Latex Migration? - Drywall - Contractor Talk
Latex Migration?
Old 03-09-2012, 03:01 PM   #1
Remodeling GC
kevjob's Avatar
Rewards Points: 2,670
Latex Migration?
I am having issues on my bathrooms where replace only part of the drywall. We have to skim what is left and re-texture.
My drywall sub has used durabond, light weight mud, regular mud, topping mud. The issue is small pin hole sized bubbles in the mud.
1st coat over old drywall comes out fine, all other coats leave pin holes sized bubbles to the point where he is skimming it 3-4 times.
It was recommended that we use oil base primer over old drywall before skimming.
Any body run into a similar issue?
kevjob is offline
Old 03-09-2012, 04:22 PM   #2
Probity Drywall's Avatar
Trade: Drywall Contractor
Rewards Points: 25
Re: Latex Migration?
Yes and you can keep skiming and skiming the pin holes will still come. The moisture cant soak into the wall so it escapes through the finish coat. i like to paint with synko pre coat. It comonly fills those pin holes, but if not pre coat is sandable and that will get rid of them. Or prime skim, sand and prime again. I don't know about oil base. Hope this helps
Probity Drywall is offline
Old 03-09-2012, 04:34 PM   #3
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,431
This has been discussed before.
Some members have said that by adding a little dawn dish detergent can help resolve this problem.
I personally have not tried this method though.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
Old 03-09-2012, 04:57 PM   #4
manipulator of wood
I Mester's Avatar
Trade: general contractor
only dawn? ajax wont work? just kidding. i've heard that too. just never got around to trying it. . pain in the a$$
I just love the smell of sawdust in the morning!
I Mester is offline
Old 03-09-2012, 05:05 PM   #5
Rewards Points: 25
I know some tapers who use dish soap for fresh board. I could'nt find a difference except my work area smelled nice.
Old 03-09-2012, 05:13 PM   #6
boman47k's Avatar
Rewards Points: 2,006
I was wondering if maybe the mud was being mixed too much/vigorously (air), but the first coat being okay is confusing.
I have used Dawn to make the mud creamier for a finish coat. Been a while.
Maybe let it slake a bit longer before applying it to the wall?
boman47k is offline
Old 03-09-2012, 05:16 PM   #7
hdavis's Avatar
Rewards Points: 1,216
It helps, but doesn't always eliminate it. Also, it does little if the hot mud underneath isn't dry enough.
hdavis is offline
Old 03-09-2012, 06:06 PM   #8
boman47k's Avatar
Also have to wonder if enough drying time is being allowed for the conditions. Is the bathroom being used at night between coats?
boman47k is offline
Old 03-09-2012, 06:11 PM   #9
Remodeling GC
kevjob's Avatar
No, vent fan is running but I am curious if curing time has anything to do with it. normally we can get on the regular mud the next day as we have a dry climate here.
Stumped.
kevjob is offline
Old 03-09-2012, 06:40 PM   #10
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
Try using a high build drywall primer and sand it down. I like duron new construction drywall primer.
It sands down like a champ and can be applied at very high mils.
JHC is offline
Old 03-09-2012, 06:43 PM   #11
Rewards Points: 25
Coating over wet mud will cause this and fast set doesn't help because it locks in the moisture. When aplying the finish coat working the mud in limits the problem a great deal.
Old 03-09-2012, 07:03 PM   #12
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
Best thing you can do is overwork it. What I mean is taking a couple xtra swipes wont hurt and even if its been on wall/patch for a minute or too. You will see the pinholes forming as the mud is drying ...take another swipe. It helps
iDAHOchris is offline
Old 03-09-2012, 07:07 PM   #13
iDAHOchris's Avatar
Rewards Points: 256
also if you are able to rough up painted walls before skim and retexturing it will help. Sounds like just over the painted surface. Dont think oil primer would help as that would just seal the wall even more. Oil primer helps on damaged walls to prevent blistering
Old 03-09-2012, 09:08 PM   #14
boman47k's Avatar
No problems with other rooms where you do this same repair?
boman47k is offline
The Following User Says Thank You to boman47k For This Useful Post:
Metro M & L (03-09-2012)
Old 03-09-2012, 11:31 PM   #15
3rdgen's Avatar
Trade: drywall
Rewards Points: 31
How thick of a skim coat is he applying? I get these pin holes where the mud is deep (where patches meet existing) but where we are just skimming the texture out the mud doesn't need to bury the texture on the first coat. Two fairly tight skim coats works well and you only have to deal with the pin holes in a few areas. It seams like every once in a while I get that employee that was taught to BURY THAT TEXTURE and I gotta straiten him out. When the mud is eased on its not deep enough to gas out it can dry from the top easily. The other nice part about not putting a lot of mud on a painted wall is that it will actually dry over night not sit wet for a day or two. We do our first skim coat let it dry the next day the angle box runs nice through the angles (with fairly stiff mud) let them set up a bit and throw the second skim coat on and she ready!!
3rdgen is offline
Cleaning frozen latex paint brushes bernielogan Painting & Finish Work 24 12-11-2014 08:15 AM
latex paint wont stick to latex primer dougfra Painting & Finish Work 8 11-02-2012 09:17 PM
Latex over Oil base paint is peeling iceman61 Painting & Finish Work 19 10-15-2008 11:44 PM
latex semi gloss over oil semi gloss - can it be done? Zeebo Painting & Finish Work 13 09-05-2007 05:38 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
