-2012, 07:37 AM   #19
Inner10's Avatar
I can tell ya from the last two I worked on one is only 4 or 5 years old and the other is probably 30...neither one had boxes wrapped. Not to mention there was nothing special in the ceiling...what about the people above?
Inner10 is offline
Old 07-14-2012, 07:47 AM   #20
Good question. Come to think of it, I don't think the doors were protected on the couple that I have done.
-Paul
TextureMaster.com
Priming & Painting drywall Repairs, not new drywall mcgyver79 Painting & Finish Work 21 04-23-2013 03:47 PM
Drywall GettingBy General Discussion 3 06-16-2011 12:58 PM
Lead Paint, What's Involved? Dyer Sandblasting 37 03-11-2010 06:21 AM
Lead Company Issues Lead Guy Online Leads Services 55 11-17-2009 10:31 PM
