Knife Size - Page 2 - Drywall - Contractor Talk
Knife Size
Old 02-15-2014, 09:56 PM   #21
mski's Avatar
Trade: home improvements
Rewards Points: 502
Re: Knife Size
6" knife for insides taping and finishing. 6" for taping flats then 12" to finish.
Anyone else when taping inside corners use the knife sideways to mud the corners?
Using a 6" knife I can spread the mud quickly 2/3 the way down this way in one pass then bottom up last 1/3.
mski is offline
Old 02-15-2014, 10:07 PM   #22
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
Re: Knife Size
Originally Posted by D.E.P.S. View Post
The original question was in regards to what knifes were used to obtain satisfactory results....... was it not?
My original follow up said that he would get a thousand different answers.
The OP came back saying that a 4" knife................was no way!
This "so called" Pro was trying to give him the most efficient answer.
That is what we are all here for............is it not?
Sanding sucks.......... you wanna sand 6" 8" and 12" inch corners?
Go for it!
DEPS
I was not including you as a Pro as you are not a taper by trade just another guy with an opinion
Anderson is offline
Old 02-16-2014, 06:09 AM   #23
Home Repairs
D.E.P.S.'s Avatar
Trade: Home Improvement
Rewards Points: 424
Re: Knife Size
Originally Posted by Anderson View Post
DEPS
Actually.... I am a finisher that turned into a home improvement guy. My wife was a finisher for about 25 years until she blew out her rotator cuff a while back. My son has been at it for about 15 years, and is a bit more "new school". He primarily runs machine tools on all of his jobs. I had some pretty good training from both of them before I entered the field. I spent 6 years pulling mud until the last company I worked for removed me from the field to perform estimating duties. I lasted about 3 years. I couldn't stand looking at prints, UL codes, and estimating software all day long. I run my own little company now and drywall is only about 25-30 % of my business. Mostly "lipstick on a pig" stuff to help realtors move property, or builders that need a fast/neat texture repair guy.
D.E.P.S. is offline
Old 02-16-2014, 06:29 AM   #24
Home Repairs
D.E.P.S.'s Avatar
Rewards Points: 424
Re: Knife Size
Originally Posted by Texas Wax View Post
Oh and I'll add....
I avoid using the idiot stick to compensate for poor taping skills. A quick light sanding at the end is all that should be required. Focus on a few stray snots and final feathering
(Idiot stick is sanding pole)
Pretty funny, and it reminds me of sanding my own work when I first worked production. When sanding day came around, nobody in the crew wanted to help sand my work. They would all laugh and pile into other rooms or areas where the experienced finishers had bedded & skimmed. It was all in fun, but it was also a incentive for me to improve.
D.E.P.S. is offline
Old 02-16-2014, 07:14 AM   #25
hdavis's Avatar
Rewards Points: 4,924
Re: Knife Size
There's few things I dislike more than sanding someone's work when they have no clue what they're doing. I've done that once in the past, that I can recall, to help out a friend whose brother was supposed to be building an addition for her. The coarsest I had was 80 grit, so that's what I used, and it still took me a few hours to get it ready start doing coats - every joint was humped up bad.
The worst part was, he wasn't supposed to be there, but he showed just as I was finishing sanding, grabbed a hawk and trowel, and laid it on thick right over the joints. No detailing, no feathering, just a big mess. I just kept my mouth shut and left. Stills get me POd.
hdavis is offline
Old 02-16-2014, 07:23 AM   #26
justanotherdrywaller
b,mitch's Avatar
Trade: drywall
Rewards Points: 26
Re: Knife Size
if you',re not efficient enough to run a 4" down a angle ,you're not going to do any better with a 6".
b,mitch is offline
The Following User Says Thank You to b,mitch For This Useful Post:
blacktop (02-16-2014)
Old 02-16-2014, 07:42 AM   #27
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
Re: Knife Size
Words of wisdom Bernie, welcome to CT!
mnld is offline
The Following 2 Users Say Thank You to mnld For This Useful Post:
b,mitch (02-16-2014), blacktop (02-16-2014)
Old 02-16-2014, 08:00 AM   #28
Home Repairs
D.E.P.S.'s Avatar
Rewards Points: 424
Re: Knife Size
I run into that stuff all the time. Everyone thinks that finishing is mindless/easy work until they realize they need a lot more than a few buckets of mud and a 6" plastic knife from LOWES.
