Inspection Light Replacement - Drywall - Contractor Talk
Old 07-22-2018, 12:30 PM   #1
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 991
I use a 150 watt bulb in an old trouble light corded for inspection before priming. Anything I can look at that's handheld and cordless. The cord is a pain most times. I do use 18v Makita and Milwaukee 12V and 18V tools. Not sure an LED bulb is what I should be looking at for lumen brightness to catch those pesky flaws.
Thanks
gowings is offline
Old 07-22-2018, 12:50 PM   #2
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Re: Inspection Light Replacement
Festool makes one specifically to do what you want, except it isn't cordless.
https://www.festoolusa.com/products/...---stl-450-usa
Milwaukee does make some of the nicest cordless lights out there with awesome color temperature. I sometimes just use my little stick light for finding flaws that need to be corrected. Their newer M18 Rover with the flexible head is pretty awesome.
Peter_C is offline
Old 07-24-2018, 06:32 AM   #3
rblakes1's Avatar
Rewards Points: 3,600
I use 2 Milwaukee Rovers, the one with the swivel head and the smaller one with a handle. I also started wearing a headlamp when doing my final, helps catch some stuff.
I also don't do large projects, mostly bathrooms so this may not scale up as nicely
rblakes1 is offline
Double pole single throw light switch? Philament Electrical 2 09-20-2016 07:25 AM
Heat Exchanger Inspection Methods Symposium MechAcc HVAC 3 08-15-2009 01:10 PM
