Laminate Drywall Advice - Drywall - Contractor Talk
Old 02-05-2019, 08:04 PM   #1
DoubleTrouble's Avatar
Rewards Points: 18
Evening everyone.
Working on another flip and since this one is "just a rental" we are not inventing much time nor money into the house. The house was built in the early 1900's so at this point nothing is plumb, level or square. We had to rewire the entire house more or less because someone decided to tap into the old knob and tube. The first and second floor is done, all that is left is the attic. It is a trying experience.
My questions all pertain to getting this attic done. The joists and studs have no rythme or reason to them. So joists are 16" apart, some are 14" and even some are 20". Since the house has settled for 100 years, it seems like they have starting to drift from being level. I could go on and on but I should get right to my questions.
1. How do I find the joists and studs if they aren't spaced equally and have drifted over 100 years.
2. We are laminating over what seems like some type of particle panel board (It isn't wood and is very spongy). Should I be using an adhesive to compensate for the lack of a consistent screw pattern.
3. Should I have stocked the drywall (3/8th) on the 3rd floor before we even starting hanging? That is sort of rhetorical because I would hope the answer is yes, but how? I've cut slots into the floor before which worked perfectly, but with years of lipstick what do I look out for?
Out of all the things I've been tasked to do over the past 8 months, this seems to be testing my patience the most.
DoubleTrouble is offline
Old 02-05-2019, 09:55 PM   #2
hdavis's Avatar
Rewards Points: 2,604
Re: Laminate Drywall Advice
1) studfinder, nail, or drill
2) if you go over that, you'll have nothing but screw pops
3) Huh? You're asking what to look out for when you cut a section of floor out, is that right?
hdavis is online now
Old 02-05-2019, 11:34 PM   #3
Anti-wingnut's Avatar
Rewards Points: 3,428
Originally Posted by DoubleTrouble View Post
Evening everyone.
Maybe DIYChatroom is a better place for you, this place is for pros and your question is very basic.
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
hdavis (02-06-2019)
Old 02-06-2019, 08:04 AM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 522
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Tinstaafl is offline
Im bidding for a commercial painting job. any advice? BaranG Painting & Finish Work 13 02-25-2014 01:54 AM
drywall subs needed ASAP estimating2013 Help Wanted or Looking For Work 4 04-27-2013 06:46 PM
Wood framing/furring for suspended drywall ceiling akm Carpentry 30 04-24-2013 09:42 PM
Drywall sagging on 24" o.c. ECinc Drywall 20 10-30-2010 08:31 PM
Any Of You Guys Use This Drywall? Ed the Roofer Drywall 12 03-02-2009 11:16 AM
