Help! - Why Seams Bubbled 3+ Weeks After Finish? - Drywall - Contractor Talk
Old 08-02-2017, 04:59 PM   #1
kodie's Avatar
Trade: Residential Rehab & Web/SEO Digital Marketing
Rewards Points: 96
Here are before and after pictures, 4 weeks later. Really at a loss here - got a text from GC today saying 'disaster' w/ the attached finished room picture.
Short of it: What went wrong? How do we correct it so that the problem does not return? We've not run into this issue before and can't figure out what we did differently.
Long story:
The Project:
The room was a storage area attached to an office which they are converting to a conf room. Carpenter installed metal framing. We hung & finished the drywall. Pictures show pretty much the last day spent on this room.
We spent a lot of time making sure everything was smooth and flush incl inspecting closely w/ shining lights across every part of the walls to find imperfections. The weather at that time was consistently hot and humid. There was A/C running in the building, but there were days in the building that were quite warm and muggy - not all, but some. For the project, we had multiple box fans as well as two air movers. Only two overnights were we allowed to keep the fans on. Still, we were confident all mud dried completely before proceeding with next coats and/or sanding.
After completing this room, the GC inspected our work and gave us a big thumbs up. We were on site the next few days doing patchwork in another area, so we were able to check on our work even after the completion - no problems were noted. Also, we were able to talk to the painter a few days after who inspected the walls and also was impressed, didn't have anything for us to correct.
kodie is offline
Old 08-02-2017, 05:19 PM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 950
Re: Help! - Why Seams Bubbled 3+ Weeks After Finish?
Not much to see from pictures but it looks kinda sloppy. No offense. Everyone who gave thumbs up did so before there was light shining across glossy paint. There's a window right up against the wall. That wall needs to be level 5 by a top notch drywaller if you don't want to see joints.
Big Johnson is online now
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
kodie (08-02-2017), SmallTownGuy (08-02-2017)
Old 08-02-2017, 05:19 PM   #3
hdavis's Avatar
Rewards Points: 2,542
Poor bond to the board. (not that that told you anything) I'll see that when the mud is thinned too much.
Blue board? No trouble on the regular boards?
hdavis is offline
kodie (08-02-2017)
Old 08-02-2017, 06:02 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,069
I think that wall got somehow overlooked before the paint. The pattern that's telegraphed is identical to the mud edges in the second pic. (I'm looking at the seam left of the two receptacles, for reference). Blame the new guy.
MarkJames is online now
kodie (08-02-2017)
Old 08-02-2017, 06:50 PM   #5
kodie's Avatar
Rewards Points: 96
hdavis - apparently some regular boards also, but will see at tomorrow's visit
kodie is offline
Old 08-02-2017, 07:07 PM   #6
kodie's Avatar
Rewards Points: 96
No offense taken, always open to education and what you evaluate as 'sloppy'. Correct, the GC/painter inspected before paint applied, but also knowledgeable based on their own experience and would have recognize a poor job, I assume - perhaps incorrectly?
My understanding of level 5: "...refers to drywall that has been taped, first and second coated, and sanded lightly to remove tool marks before applying a thin skim coat to the entire surface including the seams and field. The skim coat is sanded lightly and checked with a halogen light to look for any imperfections..." That is the method applied to this project.
Just prior to this job, we completed a residential ceiling (finish only) and were able to view it after the owner painted - it was smooth. Just sayin', each job is different though.
kodie is offline
Old 08-02-2017, 07:10 PM   #7
kodie's Avatar
Rewards Points: 96
kodie is offline
Old 08-02-2017, 07:12 PM   #8
kodie's Avatar
Rewards Points: 96
Appreciate all of your comments. Suggestions for correction at this point?
kodie is offline
Old 08-02-2017, 07:17 PM   #9
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
First off, B Johnson is spot on.
Secondly, again, just like Johnson said, what shows on a ceiling is completely different from what shows on a wall.
You are double-damned on that job. You got vertical seams AND a shiner light running close to the wall from the window - just the same as a spotter lamp would do.
The link below is to a CT member's vids. Look at how wide he runs the joints.
https://www.youtube.com/user/mooredrywall/videos
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
Big Johnson (08-03-2017), kodie (08-03-2017)
Old 08-02-2017, 07:33 PM   #10
John the Builder
"Help! - Why Seams Bubbled 3+ Weeks After Finish?"
I just have to correct some of your thinking.
Those seams didn't bubble. They are exactly the same as the day they were sanded. They didn't swell, the didn't lift, they didn't change one bit.
When somebody says "bubble" it implies that the compound is somehow lifting or popping. And that isn't the case here.