D.E.P.S. is offline
The Following User Says Thank You to D.E.P.S. For This Useful Post:
hdavis (02-16-2014)
Old 02-16-2014, 09:49 AM   #29
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
Re: Knife Size
.....[/QUOTEt] Sanding your own work is the best way to learn taping. We dont hand coat much but when we do we use a 10" and 12" for cornerbeads. We use an 8" to wipe tape(flats and butts) and always keep a 6" in back pocket.... 4" and 5" knives are in the tool bags but get used rarely. We will pick angles with a 6". Final coats (touch up butts) we use 12" or 14". We use Blueline boxes and tepetech angleheads
iDAHOchris is offline
Old 02-16-2014, 09:50 AM   #30
tyb525's Avatar
Trade: Remodeling and Carpentry
Re: Knife Size
I work for a GC, and I do woodworking as a hobby. I also cut most of my own lumber for that with a Woodmizer LT10 sawmill.
Dull tools cause accidents. Sharpen your tools before they get dull!
tyb525 is offline
Old 02-16-2014, 11:33 PM   #31
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 214
Re: Knife Size
I've never laughed so hard in my life!!!!
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 02-17-2014, 12:34 AM   #32
Texas Wax's Avatar
Rewards Points: 1,784
Re: Knife Size
That's cause your a box man LOL
Texas Wax is offline
Old 02-17-2014, 12:39 AM   #33
Drywall Slave
blacktop's Avatar
Rewards Points: 214
Re: Knife Size
No....not really! I will use the boxes on the block coat[sometimes] But after that It's all skimmed out by hand.
blacktop is offline
Old 02-17-2014, 10:14 AM   #34
Dan_Watson's Avatar
Rewards Points: 2,684
Re: Knife Size
Now that your here, please elaborate....
Your welcome for the laugh.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
blacktop (02-18-2014)
Old 02-18-2014, 11:53 AM   #35
Drywall Slave
blacktop's Avatar
Rewards Points: 214
Re: Knife Size
+ YouTube Video
Block coat on the seams I'll load and cut the edge with an 8'' then smooth out with the 10'' Then stripe the seams using a 5'' wiping it down with an 8''to hide the tape line [or a heavy sanding but that makes for a trashy skim] ,Then skim the seam with the 12'' [3 coats]
That's an old vid ..I use a 7'' mud box now for the block coat.
I use Mint craft knives . I never cared for the narrow banded knives ..After about 2 or 3 homes i'll pitch the 10'' and 12'' broad knives ,when they start getting flimsy There not much count for blocking or skimming .
1 could never get the hang of running the angles with a 4'' !
1 was taught running angles with a 5'' [ Works for me]
On bead 3 coats 1st coat 10'' 2 skims with a 12''
On butts Whatever it takes 3-4 coats with 12'' sometimes i'll break out the 14''..
On field screws 2 heavy with a cut down 5'' [a sliver off the top and sides] Then a tight 2 skims with a 6'' I try not to pad em....
+ YouTube Video
I've tried the new Kraft ss 5''/The new Sheetrock 5''/The new Hyde 5''.
Didn't like them! I prefer the old style Hyde.
Just my 2 cents ..
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
hdavis (02-18-2014)
Old 02-18-2014, 12:22 PM   #36
Drywall Slave
blacktop's Avatar
Rewards Points: 214
Re: Knife Size
BTW.....My apologies for being a smart as$ ..
blacktop is offline
Old 02-19-2014, 10:37 PM   #37
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
Re: Knife Size
my 3 way knife is a 4.5'' and a 5.5'' I cut them down
dont work hard...work smart
icerock drywall is offline
Old 02-20-2014, 02:51 AM   #38
VinylHanger's Avatar
Rewards Points: 10,844
Re: Knife Size
I've been working with a 12 inch trowel and hawk lately. 6 inch stiff knife to bed tape, then the trowel for every thing else. The narrow edge works great for corners and narrow spots. I find it's easier to pull the top coat tighter as well.
I'm not a taper by trade, so my speed wouldn't win any awards, but in the end it looks good and I like the feel of the trowel over the knives, and it doesn't seem as effected by goobers on my top coat.
VinylHanger is offline
Old 02-20-2014, 08:04 AM   #39
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
Re: Knife Size
I taped for years with knifes and bread pan. On with a 6 off with an 8, on with the 8 off with a 10, on with 10 off with 12. This was the way I was taught. A couple years ago I changed to a hawk and 12" trowel. After a short time I found my sanding time was cut way down with the trowel and my joints were looking better. I now have a 12, 14, and 16" set of trowels. The only time I use a knife is a 4" on the angles and 3 ways.
To the OP if an 8" knife works for you then use it, but if you learn with a 4 or 5" i think you will find it easier and faster.
ToolNut is offline
Exterior Window Trim Proportion to siding size md2020 Windows, Siding and Doors 19 02-18-2013 09:10 AM
Mini Ex size rino1494 Excavation & Site Work 24 07-29-2012 05:56 PM
Replacement sink...odd size MasterBuilt Plumbing 4 07-15-2012 02:22 PM
Duct Work Size Docwhitley HVAC 8 12-12-2010 09:26 AM
Considering a Gas Range, need advice on pipe sizing/service size xmptsunami HVAC 4 09-01-2010 06:09 AM
