Inner Drywall Corners - Failing Plastic Vs Paper Tape - Drywall - Contractor Talk
Old 07-09-2018, 04:14 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 520
I've fixed enough inside corners but today, visiting a job, were many inside plastic corners that were cracked and rippled, some clear through to the actual corner. Looked as if someone else before the turn of the century took a knife and slivered away the sides of them...
Giving so many of the corners were failing, as are quite a few horizontal seams, I'm questioning the framing that backs it . . .
I take it the plastic corners must be removed in entire sections. Pulling out partials of the hard inner beads and then paper taping overtop could get messy resulting in too-high-a-build... ?
artinall is offline
Old 07-09-2018, 07:08 PM   #2
Big Shoe's Avatar
Rewards Points: 2,070
Re: Inner Drywall Corners - Failing Plastic Vs Paper Tape
I don’t know what you mean by plastic. Vinyl like straight flex?
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
Old 07-09-2018, 08:20 PM   #3
artinall's Avatar
Rewards Points: 520
Seems heavier than straight flex. But probably is vinyl.
Maybe it's me but I don't see any paper on these... looking at the "cuts" Would have to peel one off.
Probably 12 -15 yrs old or greater.
It's a condo actually. Some inner corners cracked/rippled most the length up.
If it was framed out correct (ea. side) then something really somehow moved. Don't think it explains the horizontal failures/cracks on the wall areas.
Could it have been put up "super green"?
artinall is offline
Old 07-11-2018, 04:29 AM   #4
Big Shoe's Avatar
We don’t have as many “movement” issues in Florida as you guys up North.
Not exactly sure what you have without laying eyes on it. I recall metal and plastic inside corner products but they were beads.
I’ve also seen paper corners “ripple”.
Good luck.
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
artinall (07-11-2018)
Old 07-12-2018, 06:36 PM   #5
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 4,572
Pictures sure would help!
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is offline
fireplace wall with rounded drywall corners mike gunderson Tiling 6 08-02-2015 10:28 AM
Custom paper overanalyze Wallpaper 4 01-30-2013 08:51 PM
"Quick" drywall patch robert c1 Drywall 23 01-23-2013 06:10 PM
Drywall tape and mud tips for 135 degree plus angled inside corners MikeGC Drywall 5 10-13-2010 09:48 PM
Max Framing nailer - Paper & Plastic Strip? Kastoria Tools & Equipment 3 03-27-2010 06:56 PM