You asked what the course of correction would be, and my answer would be to get a damned wide knife, some all purpose mud and take those seams out another 12 inches either side of center.
And, for God's sakes, learn to make Looong strokes with the knife. Those seams look like somebody was frosting a cake - little short dauber strokes.
Again, watch Moore's vids to see how simple adjustments in handling the knife and sliding the mud on can change things.
He's damned good.
The Following 7 Users Say Thank You to SmallTownGuy For This Useful Post:
Big Johnson (08-03-2017), Big Shoe (08-04-2017), griz (08-05-2017), Gumshoe (08-03-2017), kodie (08-02-2017), SuperiorHIP (08-04-2017), TimNJ (08-03-2017)
Old 08-02-2017, 07:49 PM   #11
kodie's Avatar
Rewards Points: 96
He's damned good.
I checked out the videos, thank you for the link. 'Bubbled' came from the GC but I agree with you that it not have actually 'lifted'. We'll find out the situation tomorrow and come back here with more info.
We really appreciate all the responses and receiving feedback so quickly here on this forum.
kodie is offline
Old 08-02-2017, 08:30 PM   #12
hdavis's Avatar
That's going to take more than a light sanding to get it to level 5.
Chances are the drywall finisher did an onion skin (if anything), not an actual thin skim.
Since you don't know whether or not it bubbled, it looks to me like someone just humped up the seams and then gave a light sanding.
hdavis is offline
kodie (08-03-2017)
Old 08-02-2017, 08:35 PM   #13
hdavis's Avatar
Bust it out until you don't see light under the wide knife edge. I think 12" is probably wishful thinking.
hdavis is offline
The Following 3 Users Say Thank You to hdavis For This Useful Post:
DaVinciRemodel (08-07-2017), kodie (08-03-2017), SmallTownGuy (08-02-2017)
Old 08-02-2017, 08:40 PM   #14
hdavis's Avatar
Keep in mind, both Moore and I have run into boards that have a hump next to the tapered edge. If you run into those, it takes a lot more to get the seam flatish.
hdavis is offline
kodie (08-03-2017)
Old 08-02-2017, 08:51 PM   #15
John the Builder
That would be a total of 24" - 1/2 the width a sheet...
The Following User Says Thank You to SmallTownGuy For This Useful Post:
kodie (08-03-2017)
Old 08-02-2017, 09:09 PM   #16
back doors to hell put in
Irishslave's Avatar
Rewards Points: 506
This is why I don't finish drywall. For all the featherin, screwin, sandin, mixin, eyeballin and all the return trips hell you might as well plaster the SOB.
I'm a screwdriver wrench and hammer man....not a marathon artist
Irishslave is offline
The Following 3 Users Say Thank You to Irishslave For This Useful Post:
Gumshoe (08-03-2017), kodie (08-03-2017), sparehair (08-03-2017)
Old 08-03-2017, 01:03 AM   #17
Walraven's Avatar
Trade: carpenter/joiner
Rewards Points: 372
With the critical lighting through that window the board should have been hung horizontal. And a full skim would not hurt either.
Walraven is offline
The Following 2 Users Say Thank You to Walraven For This Useful Post:
Old 08-03-2017, 05:36 AM   #18
Rewards Points: 950
Skim coating the whole sheet is used to even out the texture and sheen between the paper and the mudded (joints, corners, screws) parts, it won't help with ridges and could make the job look worse if you don't know what you're doing.
My advice is to find a really good drywaller in your area and hire him to fix it. You're going to be screwing around with this job until Christmas if you don't. Again, no offense just trying to save you a lot of aggravation, stress and time.
Not sure why you hung vertical??? The only reason I can think is because the ceiling was an odd height and would have required 2 horizontal tapered joints.
Old 08-03-2017, 06:09 AM   #19
John the Builder
In one pic you can just make out the metal grid for ceiling.
It's commercial.
Metal studs.
Board gets hung vertical.
Old 08-03-2017, 06:43 AM   #20
Rewards Points: 950
It's commercial.
Metal studs.
I noticed it was commercial by the slab and Windows, the carpet sealed the deal. Why do metal studs require the drywall to be hung different?
kodie (08-03-2017)
Porter Cable "Bammer" 15 ga Angled Finish JR Shepstone Tools & Equipment 7 03-11-2013 07:48 AM
Basement finish rex Construction 45 09-15-2012 03:53 PM
Bostich Cordless Angled Finish Nailer ? MF Custom Tools & Equipment 19 09-14-2012 10:08 PM
floor finish Pete'sfeets Painting & Finish Work 6 05-16-2012 07:14 PM
Odd Looking Floor Finish tccoggs Flooring 8 06-06-2010 11:52 PM
