-   Drywall (https://www.contractortalk.com/f49/)
-   -   Lead lined drywall (https://www.contractortalk.com/f49/lead-lined-drywall-120386/)
woodbutchr 07-12-2012 08:18 PM
Lead lined drywall
I'm remodeling a CT room in a hospital & it has lead lined drywall that I've got to hang & finish. I've never messed with it before, what do y'all think is the best way to cut it?
Thanks,
Jim
ohiohomedoctor 07-12-2012 08:21 PM
I have no idea. I demo'd some of that stuff, it SUCKED. I cant even imagine what the epa wants you to do to install it. Sounds like $750 per sheet to me..
Sir Mixalot 07-12-2012 08:32 PM
Here ya go http://www.radiationproducts.com/gypsum-board.htm :thumbsup:
iDAHOchris 07-12-2012 10:21 PM
Thanks,
Jim
You can hang the lead by itself( if that is specd as an option or can get approved) it comes on roll, real heavy, but need a longer screw for the drywall after. You cut with a knife
Inner10 07-12-2012 10:24 PM
It cuts like butter, knife or drywall saw, never hung it but I put AV systems in multiple dental offices that used lead clad drywall.
chewy 07-13-2012 03:24 AM
I worked on a Hospital upgrade, totally gutted and refitted. In certain procedure rooms with Xray facilities they used lead lined plasterboard. Our outlet boxes had to be screwed down onto 2mm lead foil which was folded up behind them to prevent radiation escaping through the electrical and network outlets. The plasterboard didnt seem to any more difficult to cut with a normal jab saw when we had to cut open buried boxes...
woodbutchr 07-13-2012 06:10 AM
Thanks y'all. With it being as soft as it is I kinda thought it would be fairly simple to cut but I didn't know for sure, I was hoping anyway.
I started demo on the room yesterday and what a PITA!! There's 1/8" on the walls now, heavy chit. I'm going back with 1/16" as per plans so one sheet will be around 200lbs, not as bad as what I'm taking down.
Sir Mixalot 07-13-2012 09:37 AM
I wonder if there is a chance of radiation exsposure demoing an exisitng lead lined wall that has been exposed to radiation?
woodbutchr 07-13-2012 11:22 AM
I sure the h3ll hope not!
BCConstruction 07-13-2012 12:07 PM
I'm also interested to hear how this is done under RRP as it contains lead. Do you have to be RRP compliant to install it as well as remove it?
Just spoke to me mate who does a lot of this kind of work. I knew some of this but he said it don't require nothing under RRP even when installed in residential applications. He said just like stuff like floor coverings, bathtubs, pipe work etc etc He said under commercial the demo has to be done under OHSA's hazardous materials removal section for radio active waste. He said he ain't had to demo it for years so the laws could be much stricter now that Lead is also considered hazardous.
Sir Mixalot 07-13-2012 12:26 PM
Well they do reuse those lead aprons everytime they do an xray. So hopefully not.:thumbsup:
Paulie 07-13-2012 07:27 PM
Did the same thing in a chiropractors office once. If I remember right we cut it with a utility knife. Just unrolled it and had another guy to help hoist that stuff up.
I always wondered about the X rays transferring through the screws. We just used reg. drywall screws.
I don't think the RRP has anything to do with it. It's basically encapsulated behind 1/2" of rock. No lead dust can be generated.
Sir Mixalot 07-13-2012 08:06 PM
There's a small lead disk that should go over the screw head. :nuke:
http://www.radiationproducts.com/images/gypsum2.gif
Big Shoe 07-14-2012 05:47 AM
Yes, those lead disk are a real pain. You end up floating over those things, there's no way to get them recessed.
Also you would have 2'' wide rolls of it to go behind all the seams and corners.
I have done both rolled lead and the lead board......Always a lot of fun..............Not:laughing:
tedanderson 07-14-2012 06:21 AM
One thing you have to consider is that there is a difference between using lead as a solid sheet of material vs. it being in paint, gasoline, or any other substance where it is in particle form and can be inadvertently inhaled.
woodbutchr 07-14-2012 06:47 AM
The walls I tore down did not have screw caps and the box penetrations were not wrapped! :blink:
This hospital has been around a long time too. If only them nurses over the years knew.......
skyhook 07-14-2012 06:58 AM
Great discussion. :thumbsup:
Paulie 07-14-2012 07:21 AM
I honestly can't remember if we were given the disks or not. But it did ring a bell because we had a dickens of a time finishing the seams as the tape showed in several spots after a sand.
I can't imagine how to make a repair if a gurney makes a hole in the wall. :sad:
Inner10 07-14-2012 07:37 AM
I can tell ya from the last two I worked on one is only 4 or 5 years old and the other is probably 30...neither one had boxes wrapped. Not to mention there was nothing special in the ceiling...what about the people above?
Sir Mixalot 07-14-2012 07:47 AM
Good question. Come to think of it, I don't think the doors were protected on the couple that I have done.:no:
