Identifying Plaster Walls - Drywall - Contractor Talk
Old 01-25-2013, 09:32 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
Visited a site that appears to have plaster walls, though I don't know if it is of the key/lath type. There are holes to be patched, and these are mostly nail/screw holes that went all the way through the wall. Am basically wondering what to use on all areas.
There is however one approx 2'x3' ceiling section that must be cut out and patched. And I know what a pain it can be to patch if it is lath. Someone has cut out a couple wall sections and replaced with drywall, although was left unfinished (no tape or multipurpose). Should alkaline resistant (grey?) tape be used on those areas?
This could well be cementitous board, don't have access to the inner wall. The house is at least thirty-fourty years old. But I guess I could go in the attic. What I do know is that sometimes using standard multipurpose can crack out quick around the edges on some plaster surfaces, and is very revealing to the eye if applied atop sheer smooth plaster.
Ideas? If I pull an outlet coverplate it might just reveal an electrical box.
artinall is offline
Old 01-26-2013, 05:10 AM   #2
Big Shoe's Avatar
Rewards Points: 2,110
Re: Identifying Plaster Walls
Drywall,mesh tape,quikset first coat and following coats with ready mix.
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
Sir Mixalot (01-26-2013)
Old 01-26-2013, 11:15 AM   #3
artinall's Avatar
Thanks much for the reply, Big Shoe. Have found the walls & ceilings to be a grey cemetitious type board with paper backing on it (not lath) with a whitish layer of textured plaster.
- For small holes (nail/screw holes): would you also use Durabond without mesh? For holes that pass clear though, like larger nail holes -- would you first back the opening with something like Durabond to prevent cracking? Is it okay to use patching plaster over Durabond/setting type?
- Anyone have experience with 'Dap Paster of Paris'? Is this suitable for small holes only or larger patches as well or more for hobby use? Is 'Dap Plaster Wall Patch' better?
- Have used Strucktolyte in the past, but found myself applying it over an alkline resistant mesh sheet and it has a thin build from what I remember.
Does it matter whether the material overtop of the sheetrock is: Durabond [tan bags] or 20 minute [lightweight, "easy sand" quickset patch in the white bag]?
- Also, should the sheetrock be primed so the Durabond/Quickset can adhere?
artinall is offline
Plaster Disaster actionman Drywall 5 04-28-2012 01:47 PM
Venetian Plaster......A blast from the past or a New World Trend?!? amerolaplaster Drywall Picture Post 1 02-17-2012 03:06 PM
Straightening Walls jason1980 Framing 22 12-02-2010 07:37 PM
Repainting interior block walls - Drylok? CarrPainting Painting & Finish Work 6 11-19-2010 05:55 PM
Installing crown on plaster walls KMRLLC Finish Carpentry 58 03-15-2009 08:03 AM
