Help ID'ing A Product...Do You Know What It Is? - Drywall - Contractor Talk
Old 09-06-2019, 09:44 AM   #1
Kilgore_Trout's Avatar
Trade: Construction
Rewards Points: 20
I need to do a repair to this wall. I've never seen this product before. It appears to be a faux concrete finish. It is trowled smooth with small areas of imperfection. It is a newer home and the finish is over sheetrock. Any Ideas?
edit: This could be applied over cement board...I'm not sure if it matters or not.
Kilgore_Trout is offline
Old 09-06-2019, 10:04 AM   #2
hdavis's Avatar
Rewards Points: 4,868
Re: Help ID'ing A Product...Do You Know What It Is?
Normally over sheetrock it's a plaster finish layer.
hdavis is offline
Old 09-06-2019, 11:12 AM   #3
Trade: Construction
Rewards Points: 20
Any ideas of what kind of plaster I'm dealing with?
Old 09-06-2019, 11:15 AM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,509
How big is the repair?
MarkJames is offline
Old 09-06-2019, 11:16 AM   #5
Trade: Construction
Rewards Points: 20
There is a hole in the ceiling about 2' square.
Old 09-06-2019, 12:18 PM   #6
MarkJames's Avatar
I would do it in drywall and joint compound. Matching the texture is going to be the tricky part, so practice on some scraps.
Old 09-06-2019, 12:23 PM   #7
Trade: Construction
Rewards Points: 20
The texture is pretty much smooth, I just don't know what material to use as the top coat. The walls aren't painted, they appear as another poster stated some sort of plaster. I'm just not well versed in all of these finish materials. So I'm trying to ID what it is.
Old 09-06-2019, 05:44 PM   #8
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,956
I would say that it is exactly that, plaster, plaster of Paris to be precise. Probably over blue board. They may have added a base tint to also.
Andy.
ScipioAfricanus is online now
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
hdavis (09-06-2019), SmallTownGuy (09-07-2019)
Old 09-06-2019, 07:03 PM   #9
hdavis's Avatar
The next thing to do is figure out how many coats at what thickness was put down. There's a good chance it was a single coat ~ 1/8" thick. Like Andy said, over blue board. The thin ones like that are called veneer plaster.
Lots of this is done down in Massachusetts. Pretty much a special order product around here, but Home Depot stocks Diamond veneer plaster.
hdavis is offline
ScipioAfricanus (09-07-2019)
Old 09-06-2019, 07:13 PM   #10
hdavis's Avatar
You can probably ignore all that, I don't know if you can do that decorative work with something like Diamond.
hdavis is offline
Old 09-06-2019, 07:21 PM   #11
hdavis's Avatar
Getting a decent final match is going to be a sumbitch.
hdavis is offline
Old 09-06-2019, 09:21 PM   #12
VinylHanger's Avatar
Rewards Points: 10,842
That would be a time to pass it off to a plaster guy.
I'm a sucker for trying new things, but that looks like a nightmare.
Funny thing about random patterns or plaster wash like that. It is never really random and what you do will stick out like a sore thumb.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
hdavis (09-06-2019)
Old 09-06-2019, 10:15 PM   #13
hdavis's Avatar
The only saving grace is it's on the ceiling. I counted at least 3 layers of color. The only guy I knew who could nail that type of work was a mural artist who did all kinds of decorative finishes to make a living.
He'd have to make up some panels and see what got him a match before doing the patch.
hdavis is offline
Old 09-06-2019, 10:31 PM   #14
Fire up the BBQ
griz's Avatar
Rewards Points: 3,034
you do not need to be very concerned with the product as the end results.
you have encountered a texture/wall finish done by a local artisan or a travelling one.
how the product is prepared, tinted, applied etc are very often like trying to copy someone's handwriting.
unless you are EXTREMELY skilled at matching hand textures it would be best to find a local guy who can attempt the match.
good luck.
griz is online now
Old 09-07-2019, 12:42 AM   #15
Eater of sins.
The best thing is to convince the home owner that the place looks like a great big pile of ****, (which it does). And to renovate nearly the entire thing into something that looks good and has a classy timeless style, (which this does not).
It is a ridiculous, foreboding torture chamber looking house of horror. And that is just the good parts.
Andy.
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
