Hanging Vertical Versus Horizontal - Page 4 - Drywall - Contractor Talk
Old 07-12-2014, 09:26 AM   #61
Quad Racer's Avatar
Rewards Points: 594
Re: Hanging Vertical Versus Horizontal
That's what I remember hearing. The key word in your post was "right". haha
Quad Racer is offline
Old 08-08-2014, 04:51 PM   #62
nodnarb's Avatar
Trade: drywall, metal framing, suspended ceilings ect ect ect
Rewards Points: 12
Originally Posted by tenon0774 View Post
Sorry,
U channel.
I've always known it as CRC.
Attachment 115290
We call it "black iron" here. That or CRC if we are feeling fancy.
Im a commercial guy so 99.9% of the thousands of sheets I have hung have been stand ups. As explained earlier its a firecode thing, it is also a hell of a lot faster to hang standups. Anyone who says different hasnt seen a production commercial crew in action.
Stand ups are weaker though, however with commercial slabs and expansion joints you seldom see the shifts and cracked slabs you see in shacks.
nodnarb is offline
The Following User Says Thank You to nodnarb For This Useful Post:
tenon0774 (08-08-2014)
Old 10-02-2014, 10:47 PM   #63
MSLiechty's Avatar
Trade: Bender Of Nails
Rewards Points: 428
CRC= cold rolled channel. 16 ga black iron
Sent from my iPad using Tapatalk
MSLiechty is offline
Old 10-24-2014, 04:15 PM   #64
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 973
So on a 92" high basement ceiling. Would it be 48 to the top and the 44 to the bottom horizontal. Or is it the other way. So the indents are away from the ceiling joint on the 44 trim. I'm stuck with 8's. Can't get anything longer down the stairs.
Just hanging board for the taper.
gowings is offline
Old 10-25-2014, 12:40 AM   #65
commercial
sandshooter's Avatar
Trade: metalstudframing/drywall
Rewards Points: 167
stand up 92" boards all the way around. its faster, easier to hang, and easier to tape.
sandshooter is offline
Old 10-27-2014, 11:33 PM   #66
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,732
Originally Posted by supercrew View Post
trust me when i say im no drywaller....ask the guy that tried to train me to tape and finish ....but he did teach me HIS way of hanging....hang it horizontal w/end joints staggard for the same reason you dont break it along a door or window...it WILL crack....i lived in a house that had a floor to ceiling crack EVERY 4'....on EVERY wall.....just my .02.....and like said....you cant fix mis-crowned studs.....just drive around south st louis county and jefferson county and look at the new construction with vinyl siding...pitiful to say the least....
That's because there's only about a dozen good Carpenters left in StL....the rest are all retired.......you want quality in this town you gotta call those one trick ponies from the CDC
Television is fake...The internet is real
Irishslave is online now
Old 10-28-2014, 03:40 PM   #67
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
I believe on wood you should lay down, although on metal your board should be stood up. Your commercial interior system relies on the steel stud on your joint to obtain your fire rating. It honestly should not be a debate.
ubcguy89 is offline
Old 10-28-2014, 04:04 PM   #68
ubcguy89's Avatar
Rewards Points: 742
ubcguy89 is offline
Old 10-28-2014, 11:33 PM   #69
MSLiechty's Avatar
Rewards Points: 428
Deleted
Old 10-29-2014, 04:53 AM   #70
Big Shoe's Avatar
Rewards Points: 1,910
Small jobs............I stand up when I can...........Faster finishing for me. Inside and outside corners much easier,cleaner.
Whole house, big jobs...........Standard horizontal.
I probably already said that a few pages back.
Expect the Unexpected
Big Shoe is offline
Old 10-29-2014, 06:27 PM   #71
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
You guys that hang vertical are certainly working with better framers than I am. If that stud is off by a 1/4" sure doesn't leave much to screw to on one side. Anymore than that, then what, add nailers ?
ToolNut is offline
Old 10-29-2014, 07:58 PM   #72
ubcguy89's Avatar
Rewards Points: 742
I hang stand ups in commercial work. I also frame my own jobs being a comm carpenter. And I have tricks if the occasional stud is off a hair...
ubcguy89 is offline
Old 10-29-2014, 08:05 PM   #73
hdavis's Avatar
Rewards Points: 3,002
Originally Posted by ubcguy89 View Post
And I have sledgehammers if the occasional stud is off a hair...
That how I read it
hdavis is online now
Old 10-29-2014, 08:09 PM   #74
jb4211's Avatar
Rewards Points: 2,306
Originally Posted by hdavis View Post
That how I read it
You mean:
Peter Gabriel - Sledgehammer HD (1080p): http://youtu.be/OJWJE0x7T4Q
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
hdavis (10-29-2014)
Old 10-30-2014, 04:44 PM   #75
ubcguy89's Avatar
Rewards Points: 742
That how I read it
I'm not a hack I usually hang in metal pull the pan head and move the stud over. If it is one sided you can take a piece of track and lap it over the stud to give you metal to hit. On wood I always lay my sheets down
ubcguy89 is offline
Old 10-30-2014, 05:01 PM   #76
hdavis's Avatar
No offense intended, wood framing is frequently "adjusted" with framing hammers or sledgehammers if needed, even during framing. Maybe some consider that hackery, I don't.
Metal is a whole different deal
Old 10-30-2014, 07:45 PM   #77
ubcguy89's Avatar
Rewards Points: 742
No offense intended, wood framing is frequently "adjusted" with framing hammers or sledgehammers if needed, even during framing. Maybe some consider that hackery, I don't. Metal is a whole different deal
I hear ya, I usually grab a stick or two of track when I hang houses. Really comes in handy if you didn't frame, and an inexperienced crew did
ubcguy89 is offline
Old 11-02-2014, 11:33 AM   #78
commercial
Rewards Points: 167
same here, i always keep some shiny 90 in my garage, easy to store and easy to use when backing is needed.
Old 11-03-2014, 08:39 PM   #79
scottktmrider's Avatar
Trade: carpenter/drywall
Rewards Points: 295
+2 I like it for inside corners, you don't have to have a saw or long screws or nails and works great in tight spots
scottktmrider is offline
Old 11-04-2014, 06:14 PM   #80
commercial
Rewards Points: 167
i call it, the framing band aid. haaaaa
Help with - Inside corner trim for vertical cedar siding wallmaxx Framing 3 07-22-2007 05:47 PM
Vertical Cedar Channel Rustic.. RISENRUN Carpentry 2 06-20-2007 11:46 AM
Any tips on hanging drywall kanadaeh Drywall 0 11-17-2006 07:04 AM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
regarding vertical and horizontal floor izote61 Flooring 11 09-28-2005 10:10 AM
