How Much Mud Per 4x8 Board ? - Drywall - Contractor Talk
Old 10-29-2012, 10:44 AM   #1
plazaman's Avatar
Rewards Points: 1,234
Pretty sure this has been discussed before, but wondering if you guys worked out a formula for how much is used per 4x8 board?
I use premixed mud sheetrock brand all purpose.
I never really tracked usage , and always just bought i thought was needed.
Is there even a formula or calculator for it?
plazaman is offline
Old 10-29-2012, 11:23 AM   #2
Holy Crap!
ROVACON's Avatar
Trade: General Contracting-Renovations-Carpentry
Rewards Points: 296
Re: How Much Mud Per 4x8 Board ?
One 5 gal bucket usually does 10 sheets. Thats the formula I use anyway.
Brian
ROVACON is offline
Old 10-29-2012, 11:24 AM   #3
scottktmrider's Avatar
Trade: carpenter/drywall
Rewards Points: 295
http://www.usg.com/sheetrock-estimator.html
Try this
scottktmrider is offline
The Following 2 Users Say Thank You to scottktmrider For This Useful Post:
Big Shoe (10-29-2012), joe dirt (10-29-2012)
Old 10-29-2012, 11:48 AM   #4
plazaman's Avatar
Originally Posted by scottktmrider View Post
Thanks!
plazaman is offline
Old 10-29-2012, 12:14 PM   #5
hdavis's Avatar
Rewards Points: 1,534
Some people use more, some use less - track your useage and figure out how much YOU use. This gets you a ball park number: http://howtodrywalldiy.com/drywallcosts.php
hdavis is offline
Old 10-29-2012, 03:16 PM   #6
GCTony's Avatar
Rewards Points: 482
one bucket for every 10 sheets of 4x12 is a little heavy. An average house having 180 boards, with 30 pcs of corner bead, we used to buy 15 buckets
GCTony is offline
Old 10-29-2012, 06:42 PM   #7
Big Shoe's Avatar
Rewards Points: 2,066
One for ten is a good rule of thumb. But the amount of bead makes a big difference.
Expect the Unexpected
Big Shoe is offline
Old 12-16-2012, 08:30 PM   #8
Henn Drywall's Avatar
Trade: Drywall
Rewards Points: 25
I think this is spot on, this is usually how I bid jobs for material purposes.
Henn Drywall is offline
Old 12-16-2012, 08:51 PM   #9
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Originally Posted by henn drywall View Post
i think this is spot on, this is usually how i bid jobs for material purposes.
+1.
ohiohomedoctor is offline
Old 12-16-2012, 09:13 PM   #10
manipulator of wood
I Mester's Avatar
Trade: general contractor
+2..
I just love the smell of sawdust in the morning!
I Mester is offline
Old 12-17-2012, 09:31 PM   #11
boman47k's Avatar
Rewards Points: 2,006
Panels:
3
Joint Compounds:
14 lbs. SHEETROCK® Brand Ready-Mixed Joint Compounds
(Taping, Topping, All-Purpose)
or 1 gal. SHEETROCK® Brand Plus 3® Lightweight Ready-Mixed All-Purpose Joint Compound
or 6 lbs. SHEETROCK® Brand Easy Sand® Lightweight Setting Type Joint Compound
or 7 lbs. SHEETROCK® Brand Durabond® Setting Type Joint Compound
Fasteners:
192 nails. Drywall Nails
or 120 screws. Drywall Screws
You'll also need:
36 ft. SHEETROCK® Brand Joint Tape
1 gal. SHEETROCK® Brand FirstCoat Paint for Priming
3 (29 oz.) tubes Drywall Adhesive
Seems heavy on the fasteners plus adhesive for 3 4X8 panels.
No rocker, but I have hung and finished some. Just off the top of my head, I can't imagine needing that many fasteners and adhesive.
If I fall dead, I hope I fall off a ladder, not this couch.
boman47k is offline
Old 12-20-2012, 07:56 PM   #12
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
20 boards.
2 green, 1 blue
Thats heavy for estimating purposes. That can get stretched to 30 boards
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 12-21-2012, 01:11 PM   #13
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,364
When I drywall for remodels I do a lot of skim coating. 10 4x8 sheets would probably take about 3 buckets. But that's when I'm trying to blend in old walls with new, fix defects etc. If you're doing new construction it's not as messy, 1 gallon per 10 sheets sounds about right.
KennMacMoragh is offline
Backer board installation jhcontracting Tiling 165 02-14-2012 09:22 PM
Board form concrete wall water stains DerekRC Concrete & Paving 0 12-06-2011 01:44 PM
determining skirt board height romoranger Finish Carpentry 2 07-07-2009 01:46 PM
Plywood over particle board PA woodbutcher Flooring 5 03-11-2009 06:09 AM
