I Suck At Mudding - Drywall - Contractor Talk
I Suck At Mudding
Old 10-24-2010, 09:49 PM   #1
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
I Suck At Mudding
Just thought I'd get that off me chest
Had to put in a few hrs today at a remodel I'm doing. Today was mud day
I'm lousy at it, and it shows. I usually end up doing 3-4 coats, and sanding for hrs between.
I don't want to sub out my Sheetrock, it's usually covered by cabs and back splashes.
But I hate knowing there's sucky mud behind my masterpieces.
where can I go for help?
Aaron Berk is offline
Old 10-24-2010, 09:55 PM   #2
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: I Suck At Mudding
Sanding for hours between coats sounds a little extreme. Do you stand back and throw the mud onto the walls?
I do 3 coats and sand only once at the end, and I'd be hard pressed to get 1.5 hrs sanding in a kitchen.
"Industry without art is brutality"
shanekw1 is offline
The Following User Says Thank You to shanekw1 For This Useful Post:
mudpad (10-24-2010)
Old 10-24-2010, 09:57 PM   #3
Project Superintendent
mudpad's Avatar
Rewards Points: 2,000
Maybe trade school? Or hire a guy to do it for you one time and be his apprentice?
Steve
mudpad is offline
Old 10-24-2010, 10:03 PM   #4
Can I get an Amen?
Aaron Berk's Avatar
yeah that's me. Every one always said "just toss it on there" So I did. lol
It's the whole smoothing thing. I lay the mud, then try and smooth it out and I get grooves and lines, along with craters in the mud.
Am I pressing to hard, holding the knife at the wrong angle.....
Old 10-24-2010, 10:06 PM   #5
Can I get an Amen?
Aaron Berk's Avatar
I wold love to have time for trade school
I'm a sucker for knowledge, gimme gimme gimme.
I'm thinking about pimping myself out to a local drywaller when I run into some down time.
Not sure how that would go over.
"Hey I really suck, mind if I work with you?"
Old 10-24-2010, 10:07 PM   #6
mudpad's Avatar
Sounds like you got trash in you mud
Steve
mudpad is offline
Old 10-24-2010, 10:14 PM   #7
Can I get an Amen?
Aaron Berk's Avatar
It was a fresh brand new bucket.
I had just found it last wk, on the side of the road.
Really, it was on the road.
I tried to flag down the guy who lost it, honked and every thing. But he just kept on trucking.
I've seen when I get trash on my knife. I'm pretty sure all my problems aren't from trash.
Hey whats with the different color knives any way, like the blue steel and such? Should I be using higher grade tooling?
I worked on a site with some sheetrockers awhile back, and they all sanded their knives before mudding. Was it just to knock off the rust spots, or is there something more magical about that?
Old 10-24-2010, 10:32 PM   #8
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
Sanding to knock off mudspots and or knicks in the blade edge.
You add water to your mud right?
Ready to use is a bunch of BS! Always add some water it spreads easier.
It almost sounds like you have mud drying on the blade, bucket, hawk, and its getting in when you spread.
I learned alot from this website http://www.drywallschool.com/protips.htm. Some real good videos to help a guy out.
Brett Hocking
Eagle Eye Construction/Aspen Custom Cabinets
Buffalo, WY
bhock is offline
The Following 4 Users Say Thank You to bhock For This Useful Post:
DaVinci_HD (10-25-2010), Jer (10-26-2010), Main Street (01-27-2011), Remodelor (11-23-2010)
Old 10-24-2010, 10:44 PM   #9
Can I get an Amen?
Aaron Berk's Avatar
I add a little water into my tray and mix batches. Should I be doing the whole bucket?
I also only grab mud off the top of the bucket, should I mix the whole bucket first?
Drying mud might be an issue, I might be trying to work it to long, should I just be laying and tooling it once. Is it possible to over work it?
I'm kinda treating it like painting, brush it on, come back with a wet edge.....
Old 10-24-2010, 10:58 PM   #10
Rob PA's Avatar
add some water...mix the whole bucket for a few mins..
I usually use a second bucket with just water for my knifes. Apply to the entire seam before going back to smooth. Dunk your blade in the second bucket...this will help smooth it out. Plus keep dried junk off your blade. I would only sand at the end. Once you prime you will see were it may need touched up. Use a floor halogen light to cast shadows so you can see what is going to show thru the finished product.
Rob PA is offline
Old 10-24-2010, 11:07 PM   #11
Can I get an Amen?
Aaron Berk's Avatar
Lack of water might be my number one issue.
I never thought about dunking my blade, nor have I heard about applying water to the seam before smoothing.
It sounds like the ticket I was looking for.
And only sanding at the end.
I'm a die hard woodworker. I sand everything, and then sand it again, and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again and again
So I can mud, and only sand once? really this sounds pleasing
Old 10-24-2010, 11:18 PM   #12
Fire up the BBQ
griz's Avatar
Rewards Points: 568
You sucked at riding a bike when you first started too.
You have to learn when to leave it alone. If there are ridges when dry, knock off with the knife. Try a damp sponge works wonders. Just takes practice.
griz is online now
Old 10-24-2010, 11:28 PM   #13
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,364
I find mud and tape to be a constant challenge for remodelers. None of us want to pay the price to sub it out, so we try it ourselves. It looks easy but takes years of practice to get good at it. Try watching some youtube videos and read a book on it, Myron Fergeson has a good one. Try investing in some tools as well, like a banjo and mud box, then learn to use them properly.
KennMacMoragh is offline
Old 10-24-2010, 11:41 PM   #14
Wood Butcher
bhock's Avatar
An old man once told me "It's not concrete son, if it doesn't look good the first time its just going to get worse."
Brett Hocking
Buffalo, WY
bhock is offline
Old 10-24-2010, 11:45 PM   #15
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
paneling
Tom Struble is offline
oldrivers (10-27-2010)
Old 10-24-2010, 11:46 PM   #16
Fire up the BBQ
griz's Avatar
Rewards Points: 568
Hey Brett, the old guy I started learning this trade from told me that about concrete.
griz is online now
Old 10-24-2010, 11:48 PM   #17
Wood Butcher
bhock's Avatar
But now we have power trowels that can even fix concrete the day after.
Brett Hocking
Buffalo, WY
bhock is offline
Old 10-24-2010, 11:50 PM   #18
Fire up the BBQ
griz's Avatar
Rewards Points: 568
Well, ya, sort of.
But if a guy can't make a taping job look ok, he's gonna play hell making concrete come out.
You sayin' I'm too old to have seen a power trowel? HAHAHAHAH
griz is online now
Old 10-24-2010, 11:54 PM   #19
A. Spruce's Avatar
Trade: General Contractor - ret.
As with all things, drywall taping takes time to get the hang of. I've been doing it for 20 years and by no means am I an expert, but I can get a good finish and match most surfaces when patching.
As cliche as it may seem, it is truly all in the wrist. You can't ride the knife too hard or you're going to have cut lines from the corners of the knife. What I've found is to ride the outside of the knife where it's on the wall surface and rise the inside of the knife over the wet mud. A trick that my drywall guy showed me was to bend an arc in the knife blade to help you feather the edges and ridge of your joints. Use the concave side to round the ridgeline and the concave side to blend the joint to the wall. When you're done, all you should need to do is lightly sand off some edges and ripples.
Thanks for that, you made me chuckle!
A. Spruce is offline
Old 10-25-2010, 12:20 AM   #20
What kind of mud are you using? Are you pulling it right out of the box or are you adding water to it? If it's too dry, that will cause lines. I use All Purpose Lite with a splash of water and use it for everything. I find the inside corners to be the hardest in preventing lines and craters. This guy explains it good I think
http://www.youtube.com/watch?v=gvnAj_QjkqQ
Does all gutter seal suck or what? MikeGC Roofing 15 11-01-2010 10:19 PM
mudding a wall liner yoderb Drywall 5 11-05-2009 09:19 PM
Unique advice on mudding shower pans. bob_cntrctr Tiling 29 08-01-2009 09:59 PM
Does nobullremodeling.com suck for a name? willworkforbeer General Discussion 77 07-19-2009 07:00 PM
Mudding Corner Bead katoman Drywall 10 07-13-2009 12:18 AM
